It is currently Fri Jul 18, 2025 12:25 pm
PostPosted: Thu Jul 25, 2019 6:04 pm
Some time ago saw a post about a jig to cut bindings (or purflings) with no waste, by Dave Stewart. Original post here in tutorials http://www.luthiersforum.com/forum/viewtopic.php?f=10117&t=19132 but some people here may not have seen it.
Anyway, I wanted to cut down purfling for a build from 2.7 to ~1.9mm
I've tried before with a fine bandsaw blade and zero clearance plate with mediocre results
So here's my quick and dirty version, works perfectly.
The maple spacer behind the rosewood securing the blade holds the purfling flat, and the rosewood strip with one screw holds the purfing against the back post like a featherboard.
Shallow cut to start, flip the purfling over end to end keeping the cuts aligned on each side, cut again, tap the blade down, repeat a couple of times and you're there.
Thanks Dave!
PostPosted: Fri Jul 26, 2019 7:18 am
That is a nice simple jig, thank you for showing it!
PostPosted: Fri Jul 26, 2019 7:26 am
Nice one Colin. Thanks for sharing!
PostPosted: Fri Jul 26, 2019 12:34 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Original jig was good, your changes make it great. Thanks, making one today because I need one shortly
Ed
PostPosted: Fri Jul 26, 2019 3:48 pm
I'm cogitating how a person could do the Tim Taylor version by adding an oscillating tool to it (More Power!).
PostPosted: Fri Jul 26, 2019 5:54 pm
Why not go the whole hog and go for a chainsaw. 8-)
These users thanked the author Colin North for the post: Clay S. (Fri Jul 26, 2019 7:03 pm)
PostPosted: Fri Jul 26, 2019 7:05 pm
"Why not go the whole hog and go for a chainsaw. 8-)"
Now That would be Tim Taylor! [:Y:]
PostPosted: Sat Jul 27, 2019 1:16 pm
Nice!
PostPosted: Mon Jun 10, 2024 7:25 am
First name: Jon
Last Name: Snider
City: Colorado Springs
State: Colorado
Thanks Dave!
Thanks Colin. Could you expound a little? It looks and reads like the maple piece holds down the purfling (which could work for any width up to wide sheets) and I think, unlike Dave’s jig (where the strip is pulled through) runs along the surface making the cut. And the “feather board” sets the width of the cut. But does does the maple piece index on the feather board? - does it touch?
PostPosted: Mon Jun 10, 2024 7:52 am
Both jigs work in the same way.
In mine as it says,
"The maple spacer behind the rosewood securing the blade holds the purfling flat, and the rosewood strip with one screw holds the purfing against the back post like a featherboard."
The width of cut is pre-set by the width of the maple spacer + half the width of the blade (it's a double edged bevel)
I'm splitting one piece of purling into 2.
Daves' is cutting binding.
If you are cutting wider stacks/pieces, I would suggest sourcing a single bevel heavy duty blade, perhaps like the
excel BEVEL BLADE #19B with the bevel towards the inside, so it holds the workpiece into the jig.
Or you could use a marking knife maybe.
PostPosted: Mon Jun 10, 2024 8:26 am
First name: Jon
Last Name: Snider
State: Colorado
Sorry Colin, I think I get it after zooming and waking up. For a wide piece of veneer you would just clamp it flat and index your blade, with spacer width your final purfling thickness. In that case it seems the “feather board “ wouldn’t be necessary?
Thx again for posting help.
PostPosted: Mon Jun 10, 2024 9:28 am
Of course, if you are cutting wider sheets/stacks that would just be an obstruction., which is why I suggest a single beveled to pull it into the jig.
If you start with a straight edge you should be able to feed/pull it though with care and cut strips off, just hold the jig thing in a vice or clamp it to something.
PostPosted: Mon Jun 10, 2024 10:48 am
First name: Karl
Last Name: Borum
Zip/Postal Code: 63303
Very nice!
Is the BWB purfling shown been cut already? Looks like it can take a tiny tiny cut.
Measure Twice,
Karl Borum
PostPosted: Mon Jun 10, 2024 1:44 pm
Kbore wrote:
Very nice!
If you're asking me, it's dated Fri Jul 26, 2019
These users thanked the author Colin North for the post: Kbore (Tue Jun 11, 2024 1:27 am)
