It is currently Fri Sep 19, 2025 8:05 pm
 Post subject: Kerfing glue surface
PostPosted: Fri Jul 12, 2019 11:34 am
I’m working on a short scale small instrument and somewhere along the line I messed up my rim radius. This resulted in reapplying the radius and consequently sanding down some of the kerfing. It is in a wedge so sanding cut down on the glue area. What surface area do I need to maintain past the binding channel to maintain a strong bond and ensure things don’t fly off?
 Post subject: Re: Kerfing glue surface
PostPosted: Fri Jul 12, 2019 12:06 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
I'd say 1/8" lining surface would be fine. That plus the side thickness will give you around 0.200" total glue surface. Small instruments like ukuleles or violins get by with about 0.080" linings all the time.
Just be careful with your binding/purfling scheme. Your linings are shorter down the side....so don't to cut right through it when routing the binding channel.
These users thanked the author Quine for the post: SnowManSnow (Fri Jul 12, 2019 12:13 pm)
PostPosted: Fri Jul 12, 2019 12:48 pm
First name: Ken
Last Name: Nagy
City: Goodrich
On the guitar I'm building the ribs are about 1.5 mm and the linings maybe 2.5 mm. That's .16" or so. I'm not worried. But then again I don't ever worry about anything.
I'm thinking of using black dyed wood veneer I have sitting around for the binding. I'll have to do it with several strips going around, but it is only .02" thick. I can scribe the depth, and file it about .02 deep. Glue them on, and scrape the sides. It won't harm the strength at all. I had to glue a few thin pieces on three small areas of the belly yesterday. I just decided to use the thin veneer, and the belly was in almost to the linings in those spots. Easy to add wood now than to fill a thin spot later.
I don't do things normally either, at least not very often.
Why be normal?
PostPosted: Fri Jul 12, 2019 1:39 pm
If you haven't closed the box you could redo those sections that have been sanded away. If the box is already closed and the plates are tight to the sides you could skip the binding and just smooth and finish the edges of the plates if it is a simpler instrument. The greatest risk is when you cut the binding rebate. Once the binding is installed most of the strength is regained if it is glued properly.
These users thanked the author Clay S. for the post: SnowManSnow (Fri Jul 12, 2019 1:43 pm)
PostPosted: Fri Jul 12, 2019 1:43 pm
I think I’ll be ok as the binding won’t be anywhere close to the thickness of the available kerfing
PostPosted: Sat Jul 13, 2019 5:31 am
I can tell you that you need about 1/4 in glue surface for long time
you get below 3/16 it will fail.
it is easy to fix now
These users thanked the author bluescreek for the post: James Orr (Sat Jul 13, 2019 11:21 pm)
PostPosted: Sat Jul 13, 2019 5:43 pm
Are you saying 1/4 “ after the channel for the binding is cut???
PostPosted: Sat Jul 13, 2019 5:50 pm
I’m going to rekerf the top. I’m not in a hurry and I need to get it right .
I’ll do a rekerf thread . Maybe it will help another noob one day
PostPosted: Sat Jul 13, 2019 6:58 pm
A lot of kerfed linings are 7/32 wide which is close enough 1/4in to start with. When you rout out for binding typically that's only about as thick as your sides maybe a hair bit bigger if you go with thin sides. In the end though you should have the full, or very close to it, width of the original kerfed lining. If you add purfling on top of that then you should not rout down to the lining but rather have a bit of top wood stair stepped in.
PostPosted: Sat Jul 13, 2019 8:11 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
I don't know whether this idea will help OP out , but.... I use a full-height laminate I get from LMI instead of purfling on the soundboard. Lots easier to cut one channel a bit deeper and install the 'purfling' layer first, and in a second step, install the binding proper. For me, it's easier.
Peter Havriluk
PostPosted: Sun Jul 14, 2019 6:01 am
if you can end at 3/16 you should be fine if your under than you cutting it too close.
PostPosted: Sun Jul 14, 2019 10:07 pm
Top kerf is gone. I’d rather make sure it’s ok and sleep at night:)
Users browsing this forum: No registered users and 61 guests
