It is currently Fri Sep 19, 2025 6:18 am
 Post subject: Re: Dremel for rosettes
PostPosted: Mon Jul 01, 2019 5:43 pm
Toward the topic I have always used a dremmel and stewmac base. For the the key is to not be in a hurry. I simply use tight bond as far as glue goes. I have used Ca but i tend to get it everywhere in one fashion or another
Here is a rosette I did yesterday with 0 gap. Just sneak up on it:) adjust a little as the cutter is going and shave off a tad at a time until it pops in
PostPosted: Wed Jul 03, 2019 11:41 am
Last Name: Cox
doncaparker wrote:
The only incentive I would have for going back to a Dremel would be to take advantage of the decent base and jigs that StewMac carries. But I like the power and weight from a laminate trimmer better, and with a really good base and jigs (Bishop Cochran), a laminate trimmer really is way better. A Dremel with sharp bits is fine. A laminate trimmer just works better.
I bought the SM jig and modified it for my laminate trimmer. The SM jig is fantastic and mounting my laminate trimmer to it made it even better. I wasted SO much time with other jigs prior to this - the SM unit beats all the ones I tried.
My issue with the dremel is the slack/runout in the spindle bearings and flexibility of the plastic housings. I ended up routing a lot of corrugated cuts.
PostPosted: Wed Jul 03, 2019 6:21 pm
First name: Richard
Last Name: Hutchings
City: Warwick
State: RI
Zip/Postal Code: 02889
Just did this one and the dremel was missing the nose so there was plenty of opportunity for movement but it cut perfectly clean.
Hutch
These users thanked the author banjopicks for the post: Hesh (Sun Jul 07, 2019 4:38 am)
PostPosted: Wed Jul 03, 2019 6:23 pm
First name: Richard
City: Warwick
State: RI
Oh yeah, 3 coats of spray shellac and CA.
Hutch
PostPosted: Sat Jul 06, 2019 6:57 pm
First name: Peter
Last Name: Coombe
City: Bega
Zip/Postal Code: 2550
Yes I have just discovered that there are Dremels and there are Dremels. I use a Dremel and my homemade jig to cut rosettes and have had no problems cunning clean channels. My current Dremel is about 4 years old and runs smooth with no or negligible runout, and gets used a lot. I decided to buy a new one as a spare. Bought one and it is complete garbage, unusable. So much runout I sent it back. Now waiting on a replacement and we will see how the replacement is. They seem to have a QC issue. Mine is my 3rd Dremel. First one lasted 20 years, next died one week after the warrantee expired, 3rd is great and a big improvement but apparently they are not all like that.
PostPosted: Sat Jul 06, 2019 7:53 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I guess you got a Friday-assembled Dremel.
Users browsing this forum: Glen H and 38 guests
