It is currently Sun Jul 20, 2025 10:30 pm
PostPosted: Thu Jul 04, 2019 11:31 am
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I'm building a slot head neck and got these tuners for cheap. They're marked "Grover" and came with bushings like regular "paddle head" tuners. Do the bushings go on just like "paddle head" ones or do they go in the middle part of the neck? Looks like the post would work better with them in the middle. I really don't know, but maybe one you have installed some like these.
Mike S.
PostPosted: Thu Jul 04, 2019 11:38 am
Those are either/or tuners as you can see by the two string holes. If you use them for a slot head don't bother with the bushings (how would you drill for them?) If you use them for a paddle head then you would use the bushings.
PostPosted: Thu Jul 04, 2019 12:44 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
I've used the bushings on those type of tuners on a slot head. Drill the hole for the shaft before slotting the peghead the correct size for the shaft. After cutting and shaping the slots, redrill the outside part of the hole for the bushing size. I ran the drill in reverse to better control any grabbing of the bit. Press the bushing in on the inside of the slot.
PostPosted: Thu Jul 04, 2019 9:04 pm
First name: Freeman
Last Name: Keller
I've built a bunch of slotted head guitars and never used bushings on the tuners.
PostPosted: Thu Jul 04, 2019 9:09 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I do not use bushings, but if I was it seems like I would want two for each tuner, one on each side.
PostPosted: Thu Jul 04, 2019 9:18 pm
We don't need no stinking bushings....
PostPosted: Thu Jul 04, 2019 9:33 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
The Gotoh slot head tuners from LMI that I have used on a few guitars came with press fit bushings. I think they are more trouble than they are worth.
PostPosted: Thu Jul 04, 2019 10:39 pm
Some slot head tuners do use bushings, but that set isn't one of them. As I mentioned those tuners can be used for either style of peghead and the bushings are supplied for the "paddle head " style.
