It is currently Mon Jul 21, 2025 8:26 pm
 Post subject: Cutting Pickguard
PostPosted: Wed Jun 26, 2019 12:20 pm
First name: Danny
Last Name: Vincent
30+ guitars and I've never used anything but clear pick guard material. I have a sheet of the less expensive SM tortoise shell.
Would be grateful for some cutting and shaping tips :D
 Post subject: Re: Cutting Pickguard
PostPosted: Wed Jun 26, 2019 12:54 pm
First name: Gary
Last Name: Leddington
Is it celluloid? If so scissors will get you close and then a sanding block to refine.
www.leddingtonguitars.com
PostPosted: Wed Jun 26, 2019 1:44 pm
First name: Danny
Last Name: Vincent
It wouldn't be celluloid. Likely plain old plastic. Can you sand it on a spindle sander without messing up the glue? It's the peel and stick stuff.
PostPosted: Wed Jun 26, 2019 3:40 pm
MDF template. Cut oversize. Rout. If material is thicker (like original ntirocellulose) rout bevel (and buff to finish).
PostPosted: Wed Jun 26, 2019 3:51 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
To add to Mr. B’s suggestion, we remove any PSA, scrape the bevel, wet-sand to 800, then buff to fine (Menzerna). We reapply 3M 468 and put the guard on wet for lacquer, varnish, or poly.
- Beth Brower
PostPosted: Wed Jun 26, 2019 3:56 pm
I use scissors. First cut it about 1/8" oversize then cut to the line. Follow up with sandng block to get shape perfect. Last step is to use a razor blade scraper to finish the edge in a bevel. Last one I did a few weeks ago.Image
These users thanked the author SteveSmith for the post: Colin North (Thu Jun 27, 2019 1:57 am)
PostPosted: Wed Jun 26, 2019 4:02 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
How do you go about removing the PSA? I have some inexpensive pickguard sheets with PSA that I would like to be able to use on some projects. The problem is the adhesive layer is white. It is nice that it brightens up the light/translucent sections of the pattern but you see the white along the edge where it is adhered to the top. It seems to be stuck mightily to the plastic and is very difficult to remove without distorting the pickgaurd material.
Bryan Bear PMoMC
PostPosted: Wed Jun 26, 2019 4:16 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
Soak in naphtha...the adhesive may be double-sided with a polyester scrim...if so, it may take a bit of time for the solvent to work, but it will. Once the scrim can be peeled, return to the naphtha soak to get the final layer of glue.
- Beth Brower
PostPosted: Thu Jun 27, 2019 2:00 am
Mr Smith. you are pretty handy with a pair of scissors sir!
That's neat.
PostPosted: Thu Jun 27, 2019 6:04 am
That's neat.
Thank you sir.
PostPosted: Thu Jun 27, 2019 8:27 am
I hate removing the adhesive from the back of pick guard material. The first thing I check when ordering pick guard blanks is to make sure it has no adhesive. I trace the outline from my template, using a razor knife or sewing needle, then cut very close to the line with scissors, and then clean up to the line with sand paper. Most of the material I cut, is much easier to cut, and less brittle, when it is warm. So, I hold it under a portable hair blower while I am cutting. Cuts like butter. Some materials won't soften with heat, but they are usually less brittle and cutting with scissors is no problem.
Users browsing this forum: Bing [Bot] and 35 guests
