It is currently Tue Jul 15, 2025 8:18 am
PostPosted: Sat May 04, 2019 3:28 pm
Just now finishing a guitar with Target EM6000. The can I'm using is unfortunately gloss, so how do a get a matte or satin finish from that? Will wet sanding to 800 grit do? Buff or not?
PostPosted: Sat May 04, 2019 6:28 pm
State: ON
You can do as you say and stop sanding when you like the sheen of the finish. However I've found that any finish which is gloss will polish up overtime with use. On a guitar body you'll likely see this start where the players arm rest on the guitar. The movement from playing guitar will polish the finish overtime.
If you want a satin or matte finish that will hold its sheen than you need to start with that type of finish. Or you can add a flattening paste to your gloss finish before applying (with some types of finish). With the EM6000 I think you would want to use the Satin finish next time around.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
PostPosted: Sat May 04, 2019 8:40 pm
If you want a matte finish that STAYS matte, you can borrow a trick from the kustom rod painters and put a pinch of cornstarch or talcum powder in the clear.... make sure you keep agitating the cup while spraying.
PostPosted: Sun May 05, 2019 6:13 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Scuffing a surface to make it a matte finish will just gloss back up very quickly from wear....
You need to add a refractory paste to your finish and this is almost always specific to the coating being used. Cornstarch or talc will take away gloss, also will take away clarity. Hot rod cars are painted solid colors and do not attempt to show fine wood grain through their finishes.
Brian
PostPosted: Sun May 05, 2019 8:26 am
Brian is correct.... for see-through finishes, your paint seller should be able to sell you (or add) a flatting agent (usually a fumed silica known as Cab-O-Sil). Believe it or not, it's an inert thickening agent that is edible. Ketchup makers add it, and restaurants used to add it to gravy. I remember this from high school plastics class, for some idiot reason.
PostPosted: Sun May 05, 2019 4:56 pm
Best not to inhale fumed silica.
PostPosted: Sun May 05, 2019 8:05 pm
Yeah..... What's your point? I wear a mask even when I shoot latex paint.
PostPosted: Mon May 06, 2019 2:13 am
My point was that if any newbies started handling fumed silica it's best if they mask up.
PostPosted: Mon May 06, 2019 9:57 am
Jeez Chris.
PostPosted: Mon May 06, 2019 10:36 am
My point is you mask up for ANY sprayed finish. So it follows.....
PostPosted: Mon May 06, 2019 1:45 pm
Some of us just stand down wind and hold our breath. laughing6-hehe
PostPosted: Wed May 08, 2019 6:34 pm
Last Name: Beaver
City: Lake Forest
Clay said,
"Some of us just stand down wind and hold our breath. laughing6-hehe"
Actually, I hate to admit it, but I have sprayed a few with water based that way before I smartened up.
Joe Beaver
Maker of Sawdust
PostPosted: Wed May 08, 2019 8:22 pm
First name: Carl
Last Name: Dickinson
City: Forest Ranch
Zip/Postal Code: 95942
If you stand downwind isn't it blowing at you? ;)
PostPosted: Thu May 09, 2019 8:55 am
"If you stand downwind isn't it blowing at you? ;)"
Cheap high! bliss (you're right - I should have said upwind, down wind is for hunting)
A fellow I knew was subbing for a finisher where he worked in the city. Some time during the day he heard a knock on the back door. When he opened it he found some poor derelict with an empty soda can and some change in his hands. He asked my friend if he could buy some "can". Apparently the regular finisher would sell these guys small amounts of lacquer thinner for "huffing".
There are two solvents I don't mind ingesting, but neither in excess - Water and Alcohol. The rest of them I would rather not even smell.
I do have and use a respirator when the need arises.
Users browsing this forum: Michaeldc, Treenewt and 12 guests
