It is currently Sat Jul 19, 2025 2:02 am
PostPosted: Mon Apr 15, 2019 9:51 pm
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I always wince when I use my reamer to install an endpin jack in an acoustic. Can’t help wonder “what if someone wants to remove the PUP and revert back to a strap pin/button?” Stewmac has an endpin with an expanding filler thingy that never appealed to me, but that’s what it’s made for.
But today I installed an endpin preamp in a newish California-built Larrivée. Its tail-mounted strap button was on the end of a bolt that went through the tail block into a T-nut. Removing the strap button and tapping the nut through to the inside left a hole exactly the right size for the jack — no drilling or reaming required! Very cool!
So now I wonder where these things come from. I’ve had at least two clients in the past who were looking to plug jack holes and I’ve never had a good looking solution. Anyone else seen these and know where to get ‘em?
PostPosted: Mon Apr 15, 2019 10:37 pm
First name: Pierre
Last Name: Castonguay
City: Québec, Qc
You mean those?
https://www.larrivee.com/shop/end-pin-chrome
Pierre
www.torvisse.com
Pierre Castonguay
These users thanked the author Smylight for the post: Tim Mullin (Tue Apr 16, 2019 11:25 am)
PostPosted: Tue Apr 16, 2019 10:29 am
State: ON
These are standard on all Larrivee guitars I've seen. The sure making installing a pickup jack a simple operation.
Josh House
Canadian Luthier Supply
http://www.houseguitars.com
These users thanked the author Josh H for the post: Tim Mullin (Tue Apr 16, 2019 11:25 am)
PostPosted: Tue Apr 16, 2019 11:26 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Well, easy enough to buy from Larrivée — a bit pricey, but good to know. thanks for the info!
These users thanked the author Tim Mullin for the post: Smylight (Tue Apr 16, 2019 2:04 pm)
PostPosted: Tue Apr 16, 2019 2:14 pm
Taylor sells 'em too. 10 bucks for chrome and 12 bucks for gold. I don't think that is a bad price.
jw ( o)===:::
PostPosted: Wed Apr 17, 2019 4:24 pm
It's just a standard T nut with a piece of plastic attached to it-ingenious!
PostPosted: Wed Apr 17, 2019 4:30 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
That end of the hardware is not original or complicated, but the strap button itself, with the integrated bolt of the right size, is not a standard item. I can see the justification for paying a few dollars for that.
But, on the other hand, I would probably just fill the hole with a dowel and then install a standard strap button. As long as the strap button has a big enough integrated washer to cover the hole, it would be invisible. I'm not crazy about being dependent on special hardware.
