It is currently Thu Sep 18, 2025 7:04 pm
 Post subject: Should this bother me?
PostPosted: Wed Apr 10, 2019 8:46 am
Last Name: Sollod
There is a spot in my maple neck that I thought I could carve past. I'm not sure at this point if I can carve it out, but I'll see how far I can go. It is not for a client. It's just another guitar I'm making. I guess I'm just going to have to get over it because I'm not abandoning this neck... Just thought I'd share... Any suggestions? Should I let it bother me?
www.swiftcreekguitars.com
PostPosted: Wed Apr 10, 2019 8:58 am
Beauty spot!
PostPosted: Wed Apr 10, 2019 9:11 am
Last Name: Sollod
Thank you Colin!
PostPosted: Wed Apr 10, 2019 9:14 am
It depends on the person. Me personally, I see wood as an act of God or Mother Nature or what ever you want to call it. There are no cosmetic flaws in a perfect act of nature. That is there for a reason, it grew there, it's wood a once living and beautiful thing in it's own right.
PostPosted: Wed Apr 10, 2019 9:50 am
If it does not carve out and if it bothers you, there is always the option of some kind of inlay.
PostPosted: Wed Apr 10, 2019 10:12 am
Careful application of wood bleach will lighten it some and make it less noticable. Sometimes wood bleach will "eat away" a little bit of material but a little filler can remedy that. Household bleach will work and is a bit less aggressive. It might take a few applications. You could do a "burst" on the heel and peghead or use a toned lacquer. Between bleaching and toning you might make it "disappear"
PostPosted: Wed Apr 10, 2019 10:19 am
I've successfully used wood bleach for a similar "defect" in a neck before.
PostPosted: Wed Apr 10, 2019 10:40 am
First name: Heath
Last Name: Blair
City: Visalia
Sorry, no advice for remedy, but yes that would absolutely drive me nuts. Maybe cut that full length of lamination out? Bummer. Sorry, bro.
sweat the small stuff.
PostPosted: Wed Apr 10, 2019 1:10 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
inlay a similar looking piece of wood on the other side of the neck inlay.
WOW it was in the tree!!
Mike Collins
PostPosted: Wed Apr 10, 2019 1:58 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I unearthed a similar flaw in the maple neck of a mando I made for one of the challenges here. It was for me so I just considered the "flaw" as "character." I didn't take any close ups but here on page 5 you can see a picture of how it looks on the completed instrument:
viewtopic.php?f=10133&t=37268&start=100
I don't even notice it anymore.
Bryan Bear PMoMC
PostPosted: Wed Apr 10, 2019 3:19 pm
Online
Last Name: Kincheloe
My build for the last challenge had two :) http://www.luthiersforum.com/forum/viewtopic.php?p=647385#p647385 A dark spot in the endgrain, and a small knot where it meets the shoulder. But I was going for a fairly rustic style, so it looks more appropriate than in this case with the lamination stripes.
Another possible solution would be to cut the entire heel off and glue on a block of different wood. Probably with a black line like you currently have on the heel cap. Or you could go totally radical and cut through it two or three times at different angles, and then glue it back together with black lines in the cuts (or maybe black-mahogany-black), making a sort of stacked heel but with non-parallel lines :)
PostPosted: Wed Apr 10, 2019 3:38 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
In Japan there is an interesting asthetic concept called wabi-sabi which involves accepting and appreciating the imperfections that occur in the natural world and celebrating them as symbols of true beauty. A potter might emphasize a slighy irregularity in shape or a crack in a pot. The gardener should cherish the single leaf that falls onto a perfectly raked stone path - and the luthier makes no attempt to disguise irregularities in the ratural materials.
I would have no trouble living with this as it is. If a naturally occuring imperfection drives us nuts then I think that says something interesting about us. But if it is your own stuff-up that is a different story!
PostPosted: Wed Apr 10, 2019 4:27 pm
Are you leaving the guitar natural? If so, that was nature's mark. If you are doing a stain or tinted lacquer, you can just feather in a dark heel.
PostPosted: Wed Apr 10, 2019 5:03 pm
Last Name: Sollod
I'm not going to do major surgery to fix this. The neck is fitted to the body and the headplate is attached and bound. I can't help but think that any attempts at "fixing" this would make it even more visible. I have some room to keep carving. If I'm lucky I'll carve past it or it will be reduced in size. I actually carved past a spot on a cherry neck on a former build. If it's still there, I'll likely live with it... Hopefully, the guitar will be attractive enough the spot won't jump out... The beauty spot on the girl above doesn't diminish her attractiveness... (She may have put that on herself...)
PostPosted: Wed Apr 10, 2019 6:31 pm
As you carve try to notice if the spot is getting bigger or smaller. If it's getting bigger you might want to leave well enough alone. If you are leaving it all natural you could use potassium permanganate to "age" the surface to it's eventual color, and then use pigment powder to blend the dark spot in.
As to the SYT above, I'm sure the "spot" was added on top of the 1/2 lb of make up caked on her face.
PostPosted: Wed Apr 10, 2019 7:15 pm
I use oil based enamel paints and an artist's brush to touch up small inclusions in maple. Add a bit of tint to a white enamel to get the proper shade. You can't make it invisible but you can lessen the obvious nature of it.
These users thanked the author Barry Daniels for the post: Bryan Bear (Wed Apr 10, 2019 7:16 pm)
PostPosted: Wed Apr 10, 2019 7:42 pm
First name: Hans
Last Name: Mattes
City: Petaluma
Zip/Postal Code: 94952
It's noteworthy that we struggle to make our hand-built, nature-sourced creations look as if they were made by precision machines from flawless, homogeneous materials. Homogeneous except for the wood grain which, after filling any pores, we encase in a layer of shiny (if quite thin) plastic.
PostPosted: Wed Apr 10, 2019 7:58 pm
Last Name: Sollod
The other aspect of beauty is the sound it makes...
These users thanked the author sdsollod for the post: Hans Mattes (Wed Apr 10, 2019 8:17 pm)
Users browsing this forum: Brad Goodman, DennisK and 27 guests
