It is currently Fri Sep 19, 2025 8:00 pm
PostPosted: Thu Mar 14, 2019 2:23 pm
what does everyone tend to use for filling pores on mahogany necks.
I have used dust and shellac before with fairly good results, anyone use zpoxy on neck?
Sent from my SM-G960F using Tapatalk
PostPosted: Thu Mar 14, 2019 2:50 pm
Yup, all the time. Just coat and rub it in/on with a vinyl gloved finger and sand back, repeat 2/3 times.
Bit of a learning curve sanding back curved surfaces, I usually start with a light touch and card scraper followed by P180/240 backed with various erasers.
Last coat is thinned and scuffed with scotchbrite after removing any nibs with a single edged razor.
These users thanked the author Colin North for the post: cablepuller1 (Thu Mar 14, 2019 3:05 pm)
PostPosted: Thu Mar 14, 2019 3:06 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I use z-poxy on mahogany necks pretty much the same as Colin. Works great.
These users thanked the author J De Rocher for the post: cablepuller1 (Fri Mar 15, 2019 3:38 am)
PostPosted: Thu Mar 14, 2019 3:12 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Traditional pumice pore fill for me. Works well most of the time. The fingerboard edge can be a challenge, though. Not enough room to do the normal rubbing around to get the mud down in the pores. It works out eventually.
These users thanked the author doncaparker for the post: cablepuller1 (Fri Mar 15, 2019 3:38 am)
PostPosted: Thu Mar 14, 2019 3:47 pm
Because necks are thicker pieces of wood which don't move as much with humidity swings I don't mind them having a relatively thick finish so on moderately close grained woods like walnut and mahogany I just self seal with the finish material and don't pore fill
These users thanked the author Clay S. for the post: cablepuller1 (Fri Mar 15, 2019 3:38 am)
PostPosted: Thu Mar 14, 2019 5:01 pm
Last Name: Sollod
Quote:
"Yup, all the time. Just coat and rub it in/on with a vinyl gloved finger and sand back, repeat 2/3 times."
[:Y:]
I'm with Colin...
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: cablepuller1 (Fri Mar 15, 2019 3:38 am)
PostPosted: Fri Mar 15, 2019 9:26 am
I typically use a traditional oil based filler on necks. I like the way it stains it and it does a fine job filling it.
These users thanked the author jfmckenna for the post: cablepuller1 (Sat Mar 16, 2019 3:27 pm)
PostPosted: Fri Mar 15, 2019 10:31 am
First name: Rob
Last Name: McDougall
City: Cochrane
State: Alberta
I pore fill my mahogany necks with the Rosewood LMI micro-bead filler from LMI.
It is easy to use and the colour is quite dark, which pops the grain.
These users thanked the author Robbie_McD for the post: cablepuller1 (Sat Mar 16, 2019 3:27 pm)
PostPosted: Fri Mar 15, 2019 10:54 am
First name: Freeman
Last Name: Keller
I used paste pore fillers for the first few mahogany necks, often with some brown and red to make them match rosewood bodies. Lately I have been using strictly Zpoxy and I'm much happier with the results. Here is a solid mahogany body filled with Zpoxy (don't have a picture of the neck but it looks the same)
Here is one being stained to match cocobolo and then pore filled with Zpoxy
These users thanked the author Freeman for the post (total 2): cablepuller1 (Sat Mar 16, 2019 3:28 pm) • Robbie_McD (Fri Mar 15, 2019 11:01 am)
PostPosted: Fri Mar 15, 2019 1:28 pm
Nice one on matching that stained neck to the body.
PostPosted: Sat Mar 16, 2019 10:55 am
I have been trying different fillers to see if there is a difference. this is what I found out for me
A pore o pac is good but can be tricky to learn how to use
B LMI water based filler applied with a paper towel 2 coats use a sealer before and after works like a dream
C Aqua Coat Easy to use. seal with shellac before and after best filler I ever used
D E Poxy works but too much work compared to aqua coat it can also leave a sealed footprint under finish
E egg whites and dust Messy but works
F dust and shellac compared to aqua coat too much work
In all I have to say the aqua coat is easy and you can apply the 2nd coat in 45 min
Both the LMI filler and aqua coat are water based so easy clean up
These users thanked the author bluescreek for the post: cablepuller1 (Sat Mar 16, 2019 3:28 pm)
PostPosted: Sat Mar 16, 2019 11:18 am
Aqua Coat is working well for me too. Super easy. Shellac before and after as John says.
These users thanked the author SteveSmith for the post: cablepuller1 (Sat Mar 16, 2019 3:29 pm)
PostPosted: Sat Mar 16, 2019 2:38 pm
Aqua coat sounds interesting, just wondering about the grain "pop" compared to Zepoxy, the shellac may help of course - ?
These users thanked the author Colin North for the post: cablepuller1 (Sat Mar 16, 2019 3:29 pm)
PostPosted: Sat Mar 16, 2019 3:24 pm
I do think that Zpoxy 'pops' the finish a little bit more but I am happy with shellac/Aqua Coat and love the convenience.
These users thanked the author SteveSmith for the post (total 2): cablepuller1 (Sat Mar 16, 2019 3:29 pm) • Colin North (Sat Mar 16, 2019 3:28 pm)
PostPosted: Sat Mar 16, 2019 10:17 pm
+1 for me. Good old Pumice and blond shellac. I find you can't beat the color match.
These users thanked the author Alain Desforges for the post: cablepuller1 (Tue Mar 19, 2019 1:35 am)
Users browsing this forum: No registered users and 61 guests
