It is currently Sat Jul 19, 2025 8:25 am
Post new topic Reply to topic  [ 60 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue Feb 05, 2019 12:45 pm
What is the best way to fill the pores in Indian rosewood back and sides? I’ve read about several methods, epoxy (zpoxy), shellac and pumice, waterbased fillers such as aquacoat or timbermate, building coats of lacquer.
Not necessarily looking for the easiest way but for the best. I was debating using tru oil as a finish coat, spraying lacquer would probably not be an option due to temperature restrictions at the moment.
These users thanked the author 6string for the post: Pmaj7 (Wed Feb 06, 2019 12:14 am)
PostPosted: Tue Feb 05, 2019 1:05 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
How do you define "best" in this case? What performance characteristics are you concerned about?
PostPosted: Tue Feb 05, 2019 1:11 pm
Hard to beat epoxy (zpoxy)
PostPosted: Tue Feb 05, 2019 1:19 pm
I just finished using ZPoxy. And I have to say this far it is my favorite.
It’s hard to mess the process up.
Oh, and make sure you get finishing resin .... not strait epoxy (although it may still be fine).
It does take some sanding back to get it flat, but it stands easily. If possible use a sanding method with dust extraction (requires a delicate touch). Also wear a mask. Don’t wanna breath the stuff.
PostPosted: Tue Feb 05, 2019 1:34 pm
Country: Ireland
You can use tru oil to fill the pores. Haven't done it yet but I soon will.
PostPosted: Tue Feb 05, 2019 2:10 pm
The most common method for home builders is epoxy. I was pretty gung ho for trying CA, I did some test panels with it that gave me grief. So the last shiny I did with epoxy, and I couldn't believe how easy it was or why I used to think it was difficult. Instead of sanding, I scraped it level, and it turned out great...
These users thanked the author meddlingfool for the post: Pmaj7 (Wed Feb 06, 2019 12:17 am)
PostPosted: Tue Feb 05, 2019 2:13 pm
First name: Larry
Last Name: Hawes
There's a thread addressing the possibility of micro cracks in EIR that don't show up until later in the finishing process with the suggestion of a thin CA as an initial under coat to seal those cracks then a pore filler on top of that. I'm seeing those cracks in my current EIR and will use a thin CA, then pore fill with Zpozy over that.
When budget allows I will most likely switch to Silver Tip epoxy with the fast hardener.
Thank You and Best To All
PostPosted: Tue Feb 05, 2019 2:15 pm
First name: Larry
Last Name: Hawes
I tried it with sand paper and it built nice pore filling slurry that took forever to harden - can't remember if it ever did actually... Probably won't go down that road again but still love Tru Oil as a finish for necks...
These users thanked the author LarryH for the post: Bryan Bear (Tue Feb 05, 2019 2:22 pm)
PostPosted: Tue Feb 05, 2019 2:23 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I've not used Tru-oil on rosewood but I have heard that sometimes it doesn't dry well on rosewood.
Bryan Bear PMoMC
PostPosted: Tue Feb 05, 2019 3:18 pm
Country: Ireland
This is bad news. I've only done open pore finishes on mahogany which I really like but thought they wouldn't be so attractive on rosewood.
PostPosted: Tue Feb 05, 2019 3:24 pm
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
I have used tru oil on Cocobolo, Mad RW, and EI RW - no issues at all. I make sure to seal with shellac first, then apply the tru oil. Works for me.
Note, I didn't use tru oil for the pore fill however. I have used Z-Poxy and Acqua coat, with good results.
Glenn
PostPosted: Tue Feb 05, 2019 3:25 pm
Country: Ireland
Ok great. I'll try that. Thanks.
PostPosted: Tue Feb 05, 2019 3:57 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I'll offer up a vote for a traditional shellac/pumice/sanding dust pore fill. I won't go into the aspects of it that can be challenging; you can look those up for yourself. But once you do it right, the result is great. And if you use Everclear for the alcohol (as opposed to denatured alcohol), it is nontoxic. I try to keep my exposure to things like epoxy and superglue to a minimum.
PostPosted: Tue Feb 05, 2019 4:49 pm
Last Name: Beaver
City: Lake Forest
For me the best overall pore fill is Epoxy. I have been using System Three Clear Coat of late. but....
when I finish with Royal-Lac Post Catalyzed I use CA. That is because Royal-Lac Post Catalyzed is not considered compatible with epoxy by the manufacturer.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Feb 05, 2019 6:56 pm
I used a barrier of seal-Lac over epoxy and the pc RL and it worked fine...
PostPosted: Tue Feb 05, 2019 6:59 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Epoxy is by far the most attainable for the home builder. Once u get the technique down, it produces excellent results. But you have to get that technique!. Zpoxy is a favorite for three reasons: its super easy (and forgiving) to mix. Its inexpensive. The amber color really pops the wood grain. There are many other finish epoxies. Most use them for their water white color, etc. But they can be more finicky on mix. Make sure you ask a lot of process questions before you dive in. Also know this: many people are allergic to epoxy, and the reaction gets worse with repeated exposure. Wear nitril gloves. Have plenty of DNA around for cleaning. I let others chime in on the technique
PostPosted: Tue Feb 05, 2019 7:03 pm
I still prefer oil-based paste wood pore filler. Call me old fashioned.
These users thanked the author Barry Daniels for the post: cphanna (Tue Feb 05, 2019 10:51 pm)
PostPosted: Tue Feb 05, 2019 7:05 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
My technique: Surface is perfectly sanded to 220. Top is protected with carpet film. Spray body with Prestech 58/1, 58/2, then apply epoxy using an 6" ettore squeegee. Cross grain. Along grain. Next day, scuff sand, scrape drips and ridges. Apply again. Same way. Third day, scrape sand sand back to smooth. Don't worry about areas that open up to wood, just don't oversand there. Apply a diluted washcoat of epoxy (DNA). Wipe. Next day scuff sand, Prestech 58/1, 58/2 (on whole body top and all), 30 minutes later you are ready to spray topcoats.
Except for prestech, I bet many here do very similar
PostPosted: Tue Feb 05, 2019 7:06 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
OK. Your old fashioned. pfft
PostPosted: Tue Feb 05, 2019 7:29 pm
I tried epoxy once and swore I'd never do it again. Funny how this stuff works well for some and not for others. In any case, as in traditional pore filling I always sand back to wood. There was another thread about that. I know epoxy works well for many people but it would not work well for me and my customers who think that slathering epoxy all over a guitar and calling it a finish is acceptable ;) I know I know I know... Big can of worms, I'm just saying. I'd probably convince myself that it was okay to use if I didn't have such a nasty time with it.
But Hey I'll slather CA all over my guitar and call it a pore fill ;) But again, I sand back to wood. I've been really liking CA as a pore fill lately.
I also really like using egg whites. Not only is it a surprisingly great way to fill pores but again certain clientele like it.
PostPosted: Tue Feb 05, 2019 8:20 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
No question that epoxy is a mess to work with. I totally underestimated the effort. It almost caused me to quit it. I think anybody attempting this needs to understand a first attempt will likely be a failure. Sand it back, use an epoxy stripper (good luck finding that these days) and try again. there is nothing about this that is easy peazy first time out.
PostPosted: Tue Feb 05, 2019 8:58 pm
Online
First name: Brad
Last Name: Combs
Mike, are you scuff sanding the adhesion promoter before spraying finish on it? You have to with UV cured, not sure about others.
Also, FWIW, I'm really enjoying working with the UV cure porefill gel. Very easy to apply and levels nicely.
PostPosted: Tue Feb 05, 2019 10:43 pm
Last Name: Beaver
City: Lake Forest
I hear you, I tried it on a test panel over epoxy and it seemed to work fine. I looked into it pretty well and found people that said their finish started to haze up after a year or more. The seller of RL has said it is not compatible with epoxy. So, even with a successful test panel one year post, I have decided to not take the chance.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Feb 05, 2019 10:56 pm
First name: Patrick
Last Name: Hanna
State: Missouri
I am in complete agreement. A few readers will insist that it gives a "muddy" appearance. This indicates one of two possibilities to me: First, they were careless about wiping off the surplus from the surface of the wood, or, Second, they are parroting what they have read elsewhere. I will flat guarantee that oil-based wood pore filler is no more work (and probably less work) than epoxy. And if you tone the filler with a bit of color, it can be spectacular.
Here, for example, is a crotch grain walnut head plate on a tenor banjo. It was finished with oil-based paste wood filler toned with walnut oil stain and a little bit of artist's oil paint in cadmium red. My favorite combination for anything walnut, but especially for showy walnut figure.
PostPosted: Tue Feb 05, 2019 11:16 pm
First name: Jay
City: Bothell
State: Washington
I'm sorry, but I have to disagree with this just so that anyone considering using epoxy for the first time doesn't get totally spooked. I don't find it a mess to work with at all and it worked great for me on the first try. It mixes easily, it applies nicely with the squeegee-like device of your choice (or a gloved finger for the neck), it takes very little of it to cover the back, sides, and neck, it has a good working time, and it sands and scrapes very nicely.
I'm wondering why an epoxy stripper would be needed to remove it?
In another thread, you said that you use sealer/adhesion promoter beneath z-poxy to minimize wood oil flow. I haven't used cocobolo yet, but I haven't seen problems with with z-poxy and Indian rosewood, bubinga, or ziricote which are oily woods (the clogging of my drum sander sandpaper confirms that). Have you seen wood oils get through z-poxy?
I'm also wondering why you use adhesion promoter underneath the finish. Target Coatings says this about their water borne lacquers:
"I cannot stress enough that you DO NOT want to be too aggressive with the grit size of the sandpaper being used. Aggressive grits can leave deep scratches that can telegraph up through the new finish, so for surfaces that only need a light scuff sanding I recommend 400-grit aluminum oxide sandpaper as the ‘go to’ grit. Some grades of 320-grit are OK, but do not go any more aggressive then that. Water-based/waterborne coats have very good adhesion qualities, so you are not sanding to create “tooth or bonding” scratch – you are sanding to level the surface to to create a micro-scratch for the new finish to bite into."
My method is to apply 2-3 coats of z-poxy to the bare wood with level sanding back between coats, level sand the last coat (to bare wood or not, either works), apply a wash coat (no scuffing afterwards), apply UltraSeal-WB Shellac Sealer coats, and then EM6000 water borne lacquer coats. I started using this method three and a half years ago and have had no problems with adhesion or anything else. Am I missing something about finish adhesion?
These users thanked the author J De Rocher for the post: Pmaj7 (Wed Feb 06, 2019 6:14 am)
