It is currently Sun May 11, 2025 10:38 am
 Post subject: Fret saws
PostPosted: Fri Jan 25, 2019 2:18 pm
First name: Nathan
Last Name: Peirson
For those of you that still cut fret slots by hand, what are, or is, your favorite fret saw?
I will need to pick one up here soon.
Thanks all.
 Post subject: Re: Fret saws
PostPosted: Fri Jan 25, 2019 2:39 pm
The last one I used was Lee Valley 'Gents' saw that I ran over a diamond sharpening plate to reduce the kerf.
Brebt
PostPosted: Fri Jan 25, 2019 3:38 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Do you have a table saw?
PostPosted: Fri Jan 25, 2019 3:46 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
StewMac Japanese saw:
https://www.stewmac.com/Luthier_Tools/T ... t_Saw.html
PostPosted: Fri Jan 25, 2019 4:01 pm
Last Name: Sollod
www.swiftcreekguitars.com
PostPosted: Fri Jan 25, 2019 4:17 pm
Last Name: Kincheloe
Can the Japanese saw be resharpened?
I have this one https://www.stewmac.com/Luthier_Tools/Types_of_Tools/Saws/Fret_Saw.html
It was dull when new, but it's easy to resharpen with a couple strokes of a needle file on each tooth, so it ought to last forever.
The miter box is overpriced IMO. I just use a wood block that's squared up on one side, and gently hold the saw against it while cutting. Also works for fan frets, which can't be done with a miter box.
PostPosted: Fri Jan 25, 2019 4:31 pm
Last Name: Miller
City: Wood Dale
State: Illinois
I bought mine from LMI and it cut beautifully in both African Black Wood and Granadillo. Two guitars and one ukulele.
PostPosted: Fri Jan 25, 2019 4:35 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have the stewmac version. But it gets really old. Hard on elbows, shoulders, etc if u do more than a few
PostPosted: Fri Jan 25, 2019 4:50 pm
Have you ever sharpened it? As said in my post a few minutes ago, mine was dull when new, but cuts smoothly now.
PostPosted: Sat Jan 26, 2019 2:54 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Frankly, I did not know you could get a hand saw like that sharpened. It always bothered me that little brass shavings would be removed from the saw where the back ridge contacted the bearings. I finally just bought the table saw fret blade. Gets a board done in minutes. I had to build a sled. Works great.
PostPosted: Sat Jan 26, 2019 2:58 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Rodger Knox wrote:
+1 if you are hand cutting. Forget re-sharpening at that price I'd just buy a new one.
PostPosted: Sat Jan 26, 2019 6:23 pm
fingerstyle1978 wrote:
Agreed.
Assuming it's impulse-hardened, as the crosscut teeth on Japanese saws in this price range almost always are, it will last for a very long time. If you really want to resharpen it, it can be done with a diamond file.
I have some (by Gyokucho, mainly) that have seen a lot of use and some abuse, and still cut well.
These users thanked the author Carey for the post: Pmaj7 (Sun Jan 27, 2019 12:25 am)
PostPosted: Sat Jan 26, 2019 9:32 pm
Last Name: Howell
City: Atlanta
State: Ga
I have used this saw for several years and I think it might be dull. Where did you learn to sharpen it. I tried on cheap saws and could never get it right .
Scared to mess this one up.
PostPosted: Sat Jan 26, 2019 10:31 pm
Hmm, maybe being nearsighted helps. I just went at it and it worked. Look at the angle of the tooth, hold the file at about the same angle, give it a few strokes until the tip of the tooth has been touched, and on to the next one.
Use magnification if necessary.
These users thanked the author DennisK for the post: Pmaj7 (Sun Jan 27, 2019 12:28 am)
PostPosted: Wed Jan 30, 2019 12:15 pm
First name: Nathan
Last Name: Peirson
These replies have been great and I thank all of you that took the time.
Another related question is, what type of saw guide do you use if any? I am not flush enough to buy the SM or LMI guide at this point.
PostPosted: Wed Jan 30, 2019 12:33 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
When I used to cut the slots by hand, my set-up was really basic but worked fine. I would print out my fret locations using Wfret. After verifying they scaled properly, I would tape the template to my fret board blank with one squared/straight edge. To cut the slots, I just stabbed my marking knife into the line, slid a square (referenced off the straight side) up to the knife blade and clamped it in place. Then I would saw along the blade of the square using it as a saw guide.
Obviously, this put the kerf a small distance away from the printed line but by doing the exact same procedure for each slot, they are all positioned correctly relative to each other.
After a while, I broke down and bought the table saw blade. I had to buy a table saw on craigslist too. This is the only operation I use the table saw for. Generally, I like to use hand tools whenever possible. Despite this, it was still worth it. Cutting them by hand was annoying. It would probably not be as bad with a proper fretting miter box but I decided to put those funds toward the table saw method. I still smile every time I pull the table saw out and finish a board effortlessly.
Bryan Bear PMoMC
PostPosted: Wed Jan 30, 2019 7:36 pm
I made a crude table saw using a direct drive table saw motor and a 3 inch Makita saw blade. The depth of cut is adjusted by loosening a couple of screws and shimming one end of the table. The sliding fence has a fiducial mark to index the blade and fret marks on the board.
I have used the Stew Mac back saw for cutting frets by hand and it works O.K. and is about as cheap as most small back saws with a similar kerf.
PostPosted: Thu Jan 31, 2019 12:22 pm
I think I have an older LMI German made saw, it has a depth stop on it which is really nice. Sharpening is key with these saws. If you feel like you have to bear down at all to get a cut then it needs to be sharpened. It's been my experience that you don't need to have all the specialty tools to sharpen it good enough. After so many quick sharpenings then you might want to get the tooth setting tool and so on. But with just a fine triangle file that fits in the small teeth and a sharpening stone you can freshen it up after so many fret jobs.
I have one of those Japanese pull saws like the Stewmac one above but I don't think you can sharpen those though. If you can I'd love to know how. They are razor sharp though and cut like butter. The only thing about those is if for example, like I did, you make a cut on a piece of wood held in a vice or something then when you cut through you 'trow' the saw down and hit something then you ruin it. The teeth break off very easily. So be very careful finishing cuts with those saws or make sure there is only airspace under your final cut. You can buy new blades for those I believe though.
PostPosted: Thu Jan 31, 2019 3:52 pm
First name: Brad
Last Name: Combs
This has been an educational thread for me. I would have never thought that one of the saws from SM or LMI would need to be sharpened out of the box. However, given my experience hand cutting slots (just one guitar worth) I think the saw I had must have needed a sharpening. I remember getting to the 14th fret, sweaty, almost panting, and saying to myself - how does anyone do this on a regular basis!
Like Mike, there was little brass shavings everywhere. Well not that bad, but still.
I bought one of the slitting blades and didn’t look back. :)
Side note - I still have one of the LMI slotting setups if anyone wants to trade for something useful. ;)
PostPosted: Thu Jan 31, 2019 5:49 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I'm sure its a slow process, but those brass shavings mean the saw spine is being worn down, and almost certainly creating a curve. When u say slitting blade, Iam assuming u means the table saw blade? That thing is worth it!
First name: Brad
Last Name: Combs
Yes indeed. Worth every penny. :)
PostPosted: Thu Jan 31, 2019 7:57 pm
Last Name: Howell
City: Atlanta
State: Ga
I have been using the Stew Mc saw with a metal square as a guide. I think That's why it is getting dull. Re thinking my technique, like a strip of wood next to blade.
That homemade table is a jewel. I'm going to look for a motor.
PostPosted: Thu Jan 31, 2019 8:16 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Try a block of wood an inch tall instead of a strip, that way the flat blade will always register against the flat block. If the saw is more than about 13 ppi (13 points per inch) it will be very difficult to set (bend the teeth side to side for kerf width), and you will have to alter a standard saw set for the little teeth.
Every time you sharpen you make the fret slot a little narrower.
Ed
PostPosted: Thu Jan 31, 2019 9:16 pm
Ed
Yep. Here's my trusty wood block cutting some fan frets:
I also use it as a general purpose clamping caul (it has cork on the side that's against the fingerboard, which also helps keep it from sliding around when putting the clamp on), and for sharpening scrapers. First to push the scraper down against a fine diamond stone:
Then as a fence to hold the scraper against while sliding it back and forth to square up the edge:
And then when burnishing:
These users thanked the author DennisK for the post: Pmaj7 (Sun Mar 22, 2020 9:55 pm)
PostPosted: Thu Jan 31, 2019 9:18 pm
" If the saw is more than about 13 ppi (13 points per inch) it will be very difficult to set (bend the teeth side to side for kerf width), and you will have to alter a standard saw set for the little teeth. "
I've read - but haven't tried - that some people set small groups of teeth (2 or3) rather than alternating every other one on high PPI saws.
Users browsing this forum: Glen H and 41 guests
