It is currently Fri Jul 18, 2025 11:22 am
 Post subject: CA glue recommendation ?
PostPosted: Mon Jan 07, 2019 8:37 am
I am looking around for CA glue and all that is available locally is Loctite and Gorilla ( Big Box Store ) stuff. I’m not opposed to ordering from amazon or eBay if needed, but would like to get some recommendations from those of you with experience in using. Which CA glue do you use, thin,medium, and do you also use accelerator?
PostPosted: Mon Jan 07, 2019 8:41 am
First name: Brad
Last Name: Combs
Accelerator or not depends on what you are using it for.
If you have a woodcraft or rockler nearby you can try a couple different brands. I use Stick Fast, Titebond and Satellite City all with about the same results in the thin, but I like the Titebond for gel.
If you are using it for finish repair, GluBoost is good, I have that but haven't used it much yet.
I don't have any experience with CA pore fill, some others will probably chime in though.
PostPosted: Mon Jan 07, 2019 8:49 am
Last Name: Colbert
City: Anacortes
There’s Gluboost.
They also sponsor the OLF. I just purchases a range of products from them and my only complaint was how long it took to get here. Before that I was using Hot stuff from satellite city which is very stinky (they also make a low odor version) but I can get it locally. I like to use a thin for bindings and inlay, and medium for holding parts on my cnc. I use the aerosol accelerator.
These users thanked the author Michaeldc for the post: pkdz (Wed Jan 16, 2019 8:28 pm)
PostPosted: Mon Jan 07, 2019 8:50 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
The Loctite stuff I found very disappointing. I use Bob Smith Industries CA.
Brian
These users thanked the author B. Howard for the post: Michaeldc (Mon Jan 07, 2019 8:52 am)
PostPosted: Mon Jan 07, 2019 9:29 am
Lately I've been using either Starbond or what ever Stewmac sells. I will say though that I've never had a problem with Loctite and for years it was all I ever used.
PostPosted: Mon Jan 07, 2019 9:38 am
I've used StewMac CA for a long time but for the water thin and regular CA I've been using the GluBoost products for several years now. I like the way their CA glues work with their accelerator for bindings, finish repair and inlays.
PostPosted: Mon Jan 07, 2019 9:40 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
If you have a local hobby shop they usually have the Smith CA sometimes with their own brand label instead of Smith.
Fred
Fred Tellier
PostPosted: Mon Jan 07, 2019 10:02 am
First name: Larry
Last Name: Hawes
+1
This is a large bottle I use to re-fill my smaller bottles. Been using a long time with no complaints but nothing much to compare it to other than Gorilla and Loctite from the local Lowes which has been almost worthless.
https://www.amazon.com/gp/product/B001N ... UTF8&psc=1
With their pump spray accelerator, WAY more efficient than the aerosols. They also sell a large bottle of accelerator to re-fill the smaller.
https://www.amazon.com/dp/B0166FFCCS/re ... ng_options
https://www.amazon.com/dp/B00111V9NO/re ... 73576&sr=3
Thank You and Best To All
PostPosted: Mon Jan 07, 2019 11:33 am
The very best CA that I have found is from Satellite City. I've been using their thin Hot Stuff and medium CA since the mid 70's. They also have several accelerator and debonding products.
https://www.caglue.com/
Jim Womack
Will Rogers
PostPosted: Mon Jan 07, 2019 3:59 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
GluBoost thin or medium for most things, as the kick is not nearly as fast when padded on, although when we need really low viscosity glue, the BSI thin gets used. For finish repair or other work on poly finishes, the GluBoost fill & finish thin and medium are excellent. I've used both Hot Stuff and Zap in previous craft related endeavors, and used to use the Mercury brand when I first started here, but the GluBoost/BSI lines seem to have taken the place of any other brands.
We've had several containers of LocTite gel in the shop - short shelf life and extremely poor performance...to the point where we use BSI or GluBoost medium for K&K installs. Awful stuff.
- Beth Brower
PostPosted: Mon Jan 07, 2019 5:56 pm
Last Name: Shanklin
City: Windsor
State: ON
Bob Smith, thin, medium, and thick, and Smith accelerator and remover. I get them at a local hobby shop. Lee Valley is selling Hot
Stuff, so I might pick some up the next time I'm in their store and try it out.
Bob
PostPosted: Mon Jan 07, 2019 6:29 pm
I have had good luck with Bob Smith, Glu Boost and Star Bond.
Star Bond has free shipping from their website and with each bottle they include an extra bottle cap and several whip tips so the price is very good.
Glu Boost has the best accelerator if you can’t have it foam, though I use other brands of accelerator for less visible spots. Just watch out since some have acetone (Starbond) and can harm nitro, while others don’t
Kent
These users thanked the author kjaffrey for the post: Pmaj7 (Mon Jan 07, 2019 10:28 pm)
PostPosted: Tue Jan 08, 2019 2:14 pm
First name: David
City: Napa
Zip/Postal Code: 94558
The Stewmac CA glue is actually Starboard fyi. I use the Starboard, its pretty cheap when bought in bulk directly, but sometimes if I really need small amount of a certain viscosity I check Amazon for the Starbond.
PostPosted: Tue Jan 08, 2019 3:20 pm
Bob Smith Industries thin & medium. Can usually find 2oz pretty cheap on Amazon with free shipping. I tried some of the odorless which was nice, but it was a little annoying because it takes longer to kick.
I like the aerosol accelerator for larger applications but most of the time I use the pump bottle because I just unscrew it and put one or two drops on from the bottom of the tube.
A while back I started having bad reactions to ca. Couldn't breathe through my nose for a couple days and thought I might never be able to use it again. Since then, I've found if I keep even a small fan on when I'm using more than a drop, it's ok.
New username, same Pat Mac
PostPosted: Tue Jan 08, 2019 4:59 pm
First name: Larry
Last Name: Hawes
I use a respirator. OK with just the CA but the accelerator messes up my nose for a couple days.
These users thanked the author LarryH for the post: Pmaj7 (Tue Jan 08, 2019 5:14 pm)
PostPosted: Tue Jan 08, 2019 5:00 pm
Stew mac is Starbond
Put me down for Gluboost
best CA for guitar work
the accelerator won't harm a finish
PostPosted: Tue Jan 08, 2019 5:10 pm
First name: Ernest
Last Name: Kleinman
City: Guthrie
Zip/Postal Code: 73044
we use 2p-10 thick med and thin mostly without accelerator. From a local hardwood retail store
PostPosted: Wed Jan 09, 2019 9:24 am
First name: Willard
Last Name: Guthrie
City: Cumberland
As long as the recommended light mist is applied, which simply requires a little modulated pressure on the applicator button, GluBoost is safe on any finish we've used it on, and avoids all the issues we see with other CA accelerants.
If applied close to the work and unthrottled (i.e., applied so heavily that the spray pools on the surface), it WILL dull the surface of standard instrument lacquers, and will require some buffing to clear. Because of the cost of GluBoost, dumping a bunch of it on a repair or finish touchup is a) not necessary, and b) expensive.
- Beth Brower
PostPosted: Wed Jan 09, 2019 10:58 am
In UK, I've recently found and used this non-whitening CA accelerator https://shop-4-glue.com/cyano-accelerator-cyanoacrylate-activator-kicker-spray-ca-super-glue-adhesive-non-whitening-100ml-27-p.asp
Seems quite good.
Company is in UK, but production and dispatch is from Bulgaria so takes 5-7 days to get here, but saves about 50% on cost.
PostPosted: Wed Jan 09, 2019 2:32 pm
Country: Ireland
Seems quite good.
Hey Colin,
Do you use their glue as well?
Thanks.
PostPosted: Wed Jan 09, 2019 3:39 pm
mike-p wrote:
Seems quite good.
Hey Colin,
Thanks.
Not tried it, I'm using Poundland CA, mainly for jigs/cauls etc.
It seems popular with modellers in UK, they do stalls at a lot of the shows.
Users browsing this forum: ChuckB and 14 guests
