It is currently Fri Jul 18, 2025 6:58 pm
PostPosted: Wed Jan 02, 2019 1:56 pm
So, I’m building 10 or 11... I don’t know, and I’m to the point that I’ve planes down the bindings enough so that they are close enough to the top to use a scraper, I’m afraid of gouging with a plane edge...
One issue I’ve ALWAYS had is how to HOLD the body securely as I do this a troji solved the issue for holding it on end, but I still hadn’t figured it out (I can be dense) as far as the top and back go.
Well.... I use a radius dish. To use the dish I have a pipe in the middle of a plywood sheet that I can move around easily . It just clamps to the table. On each of my molds I have holes drilled in the corners and on the plywood so I can insert dowels and hold things still while I radius.
Duh... just put the body back in the mold and tack it down to the plywood sheet...
done
Why do the simple solutions escape me for so long haha.
Anyway. I hope this helps another noob out:)
Peace
PostPosted: Wed Jan 02, 2019 8:59 pm
First name: Larry
Last Name: Hawes
Sounds interesting, do you have any pictures you might post?
Thank You and Best To All
PostPosted: Wed Jan 02, 2019 9:15 pm
Here ya go. Build one of these holders and a guitar vise with pipe clamps, threaded base plates, and cork lined 1/4” plywood. Easy to do and it will simply your life enormously, especially scraping bindings.
PostPosted: Wed Jan 02, 2019 10:42 pm
Well I could take one but it says profile missing and I can’t take pics:(
PostPosted: Thu Jan 03, 2019 12:55 pm
SnowManSnow are you signed in? I can see your profile OK
PostPosted: Thu Jan 03, 2019 12:57 pm
Pretty much same idea as what I use, simple and works well.
PostPosted: Thu Jan 03, 2019 3:04 pm
First name: George
City: Seattle
Yeah, like that.
George :-)
PostPosted: Thu Jan 03, 2019 3:19 pm
First name: Larry
Last Name: Hawes
Yeah got that too, little different form, but a couple of must haves IMO.
Users browsing this forum: oval soundhole and 18 guests
