It is currently Fri Sep 19, 2025 12:57 pm
PostPosted: Wed Dec 19, 2018 11:27 am
First name: Brad
Last Name: Combs
Hello,
Has anyone put together an effective setup for dust collection while running your binding jig or neck angle jig? For both of these operations I just let stuff go where it wants and vacuum up later. I wear a dust mask during. I've tried various hood things, but it was really a waste of time. I'm considering just building a box to at least contain it a little, like I have for the miter saw, and let the dust and chips fly and then vacuum after.
Anyone come up with an interesting setup? Pics are appreciated.
Thanks!
Brad
PostPosted: Wed Dec 19, 2018 12:04 pm
Nope.
These users thanked the author SteveSmith for the post: bcombs510 (Wed Dec 19, 2018 12:07 pm)
PostPosted: Wed Dec 19, 2018 12:29 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Nope, here too. I let the chips fall where they may.
These users thanked the author J De Rocher for the post: bcombs510 (Wed Dec 19, 2018 1:51 pm)
PostPosted: Wed Dec 19, 2018 12:36 pm
First name: Tom
Last Name: Rein
City: Saline
If remotely possible I carry out these operations outside.
Stay with the happy people.
--Reynolds Large
These users thanked the author TRein for the post: bcombs510 (Wed Dec 19, 2018 1:51 pm)
PostPosted: Wed Dec 19, 2018 12:52 pm
Last Name: Colbert
City: Anacortes
Yes,
My binding station has a 4" port with a gate (bottom left). It's super simple and collects 95% of the dust. I just have to touch up the countertop with my shop-vac after.
My neck block and heel block are cut on my cnc which also has collection.
Cheers, M
These users thanked the author Michaeldc for the post (total 2): Pmaj7 (Thu Dec 20, 2018 9:20 pm) • bcombs510 (Wed Dec 19, 2018 1:51 pm)
PostPosted: Wed Dec 19, 2018 3:57 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
I don't have a problem collecting the dust and chips when using my neck jig.
Tony Thatcher
Bozeman, Montana
These users thanked the author mountain whimsy for the post (total 3): Pmaj7 (Thu Dec 20, 2018 9:20 pm) • bcombs510 (Wed Dec 19, 2018 8:31 pm) • Michaeldc (Wed Dec 19, 2018 4:22 pm)
PostPosted: Thu Dec 20, 2018 6:19 pm
First name: Aaron
I use the dust collection attachment on my DeWalt compact.
These users thanked the author Aaron O for the post: bcombs510 (Fri Dec 21, 2018 9:58 pm)
PostPosted: Thu Dec 20, 2018 9:22 pm
How does that do?
New username, same Pat Mac
PostPosted: Thu Dec 20, 2018 9:34 pm
The mess from binding routing is child’s play compared with shaping archtop plates. I have not been very successful with attempts at dust collection for either.
PostPosted: Thu Dec 20, 2018 9:53 pm
In one of the builder's videos that I've seen, might be Greenfield, he had a 4 or 6" DC Inlet positioned right next to his work. It looked like either that or the workpiece could be roughly moved to Optimum position on the right side, as he was using a Fleischmann style jig. Seems like if you we're moving a big enough volume of air, it could be fairly effective. You would probably need to route a little slower, but it would be worth it if you could get most of the Dust
These users thanked the author Pmaj7 for the post: bcombs510 (Thu Dec 20, 2018 10:16 pm)
PostPosted: Fri Dec 21, 2018 4:05 am
First name: Aaron
Pmaj7 wrote:
How does that do?
Actually very well on the binding jig, which is a mix of a parallelogram and vertical slide style. It fits on the solid base.
Since I use a plunge base for the m&t neck jig, I just ran a piece of ply about 4” “deep” down the front edge of the neck/tenon side. The dust falls down instead of out. Then I just put a screw clamp on that piece of ply, and rested a dc hose on it, pointed at the cutting area. That took care of most of the falling chips. Just very simple.
Edit: I know, pics help.
Self explanatory on this. I also lay a 4” flex dc hose on the table, just for the extras that fly out.
Here’s the ply, with the clamp on the side. A 2 1/2” dc hose is layed on the clamp, pointed towards the cutter.
These users thanked the author Aaron O for the post: Pmaj7 (Fri Dec 21, 2018 4:23 am)
PostPosted: Fri Dec 21, 2018 9:26 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have an old bedsheet stapled to the overhead floor joist in my basement shop. It reaches my bench top and forms 3/4 circle around one end of my bench and I rout inside of it. It collects 3/4+ of the stuff right there for easy disposal. When I am done, I roll it like a sausage and put a spring clamp on it to hold against the ceiling.
Ed
These users thanked the author Ruby50 for the post (total 2): Pmaj7 (Sat Dec 22, 2018 2:43 am) • bcombs510 (Fri Dec 21, 2018 9:58 pm)
PostPosted: Sat Dec 22, 2018 10:00 am
Last Name: Sollod
I haven't tried it but, a down draft table might help...
www.swiftcreekguitars.com
Users browsing this forum: Melt in the Sun and 32 guests
