It is currently Sat Sep 20, 2025 11:28 am
 Post subject: Ukulele binding jig?
PostPosted: Thu Dec 13, 2018 1:45 pm
Last Name: Schaefer
City: Atlanta
State: Ge
Zip/Postal Code: 30310
I was thinking of picking up one of LMIs Binding Machines and the binding machine carrier. I called and they said the binding machine carrier will not scale down to fit a Ukulele. Does anyone of a binding jig made for a Ukulele?
 Post subject: Re: Ukulele binding jig?
PostPosted: Thu Dec 13, 2018 3:19 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
I only use the StewMac binding router bits with bearings in my Makita laminate trimmer. No jigs, holders etc. Over 300 ukes now and can't imagine needing anything more complicated.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Thu Dec 13, 2018 7:29 pm
I'm not sure how the LMI works, but I have a Blues Creek jig and carriage. It allows me to flip the foam piece around and it works great for ukulele. You can't go wrong with Blues Creek!Image
New username, same ole Pat Mac
PostPosted: Thu Dec 13, 2018 7:45 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
I use LMIs jig and made my own cradle for ukuleles and it works fine for me.
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Thu Dec 13, 2018 9:52 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I got one of these $35 binding jigs from Ken Cierpowski (no longer in business I think). I have used it with success on 7 guitars, but on the only uke I built I was able to clamp it in the vice and pass the body over it. Very simple, quick, effective, and almost foolproof.
PostPosted: Fri Dec 14, 2018 10:26 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
You need a closely sized cradle for any of the tower binding systems or the cradle will bump into the tower. I drilled some ukulele holes in my cradle and installed brass inserts; a very easy modification. but I use a Fleischmann binding system that reaches over the cradle.
PostPosted: Sat Dec 15, 2018 1:06 am
I hadn't thought about that, but yes I use a Fleischman style also.
PostPosted: Sat Dec 15, 2018 4:26 pm
Last Name: Schaefer
City: Atlanta
State: Ge
I love this forum!!!
I have used a router with binding router bits and bearings to cut slots on a guitar and it worked fine, but the Ukulele has a slight curve to the back. I am afraid the binding slot will not be cut straight. Am I over thinking this?
PostPosted: Sat Dec 15, 2018 4:30 pm
Last Name: Schaefer
City: Atlanta
State: Ge
I think I posted this on the wrong response and now I can't see how to delete it
That looks sweet
Are those blocks of wood with rubber around them? Where did you get the rubber
PostPosted: Sun Dec 16, 2018 4:25 pm
First name: Aaron
Made my own, too easy. Both the jig and the cradle.
See post #13. It’s since been updated with a DeWalt DW611 and a Zero-bar style bearing foot (made that too).
https://forum.ukuleleunderground.com/sh ... -box/page2
Note, the cradle is set for one size, but it can easily be made adjustable. Most guys I know that use a binding jig for ukulele have an LMI or SMD. Haven’t seen anyone around me with a parallelogram.
PostPosted: Sun Dec 16, 2018 8:15 pm
That looks sweet
Assuming you were responding to my pic, that's what came from Blue's Creek. They are just plywood squares with like some weather stripping around the edges. Works great!
PostPosted: Mon Dec 17, 2018 11:03 pm
Yes, he is definitely no longer in business. Sadly, he won't be posting anymore here either and is greatly missed.
New username, same Pat Mac
