It is currently Thu Sep 18, 2025 1:47 am
PostPosted: Mon Sep 17, 2018 11:48 am
Last Name: Sollod
I build steel strings rather than classical style. I have some mahogany that I could use for back braces, but from a sound perspective should I stick with spruce?
www.swiftcreekguitars.com
PostPosted: Mon Sep 17, 2018 11:54 am
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
Can't tell much, if any difference. If you want to alter the tap tone of the back, change the height of the braces.
PostPosted: Mon Sep 17, 2018 4:44 pm
Spruce would be stiffer for the weight, but for back braces sometimes you need weight more than you need stiffness. I usually use spruce, but more of them and low wide ones in the lower bout.
PostPosted: Tue Sep 18, 2018 7:51 am
I've used walnut, mahogany, cherry and even oak. I tend to prefer spruce now just because it's light and strong but like JA said you can adjust the stiffness accordingly by reducing and or adding height.
PostPosted: Tue Sep 18, 2018 12:44 pm
What Clay said.
Cherry is a pretty good substitute for mahogany, as is walnut.
PostPosted: Tue Sep 18, 2018 2:43 pm
Last Name: Sollod
Okay - What I'm hearing is that mahogany, cherry, or walnut can be used for back braces. Spruce is lighter, but that may not matter much. "...you need weight more than you need stiffness". I'm not sure I get this... Does anyone want to discuss this some more? Clay? Alan?
PostPosted: Tue Sep 18, 2018 3:01 pm
don't rule out Poplar and Catalpa
PostPosted: Tue Sep 18, 2018 8:26 pm
There are two ways to lower the pitch of the "plate". One is to reduce stiffness and the other is to increase mass. Mahogany is less stiff and heavier than an equally dimensioned piece of spruce, so it should do both. The shape and orientation of the braces can also have a great effect on the outcome, just as it does for the soundboard braces.
Some people tune the back to fall within a range of tones to the top, so sometimes a less stiff heavier brace will help (low ,wide mahogany) or a stiffer lighter brace might be called for (tall, narrow spruce) This is more important when building an "active" back.
As I mentioned I tend to use a combination of tall narrow and low wide spruce back braces and more of them (5 on a "parlor" size guitar). There is more than one way to skin a cat (non-live back) and spruce is what I usually have on hand.
These users thanked the author Clay S. for the post: Rodger Knox (Thu Sep 20, 2018 1:42 pm)
PostPosted: Wed Sep 19, 2018 4:47 pm
Another way to think of it is that the top is the part that is directly driven by the strings. Everything else gets the energy to vibrate from the top. In the very low 'bass reflex' range the back can actually improve the output of the guitar if it can work together with the top; that is, if it's not too stiff, so that it has a resonance that is not too far above the 'main top' resonance. Above that range (which is near the open G pitch on most guitars) the top will be far more effective at turning string energy into sound, so making the back or sides too loose will cost power. It's not all bad: this is where a lot of the 'tone color' of the guitar seems to come from. So what you want to do, IMO, is to get the back to be 'active' in the bass reflex range, to improve the low end power, and then have it be a 'reflector' for the most part above that. You can't avoid having resonances in the back that cost power, but by keeping the activity level down and the band widths of those resonances small (it's only costing energy when it's moving) you limit the cost. You keep the activity down by using a heavy, stiff back, and the band widths depend mostly on the loss in the system. That's why a dense, stiff, low loss wood like Brazilian rosewood works so well for backs. Light weight in the top is helpful, as it means more sound for a given amount of power, but the back has a different job.
These users thanked the author Alan Carruth for the post (total 4): Pmaj7 (Thu Sep 27, 2018 11:57 am) • TimAllen (Fri Sep 21, 2018 11:53 am) • Rodger Knox (Thu Sep 20, 2018 1:42 pm) • Bri (Wed Sep 19, 2018 7:42 pm)
PostPosted: Fri Sep 21, 2018 11:09 am
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
how thick do you leave your backs?
Mike Collins
PostPosted: Mon Sep 24, 2018 6:03 pm
I generally make backs about 2.5mm thick (.1"), with some variation depending on how dense and stiff the wood is, and the size of the box.
PostPosted: Tue Sep 25, 2018 3:27 am
Online
At least I have one thing in common with Mr Carruth. bliss laughing6-hehe
Users browsing this forum: Colin North and 31 guests
