It is currently Thu Sep 18, 2025 11:26 am
 Post subject: Polyurethane
PostPosted: Mon Jun 11, 2018 9:15 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
Zip/Postal Code: 96760
Just curious if anyone has had success with using commonly available polyurethane/catalyzed poly from industrial suppliers like Sherwin Williams, or automotive suppliers, or others as opposed to companies that sell specialized instrument finish material. Not trying to get cheaper finish, it's just that here in Hawaii it is impossible, or extremely expensive due to Hazmat shipping to get any of the cool specialized stuff that is available on the Mainland. Having sprayed nitro for 40 years on my acoustic instruments, I am now looking for a different finish that I can use on some lap steels. A faster curing, slightly harder, faster pore filling, finish than nitro. Lap steels are somewhat of a lower end instrument dollar wise, and although I enjoy making them, I can't reasonably put the time into them doing the nitro finishes I normally do. I do like a filled pore finish, so I don't care for the various oil finishes even though they can be fast and easy. Just shopping for ideas. Thanks, Bob
“ The meaning of life is to find your gift and the purpose of life is to give it away” Pablo Picasso
 Post subject: Re: Polyurethane
PostPosted: Tue Jun 12, 2018 5:33 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I have used PPG DCU 2021 Concept clear for years with good results.
Brian
PostPosted: Tue Jun 12, 2018 7:52 am
Maybe try an oil based floor varnish? if you can still get them. A lot of it is going over to low VOC's. Keep the finish thin and I'm pretty sure it will be OK.
PostPosted: Tue Jun 12, 2018 10:20 am
Last Name: Gleason
City: Kurtistown
State: Hawaii
Thanks for the replies. Brian, what have you used that PPG on? No checking on wood? Thanks, Bob
PostPosted: Tue Jun 12, 2018 3:46 pm
Last Name: Beaver
City: Lake Forest
Brian,
Don't want to be a pest but I'm also very interested in the PPG product also. Would love to know the pore filler and base coat you used with it.
And I assume you level sanded and buffed it to a nice gloss?
Joe Beaver
Maker of Sawdust
PostPosted: Tue Jun 12, 2018 4:04 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
You guys on the Mainland lucky! Here's what we have to deal with on planet Hawaii. I did a web search for PPG products and sure enough there was a local dealer. Great! I called and ask if they had DCU2021. Took the guy several minutes to come back and say no. I asked him if they had any other poly. After a couple of minutes he came back again and said "Well, we have Deft". Not much available here.
PostPosted: Wed Jun 13, 2018 4:38 am
Do you have a General Finishes supplier locally?
PostPosted: Wed Jun 13, 2018 6:16 am
Last Name: Howard
City: Magnolia
State: Delaware
Deft? where did you call? Never talked to a body shop supplier that carried deft.... PPG DCU2021 is a high end automotive re-finish clear used mainly on hot rods,lowriders and such. Call your local auto re-finish suppliers.
I have used this on lot's of guitars electric and acoustic with great results. This is a 2 part urethane and compares well with the IC&S
industrial product that PRS has used for years.
Brian
PostPosted: Wed Jun 13, 2018 6:22 am
Last Name: Howard
City: Magnolia
State: Delaware
Joe Beaver wrote:
Brian,
I run it over the same filler/sealer package I used at the time which would have included a vinyl sealer of some type over the filler. Key here is prep work, it's a mechanical bond....
Product is designed to be cut and buffed to a flawless mirror shine though it is harder to buff out on a conventional arbor than some other types of finish.
Brian
PostPosted: Wed Jun 13, 2018 11:52 pm
Last Name: Beaver
City: Lake Forest
Thanks Brian. I helped a friend build a solid body base. He used PPG Shop Line to finish it. We never could get much shine out it on the buffing wheel. I suspect that the product you used was superior.
Thanks for the info
Joe Beaver
Maker of Sawdust
PostPosted: Thu Jun 14, 2018 5:43 am
Last Name: Howard
City: Magnolia
State: Delaware
Thanks for the info
Shopline is a low end finish designed for more off the gun spot repair and panel replacement in the body shop. Concept clear (2021) was made for buffing out. the difference will be night and day between the two. I am sure shopline is much cheaper too.... Last I remember the DCU2021 was about $130-$150 a RTS quart with activator and reducer.
Brian
PostPosted: Thu Jun 14, 2018 3:08 pm
First name: Julie
Last Name: Moriarty
City: Punta Gorda
State: FL
Zip/Postal Code: 33950
There was an article in Fine Woodworking magazine a year or so ago where the author showed how to get a smooth, even finish with poly. The wood he chose for the article was curly maple. He started brushing the poly on, followed by sanding. For the final coats he used wipe-on poly. The finished product looked to give it a try.
I made a live-edge, river-glass kitchen island and wanted a tough finish for the live-edge boards. I went with Minwax floor poly and also picked up a can of Minwax wipe-on poly. The wipe-on poly is where you really start to see a nice, even finish. Not sure how well this might work on a guitar, but if this kind of product is all you can get, maybe it's worth making up a sample.
Julie Moriarty
http://JulimorCreations.com
PostPosted: Thu Jun 14, 2018 4:44 pm
Last Name: Gleason
City: Kurtistown
State: Hawaii
I've taught some lap steel building classes on other islands where I can't fly with explosive chemicals. I have used the Minwax Waterbase Wipe on Poly in those cases. For a student finish, it is fairly foolproof, and it can be built up to a pore free finish. It takes time though and I'm hoping to find a sprayable poly to try out. Still searching for something that might build a little quicker for the steels I sometimes make in my shop. For acoustics I'm still bound to nitro. Like the look. Hate the process.As I mentioned earlier, the suppliers here, and the available products, are sketchy on the outer Hawaiian Islands. Just hoping to get lucky and find something that works.
PostPosted: Fri Jun 15, 2018 12:12 pm
Last Name: Beaver
City: Lake Forest
I've used Minwax wipe-on many times on thinges lIke stair rails. I wipe it on with a pad so it does take many coats to build but it does a nice job.
Not quite what I want on a guitar though. I am going to look into using the PPG product Brian mentioned. It sounds very promising. I just have to figure out how to pore fill and if I need a bond coat between the fill and topcoat. And come up with a spraying schedule and then how to buff it. Repairs should be easy with Gluboost
Joe Beaver
Maker of Sawdust
PostPosted: Sat Jun 16, 2018 6:11 am
Last Name: Howard
City: Magnolia
State: Delaware
Follow the directions here
https://www.e-bodies.org/Resources/Mopa ... et_199.pdf
I use the DCX 61 hardener.
Any pore fill compatible with solvent finishes will work. I recommend a vinyl sealer, anything similar to this
http://www.mohawk-finishing.com/catalog ... ictNbr=825
A catalyzed vinyl sealer would be preferred but not necessary. FWIW, PRS used to finish guitars entirely in a very similar finish when they first started out. They simply sprayed and sanded back until the pores were full...... About 15 -20 coats on each guitar with most of it winding up in the dust collectors after sanding.
Brian
PostPosted: Sat Jun 16, 2018 3:03 pm
Last Name: Beaver
City: Lake Forest
Wow! Thanks Brian, That makes it much easier !!!
Joe Beaver
Maker of Sawdust
PostPosted: Sun Jun 17, 2018 9:52 am
Brian, from those instructions, could you do a complete finish in a couple days? How many acoustics could you get from a quart?
PostPosted: Mon Jun 18, 2018 5:47 am
Last Name: Howard
City: Magnolia
State: Delaware
Will depend a little on your pore filler but one week is quite possible. I haven't used this in a few years now but from what I recall a RTS quart should do 2 dread size nicely.
Brian
These users thanked the author B. Howard for the post: Pmaj7 (Mon Jun 18, 2018 8:35 am)
Users browsing this forum: jfrench and 26 guests
