It is currently Thu Sep 18, 2025 7:52 am
 Post subject: Polishing bone.
PostPosted: Fri May 25, 2018 7:55 pm
First name: Jonathan
Last Name: coleman
City: rome
State: ny
Zip/Postal Code: 13440
So I was using a dremel with the polishing wheel and using the little red block of compound that comes with the dremel.
I polished at around 15-20k rpms setting.
What did I do wrong? Image
 Post subject: Re: Polishing bone.
PostPosted: Fri May 25, 2018 8:15 pm
Bone has pores. Looks like you drove compound into them.
Try getting a different colored compound. I use the same Dunn colored menzerna I use to buff out gloss...
PostPosted: Fri May 25, 2018 8:34 pm
Last Name: coleman
City: rome
State: ny
Ok...I was just making sure I wasn’t doing something wrong lol
I’ll get white compound.
PostPosted: Fri May 25, 2018 8:57 pm
First name: Freeman
Last Name: Keller
I usually sand to 1000 or so, then polish with medium Mequires compound. I had one customer complain that the nut was too shiny - I think he said it looked like plastic.
These users thanked the author Freeman for the post: Bri (Sat May 26, 2018 12:11 am)
PostPosted: Fri May 25, 2018 9:08 pm
Last Name: coleman
City: rome
State: ny
Hmmm I’ve been meaning to pick up some mequires. Too shiny eh? Maybe on a prewar Martin [WINKING FACE]
PostPosted: Fri May 25, 2018 11:31 pm
Try buffing with white toothpaste...
PostPosted: Sat May 26, 2018 8:44 am
Last Name: Sollod
I like to use micromesh...
www.swiftcreekguitars.com
PostPosted: Sat May 26, 2018 9:38 am
First name: Julie
Last Name: Moriarty
City: Punta Gorda
State: FL
Zip/Postal Code: 33950
You could try using Micro Mesh. No compound needed and it will polish to a high gloss.
Julie Moriarty
http://JulimorCreations.com
PostPosted: Sat May 26, 2018 10:26 am
First name: Conor
Last Name: Searl
City: Duncan
State: British Columbia
Zip/Postal Code: V9L 2E5
I use the micro mesh too. Mines a little dirty from polishing frets (I should probably replace it,) and it will occasionally leave the bone looking a little dirty, but I find the dirt comes right off with a final wipe of guitar polish and it looks as shiny as I'd ever want it when its done.
PostPosted: Sat May 26, 2018 10:47 am
Never found a need to polish a nut or saddle. Sand to 800 grit and done.
PostPosted: Sat May 26, 2018 11:21 am
First name: D
Last Name: S
I like unbleached bone. I has less of a plastic look.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: Haans (Wed May 30, 2018 4:16 pm)
PostPosted: Sat May 26, 2018 11:31 am
Last Name: coleman
City: rome
State: ny
I’ve never used it. I’ll try that too.
PostPosted: Wed May 30, 2018 11:32 am
I lay a coat of water-thin superglue over the surfaces of nuts and saddles, then sand off the excess before polishing. It's solved the pore problem for me.
michael propsom
www.propsomguitars.com
PostPosted: Wed May 30, 2018 4:15 pm
Not only that Dan, unbleached bone is quite a bit stronger than bleached bone. Bleaching turns bone to mush...
PostPosted: Wed May 30, 2018 6:06 pm
Not quite. But it looks nicer, and it's not as greasy as some unbleached nuts.
PostPosted: Thu May 31, 2018 1:00 pm
Well, you are right, doesn't turn it into Quaker Oats...bleached is more like ivory. Wears faster than unbleached. You can tell by filing the string slots. Might not look nicer, but doesn't look like plastic and is natural looking.
Wouldn't know about greasy, I never bought my unbleached bone from the butcher shop.
PostPosted: Thu May 31, 2018 1:23 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
I sand to 800 then hit it with some Pol polish (similar to Simichrome) on a paper towel by hand. I don't want it getting hot, that may be a leftover from working with ivory, but it works for me.
Users browsing this forum: Bing [Bot], Cal Maier and 34 guests
