It is currently Sun Jul 20, 2025 9:04 pm
PostPosted: Fri May 04, 2018 4:11 pm
Greetings...
When your premixed hide glue is in the fridge waiting to be reheated, what is its form like? Is it dried like cured glue, glass like and crystalline, or a goopy gelatinous mess?
PostPosted: Fri May 04, 2018 4:15 pm
Firm jello.
PostPosted: Fri May 04, 2018 4:18 pm
Last Name: Kincheloe
Solid but squishy. Sort of like rubber. Jim's firm jello description is also good, since that's basically what it is :)
PostPosted: Fri May 04, 2018 5:10 pm
Ok thanks. Mine too. But then I wondered if it was supposed to be glass like. I've had a few bridges come up and wondered if I perhaps had bad glue. But no, I can once more rest assuered that it's something I've done:)
PostPosted: Fri May 04, 2018 10:01 pm
First name: Allen
Last Name: McFarlen
City: Mt. Sheridan
State: Qld.
Zip/Postal Code: 4868
Mine is 315gm strength glue and it's very firm gello like.
If your bridges are lifting and you're certain your technique is good, perhaps you are making the glue up a bit too thin.
Allen R. McFarlen
Facebook
Cairns, Australia
PostPosted: Fri May 04, 2018 10:43 pm
That's my best guess.
PostPosted: Sat May 05, 2018 6:38 am
First name: Greg
Last Name: Maxwell
City: Mount Vernon
State: Ohio
You can always test your theory by using Titebond to glue a couple bridges, using the same preparation techniques. If they stay down, the evidence is that the glue is to blame.
It will probably be alright.
PostPosted: Sat May 05, 2018 10:18 am
Yeah, I switched back to TB. Thing is, they stayed down for nearly two years, then suddenly a rash of them in different circumstances all over the place. Go figure...
PostPosted: Sun May 06, 2018 8:33 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
Pure speculation here:
I wonder if the crystalline nature of dried hide glue, combined with a relatively stiff bridge, combined with a relatively flexible top and bridge plate, combined with a fair amount of relative humidity variation, and combined with something less than a perfect fit of the mating parts, could lead to this type of failure.
If the top and bridge plate are swelling and shrinking, getting rounder and flatter as the RH fluctuates, but the bridge is pretty stiff, staying flat, I can see hide glue letting go if the joint is not spot on at all points that feel the stress.
PostPosted: Sun May 06, 2018 8:51 am
"If your bridges are lifting and you're certain your technique is good, perhaps you are making the glue up a bit too thin."
For gluing bridges I like the glue to have the consistency of treacle. For gluing violin plates I like it to be thinner. Changing the viscosity of the glue and the ultimate strength to suit different uses is one of the great things about hide glue.
PostPosted: Sun May 06, 2018 11:47 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
You might one to test your batch of HHG, on scrap for 24hrs and then see how easily it will steam apart
PostPosted: Sun May 06, 2018 5:23 pm
Last Name: Parker
City: Charleston
Ditto.
PostPosted: Mon May 07, 2018 2:38 am
I don't actually know what treacle's consistency is. But I'm 90% sure I've been making my HHG too thin.
PostPosted: Mon May 07, 2018 4:02 am
Treacle's consistency is similar to syrup if that helps.
Users browsing this forum: Dave Rickard and 14 guests
