It is currently Wed Aug 06, 2025 4:51 am
 Post subject: Fan fret question...
PostPosted: Mon Apr 23, 2018 1:01 pm
Which do you folks like to be your parallel fret?
 Post subject: Re: Fan fret question...
PostPosted: Mon Apr 23, 2018 1:44 pm
Last Name: Colbert
City: Anacortes
7th on both models I make.
PostPosted: Mon Apr 23, 2018 2:07 pm
First name: Tony
Last Name: Thatcher
City: Bozeman
State: MT
7th for me, too
Tony Thatcher
Bozeman, Montana
PostPosted: Mon Apr 23, 2018 2:43 pm
Thanks!
Any particular reason why you both choose the 7th?
PostPosted: Mon Apr 23, 2018 4:08 pm
Last Name: Kincheloe
7th for me as well.
The "intensity" of the fret angles is dependent on the spacing of the strings. Since the strings are closer together at the nut than at the bridge, 12th fret perpendicular results in the nut being more sharply angled than the bridge. 7th fret perpendicular gives roughly equal nut and bridge angle with most configurations.
PostPosted: Mon Apr 23, 2018 4:10 pm
Last Name: Colbert
City: Anacortes
meddlingfool wrote:
Thanks!
As I recall it’s so the nut/saddle angles don’t end up too steep or too shallow. Mine aren’t very radical. 25” on top, 26” on the bottom for my 14 fret OM. My 12 fret 00 is 24” and 25”.
PostPosted: Mon Apr 23, 2018 4:13 pm
Last Name: Colbert
City: Anacortes
DennisK wrote:
7th for me as well.
Clearly a better explanation...
PostPosted: Mon Apr 23, 2018 4:31 pm
Thanks very much gentleman! I have one on order and there's all kindsa new interesting things to consider...but the above makes total sense.
PostPosted: Tue Apr 24, 2018 9:28 am
I like Dennis' reasoning. Some players might prefer it up or down a couple of frets, depending on how they hold the guitar.
PostPosted: Wed Apr 25, 2018 3:56 pm
First name: Leo
Last Name: Pedersen
City: Bowen Island
State: British Columbia
Zip/Postal Code: V0N 1G2
Ed do you use Fretfind2d?
It shows the angles of each fret as well as the nut and bridge.
I use it to create complementary angles between the first and last frets on the fretboard, e.g. 15deg. at fret 1 and -15deg. at fret 20 by manipulating where the perpendicular fret is.
This is the most neutral design for the fretting hand in my opinion - doesn't favour lower or higher positions on the fretboard.
Of course some players my prefer to reduce the fret angles at one end of the fretboard or the other.
Then again it's possible to reduce fret angles on some strings instead of others, as in the e-scale concept pioneered by Daniel Memory of Oni Guitars in Australia:
PostPosted: Wed Apr 25, 2018 4:15 pm
^^^^ WOW. Curved frets..... I am MOST intrigued about the technique and tools to do this. ^^^^
I've played a few fanned fret guitars with the 10th fret being most parallel. I was surprised how comfortable they felt. Of course - I'm not a fantastic guitarist in any sense of the word.
PostPosted: Wed Apr 25, 2018 7:41 pm
Leo, no I've never used that. Mostly I've just used LMI jigs. When I needed something else, I've just had my friend who did the designing at the old shop and has a little CNC side biz.
Bendy fret look cool!
PostPosted: Wed Apr 25, 2018 7:46 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Depends on scale length for me. I use the 8th on a 27.5" long end.
PostPosted: Thu Apr 26, 2018 3:23 pm
First name: Leo
Last Name: Pedersen
City: Bowen Island
He designs the scale lengths for each string in Rhino3D using an exponential relation from the shorter lengths to the longer ones - hence "e-scale."
He CNC cuts the fret slots and uses stainless steel frets which he says follow the curved slots quite easily.
I must say I'm a huge fan of his work. Love the simple clean aesthetics of his designs.
