It is currently Tue Aug 05, 2025 5:36 pm
PostPosted: Sun Apr 22, 2018 11:07 am
First name: Stuart
Last Name: Gort
This carbon fiber monocoque structure was formed inside of a wooden mold using unidirectional and braided sleeve formats. Once the resin cures the whole structure is a true hybrid carbon and wood block. CNC operations remove everything that ISN'T a neck. :)
This structure is continuous THROUGH the volute area and into the headstock.
There is no truss rod. Once you feel this neck for the first time, mounted on a body, you realize that a truss rod is moot. The rigidity is immense but it weighs only 2/3rds of the neck it replaced.
The hollow neck introduces an actual acoustic element into the electric neck. This greatly accentuates all harmonics. I was thinking it would when in the idea stage on this project...and it DOES. This neck went on a Strat body. All the Strat type noise are there...and are accentuated. It's quite musical.
The hollow cavity can be filled with a urethane based foam. The foam is easily adjusted to produce varying values of density. Therefore, the harmonic qualities can be controlled if desired.
StuMusic
These users thanked the author Stuart Gort for the post: Durero (Wed Apr 25, 2018 5:45 pm)
PostPosted: Sun Apr 22, 2018 11:18 am
Pretty cool. You could also build a little trap,door and use it to store consumables. Like picks...
PostPosted: Sun Apr 22, 2018 11:23 am
First name: Stuart
Last Name: Gort
Ya huh...I could put dope in there.
StuMusic
These users thanked the author Stuart Gort for the post (total 2): dpetrzelka (Mon Apr 23, 2018 6:53 pm) • Michaeldc (Sun Apr 22, 2018 2:54 pm)
PostPosted: Mon Apr 23, 2018 4:50 pm
City: Escondido
Zip/Postal Code: 92029
That’s probably not something I’d ever try, but I do work with CF. I always love knowing what can be done. What is the technique were seeing here? It looks pretty time and labor intensive.
Ps: haven’t you heard? You don’t need a secret compartment for dope anymore. It won’t be long before you can pick it up at a local store along with a fifth of Jack and a hard pack of Marlboro’s. Although the Marlboro’s are probably going to cost you five time as much as the dope, so maybe skip them.
PostPosted: Mon Apr 23, 2018 6:46 pm
First name: Stuart
Last Name: Gort
A bladder is inflated inside the carbon sleeve to 100 psi.....expanding the material to the extremes of the wooden cavity. Once completely cured the block is machined until a neck pops out. I just push a button. :) Bladder molding is used extensively through aerospace, F1, cycling, and other markets where a monocoque structure is desired.
Yes...it's very time consuming but it DOES produce a very consistent result...I mean every time. This is one of the processes I used to make aircraft propellers...for that very reason.
StuMusic
These users thanked the author Stuart Gort for the post: Durero (Wed Apr 25, 2018 5:46 pm)
PostPosted: Mon Apr 23, 2018 7:03 pm
City: Escondido
I assume you have to mill the cavity first to the exact size of the sleeve. So the neck is milled four times? Each half of the blank for the cavity, outside top, outside back? Glue up, holding jigs, vacuum infusion? As I said, looks like a lot of work.
PostPosted: Mon Apr 23, 2018 8:56 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
very slick very high tech , very impressive . I like it!
These users thanked the author ernie for the post: Stuart Gort (Tue Apr 24, 2018 9:53 am)
PostPosted: Mon Apr 23, 2018 10:33 pm
First name: Stuart
Last Name: Gort
Not exactly. The braided sleeve is something like a Chinese finger torture...in that it WILL expand within a limited range.
Yes (that's very astute...btw), except the inside operations do not require any fine surfacing. That goes rather quickly.
The programming and tooling is intensive. Beyond that it's about 8 hours of machine time and about 15 hours of hand work to complete a neck....ready to play.
StuMusic
 Post subject: Some Carbon Fiber Action
PostPosted: Mon Apr 23, 2018 10:35 pm
City: Escondido
Stunning, and beautiful, and very cool. Excellent work.
PS I’d love to see a picture of the whole completed neck.
These users thanked the author rlrhett for the post: Stuart Gort (Tue Apr 24, 2018 9:53 am)
PostPosted: Tue Apr 24, 2018 10:21 am
Wow! That's really neat.
These users thanked the author jfmckenna for the post: Stuart Gort (Tue Apr 24, 2018 5:50 pm)
PostPosted: Tue Apr 24, 2018 10:25 am
City: Escondido
One more question: the carbon fiber layer looks to be 1/8” or more thick. But the weave of the sleeve can’t be more than 1/40”. What makes up all that thickness?
PostPosted: Tue Apr 24, 2018 5:46 pm
First name: Stuart
Last Name: Gort
The sleeve is doubled...one inside of another. It takes a thin resin to wet out two layers together. Both layers together result in a wall thickness of .06". The rest of that thickness is due to an outer layer of unidirectional tows. You can pack that anywhere you want and make it as thick as you want....within limits.
StuMusic
PostPosted: Tue Apr 24, 2018 6:40 pm
City: Escondido
So what you are saying is that when you are done playing your Strat you can use it as a lever to prop up a bulldozer to change the tracks. [FACE SCREAMING IN FEAR]
These users thanked the author rlrhett for the post: Stuart Gort (Tue Apr 24, 2018 8:08 pm)
PostPosted: Tue Apr 24, 2018 7:23 pm
That is not only cool but very impressive Stuart. I like it!
jw ( o)===:::
These users thanked the author joe white for the post: Stuart Gort (Tue Apr 24, 2018 8:04 pm)
PostPosted: Thu Apr 26, 2018 8:09 pm
First name: Stuart
Last Name: Gort
StuMusic
PostPosted: Thu Apr 26, 2018 10:54 pm
First name: Leo
Last Name: Pedersen
City: Bowen Island
State: British Columbia
Zip/Postal Code: V0N 1G2
Wow! That's very beautiful work Stuart!
Fascinating construction method and structure too.
How do you remove the bladder once the resin is cured? Does it come out the body end of the neck?
Very impressive :)
These users thanked the author Durero for the post: Stuart Gort (Fri Apr 27, 2018 12:33 am)
PostPosted: Fri Apr 27, 2018 12:35 am
First name: Stuart
Last Name: Gort
It stays inside...bound to the resin for eternity. :)
StuMusic
PostPosted: Fri Apr 27, 2018 5:44 am
Stuart - you never fail to intrigue me with your advanced thinking and techniques.
PostPosted: Fri Apr 27, 2018 6:49 am
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Curious how much weight this cuts out?
PostPosted: Fri Apr 27, 2018 8:06 am
Stealth Carbon. Pretty Cool!
These users thanked the author Clay S. for the post: Stuart Gort (Fri Apr 27, 2018 3:45 pm)
PostPosted: Sat Apr 28, 2018 10:37 am
First name: Stuart
Last Name: Gort
Without tuners it weighs a bit less than 2/3rds of the stock Fender neck. I like Sperzel (aluminum housings) tuners when weight is truly an issue.
StuMusic
Users browsing this forum: Chris Ide, Mike Franks and 42 guests
