It is currently Fri Jul 04, 2025 7:32 am
PostPosted: Tue Feb 27, 2018 5:46 pm
Haven't posted here in a cockatoo's age
About to finish another guitar in lacquer and again thinking on how to keep the finish out of the bridge and stop bar holes. I have tried tissue, thin scrunched plastic, Plasticine and just shot lacquer straight over them and cleaned up after.
Inevitably I will lose finish when pulling the fill or have it shatter when tapping in the bushings. Worst thing is time consuming lacquer repairs putting a barrier between the customers cash and my wallet.
Any one have a tip?
greatly appreciated and thanks in advance
PostPosted: Wed Feb 28, 2018 8:40 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
I finish over them and press the bushings in hot. The heat will keep them from chipping the finish.
Brian
These users thanked the author B. Howard for the post (total 2): old_picker (Wed Feb 28, 2018 6:18 pm) • Pmaj7 (Wed Feb 28, 2018 11:11 am)
PostPosted: Wed Feb 28, 2018 12:47 pm
First name: D
Last Name: S
I install the bushings slightly below the body surface before finishing, and cover them with tape.
I use a Dremel to create a step for bushings that have a lip.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: old_picker (Wed Feb 28, 2018 6:18 pm)
PostPosted: Wed Feb 28, 2018 6:21 pm
the step is done before finishing or after finishing?
PostPosted: Wed Feb 28, 2018 9:21 pm
First name: D
Last Name: S
Before finishing.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: old_picker (Wed Feb 28, 2018 11:45 pm)
PostPosted: Wed Feb 28, 2018 11:47 pm
Love to know how you get a dremel to cut a nice even step like that - I was thinking on using a 19mm countersink bit. Currently masking up and about to start on shellac as pore fill. This one is in korina and the grain is very open which takes a lot to fill out. So I have a few days before I start laying down lacquer coats to get this right. I drove the stop bar studs just below the surface and I will tape them off as per your suggestion.
btw that looks like a very nicely built instrument and the burl is quite stunning [:Y:]
These users thanked the author old_picker for the post: dzsmith (Thu Mar 01, 2018 9:49 am)
PostPosted: Thu Mar 01, 2018 9:48 am
First name: D
Last Name: S
I mounted the Dremel in a router base, and routed it out by hand.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post: old_picker (Thu Mar 01, 2018 5:03 pm)
PostPosted: Thu Mar 01, 2018 5:06 pm
ok good hands i reckon - i tend to be less trusting of getting a neat result
i will do it like that but mount a 16mm mdf on top with 2 x 14mm holes @74mm centers punched through as a bit of a guide
PostPosted: Thu Mar 01, 2018 11:02 pm
First name: Allan
Last Name: Bacon
You might give these a try. A reverse spot face tool.
https://www.yardstore.com/drilling-and- ... se-cutters
PostPosted: Fri Mar 02, 2018 10:34 am
City: Escondido
Zip/Postal Code: 92029
Keeping Finish out of body holes?....
Pants and a good respirator.
These users thanked the author rlrhett for the post (total 2): John Lewis (Sat Mar 03, 2018 3:49 pm) • fumblefinger (Sat Mar 03, 2018 12:29 am)
