It is currently Sat Jul 19, 2025 1:39 am
Post new topic Reply to topic  [ 67 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Thu Jan 25, 2018 7:00 pm
I like how they consider a guitar that plays well up the neck with the same power and clarity as the low part of the neck an innovation, as if custom builders by the thousands haven't already been doing that for donkeys years.
PostPosted: Thu Jan 25, 2018 7:07 pm
Ladder Bracing? Aside from the LTB, Colin, don't see it, and where is the lower bout spanning bridge patch?
As far as the groove, depends on what the thicknesses are. Personally, coming from graduated mandolins, I would rather do what I actually did on my guitars, taper the tops on the thickness sander and taper the lower bout edges more after the box is together and bound, but you need a Hacklinger gage for that. The difference between handbuilt and factory. One is always in a hurry...
My guess is the top is not fully braced, and a UTB and popsicle or double UTBs are to be added. Unless they are going to float the F/B extension, the area above the LTB is mostly useless anyway as a major contributor to vibratory tone production.
Why the groove runs way inside the kerfing on the bass side is a mystery to me. Maybe it's some of that corporate doublespeak crap.
They will have big problems with the telegraphing of the longitudinal bracing. Just goes to show that you can put bracing anywhere and it will sound like some kind of guitar as long as it has 6,7,9 or 12 strings. What kind of tonal qualities you end up with is another story and what the instrument looks like in 50 years yet another, but many have drifted away from "traditional" tone with laminated tops, double tops with epoxy/Nomex fiber, plastic backs, carbon fibre guitars, HPLs, etc, etc, in the quest for a "better" sounding instrument than traditional, but I stuck with traditional and it worked VERY well.
These users thanked the author Haans for the post: Ken Grunst (Thu Jan 25, 2018 9:37 pm)
PostPosted: Thu Jan 25, 2018 7:40 pm
"Taylor has been doing the soundboard groove for well over 10 years now. It's not a problem."
10 years is not what I would consider "the long run"
When the top hits a dry spell it seems like the groove would be a weak spot and more likely to have a parting of the ways. The brace system just below the soundhole bothers me more. I just don't see it resisting the pull of the strings for 50 or 100 years.
These users thanked the author Clay S. for the post: Haans (Fri Jan 26, 2018 9:06 am)
PostPosted: Thu Jan 25, 2018 8:25 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I'd be interested to see what the neck block looks like. Average sized, or massive?
Alex
PostPosted: Thu Jan 25, 2018 8:28 pm
First name: Fred
City: Winnipeg
Think this is just the 'new' bracing structure the remainder is not shown as it is the same old stuff, not that that is bad. But new?
https://www.youtube.com/watch?v=w00ty90qZcI
Oh, almost forgot to mention, the lower soundhole brace is the same old classical guitar recipe. Tried and true for a few years.
PostPosted: Thu Jan 25, 2018 8:50 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Personally,I hope it sounds great. Innovation that makes your guitar sound better? I’m in.
These users thanked the author JSDenvir for the post: Mark Fogleman (Fri Jan 26, 2018 7:41 pm)
PostPosted: Thu Jan 25, 2018 9:30 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I agree. But it really chaps my hide to see companies with great reputations stoop to shovel fulls of hoopla, hooey, and hyperbole to promote something new as is being done with this bracing design. It reminds me of the shovel fulls of h, h, & h that were tossed around over the past couple years regarding torrified tops (torrefaction time machines come to mind). It's totally unnecessary given the loyal followings these companies have. If I worked there, I would be embarassed to be associated with such nonsense.
These users thanked the author J De Rocher for the post: Haans (Fri Jan 26, 2018 8:55 am)
PostPosted: Thu Jan 25, 2018 10:16 pm
I’d be very interested in how it feels. I mean... my Martin just FEELS so much different than say my Halcyon. I want to know how it feels against me I guess.
When I read that it sounds really weird haha
PostPosted: Thu Jan 25, 2018 10:57 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I would not worry about the grooves. The light bracing? That's another thing. Tacoma failed with that general design, and a 6 string has way more tension. That said, that extra plate might just be what it takes to prevent the Tacoma belly bulge problem.
PostPosted: Fri Jan 26, 2018 10:25 am
I think Collin and I are seeing the same thing re:ladder bracing. Like a classical guitar this design has a huge lower cross brace which essentially cuts the 'working' top at that point into the lower bout. It also has two very strong braces right down the center which tend to divide the top into two sections with a ladder-ish braced design. Like I said I don't know if I am right about this but that's what I see and that's how I think about these things right or wrong.
PostPosted: Fri Jan 26, 2018 10:30 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
By no means am I a ladder brace expert but I thought a feature of ladder bracing for tops was a lateral brace under the bridge doing whatever it does there. THis looks like it is derived from classical bracing patterns. There are inverse fan bracing patterns.
PostPosted: Fri Jan 26, 2018 12:15 pm
Rorschach test, laughing6-hehe
PostPosted: Fri Jan 26, 2018 12:45 pm
Ladder...
Fishbone...
PostPosted: Fri Jan 26, 2018 1:10 pm
First name: Jay
City: Bothell
State: Washington
[:Y:] Definitely fishbone.
PostPosted: Fri Jan 26, 2018 2:55 pm
Ha! Fishbone, I like that :D
PostPosted: Fri Jan 26, 2018 4:49 pm
First name: Kerry
Last Name: Werry
City: Coquitlam
State: British Columbia
The more I see different bracing schemes the more I think they don't matter, X, ladder, Kasha, Lattice, double X, Symmetric Laravee, Old Gibson H, and now this just to name a few.. As Hesh pointed out some are easier for the repair guy to deal with some are better for strength and longevity BUT they can all sound good if treated properly AND I do believe we all hear what we want.. Most truly blind listening tests I've heard seem to agree we hear what we thing we should when we know what we are listening too..
And yes this particular one appears to be lettered with marketing BS pfft
Kerry
Hesh wrote:
As to what it sounds like: My prediction is that everyone will think that is sounds exactly like what they want it to sound like just like all other bracing schemes..... ;)[/quote]
My Website http://klw-strings.com
My Luthier's Blog...http://klwstrings.blogspot.com
PostPosted: Fri Jan 26, 2018 6:01 pm
looks like the cross dipole will be very mobile
PostPosted: Fri Jan 26, 2018 6:45 pm
At the expense of what, though?
PostPosted: Fri Jan 26, 2018 9:37 pm
Time will tell. No Doubt there are some cost-saving measures there. I think it is a smart marketing move to have some "technological advances". People eat that stuff up!
PostPosted: Sun Jan 28, 2018 11:21 am
Yeah,
and making that groove unsymmetrical may be an attempt to make it unsymmetrical
as well to reduce the phase cancellation of the cross dipole?
PostPosted: Sun Jan 28, 2018 3:51 pm
A couple of thoughts....
First, before I make a formal evaluation of the V system, I want to play a couple of them. That being said....
In listenting to several videos, from Taylor and Peghead Nation, my take is that it is unremarkable. Like others who have commented, it still sounds like a Taylor (or at least a post 1993 one). If that's your flavor, great. I don't notice anything that jumps out at me. I haven't played one, so I can't comment on how it feels up and down the neck, nor how it intonates. The question I have is does it fall within the normal distribution of good and better Taylors or is it an outlier which would be something different. The jury is out. I want to hear what these sound like now, and a year from now.
PostPosted: Sun Jan 28, 2018 6:25 pm
Last Name: Fields
City: Granite Falls
Zip/Postal Code: 28630
J.L.K. Vesa wrote:
Yeah,
I'm thinking it's to allow for the armrest.
Mike Fields
PostPosted: Sun Jan 28, 2018 7:01 pm
I would almost bet you are right Mike. That just makes me think that they are playing "silly buggers" as the Brits would say.
Have read all the drivel over at that "used to be Taylor" website. I noticed that some were wishing for builders to comment, but haven't seen any. Just gotta love all the "professional players" trying to make builder comments.
Myself, I wished I would have had the time to experiment more with this bracing...
Too complicated for "production" though. Couple of days ago I pulled out one and I was very impressed at the improvement after several years of not playing it. Must have been that mobile cross dipole...
PostPosted: Mon Jan 29, 2018 12:41 pm
i'm not a fan of the "Taylor tone" but i'd have to play one just to see what it brings to the table. it at least seems interesting. it wouldn't be what I'd do but it might work for Taylor.
gut tells me that this would give the mids a boost and serve up a bit more "perceived" projection but who knows? there's more to a guitar's sound then just the top.
on the other hand it might change the famous "Taylor-tone" and drive people away. again, just don't know yet.
PostPosted: Mon Jan 29, 2018 1:35 pm
cs51762 wrote:
J.L.K. Vesa wrote:
Yeah,
Yes,
that is it, didn't cross my mind.
Somehow I thought this bracing would be for the cheaper end of the line with no such features,
but I just saw a video from where I learned that they start from the top end of the line with this bracing.
Users browsing this forum: DennisK, Michaeldc and 15 guests
