It is currently Fri Sep 19, 2025 3:07 pm
PostPosted: Sun Jan 21, 2018 12:07 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Anyone out there own one? would like to get some feedback before buying one looked at the wen 6502 on amazon and the low end ryobi and an HF models .Plan to use it for uke FB, bridges , bone nuts and saddle and other small parts Thank you,
PostPosted: Sun Jan 21, 2018 12:52 pm
First name: Fred
City: Winnipeg
I have an old sander for about 30 years, done many a project on it. It is quite useful but I will eventually get a longer version to do a full size fretboard on it.
These users thanked the author printer2 for the post: ernie (Sun Jan 21, 2018 1:53 pm)
PostPosted: Sun Jan 21, 2018 1:23 pm
Well, I absolute love the small disc sander for nuts and saddles. Never got much use from the belt. Though the end of the belt can make a real nice thickness sander if you make a little contraption for it. The disc usually has a crown so you need to flatten it. When I did my Reno a few years ago, there was no good place to,put the 4x36, and I miss it...
These users thanked the author meddlingfool for the post: ernie (Sun Jan 21, 2018 1:53 pm)
PostPosted: Sun Jan 21, 2018 3:28 pm
First name: David
City: Napa
Zip/Postal Code: 94558
if you want the best get a Jet if not I like the Rikon 4x36. with a 6" disk combo. Rikon is sale high now at woodcraft 10% off
These users thanked the author dofthesea for the post: ernie (Sun Jan 21, 2018 4:53 pm)
PostPosted: Sun Jan 21, 2018 4:43 pm
What part of the fretboard are you guys doing with those sanders?
Ed, I've noticed a crown on the belt rollers, but was surprised to hear there might be one on the disk. Guess I need to check...
PostPosted: Sun Jan 21, 2018 4:54 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Checked out the rikon at HD Lowes has PC a little more money and more HP
PostPosted: Sun Jan 21, 2018 7:40 pm
The crown on the roller is go keep the belt centered.
The crown on the disk is likely just a result of their machining process. It's nice to get it flat especially for saddles...
PostPosted: Mon Jan 22, 2018 6:59 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
If you want to just buy a cheap Harbor Freight one, to see if you like it, I have found that the motors in those sanders are excellent for building your own woodworking tools. I am powering my motorized dish sander with the motor from one of those cheap sanders. So, if it winds up not working the way you want, you can chop it for parts. Depending on sale prices, it can be a lot cheaper than buying a motor on its own.
These users thanked the author doncaparker for the post: Pmaj7 (Mon Jan 22, 2018 7:09 pm)
PostPosted: Mon Jan 22, 2018 8:29 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have the Jet 6x48. Endless uses. Bone work, fret boards, on and on. You make ukes. the 4x36 will work just fine.
Edit: Bridges, saddles too. I have to admit when it came to tools like this, I haunted other forums to find stuff like this used. I got my Jet for way less than new cost and it was and is way like new. But if you have settled on HF or Ryobi, then go for it. A good selling forum is over at sawmillcreek.org. Very reliable.
PostPosted: Tue Jan 23, 2018 4:03 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I have the Porter-Cable PCB420SA Belt with 8" Disc Bench Sander, 4" x 36" and it has held up well for me over 3-4 years. I use it almost everyday in the shop. For the price it was pretty good. I had a ryobi that I repaired about 4 time in the few years that I had it. It constantly broke belts. TThe biggest issue I have with the Porter Cable is that the tables do not lock well. Each time I use it I need to check that the table is square. I am the opposite of most and use the belt and not the disk very often. Although the 8" is not a bad size for a lot of tasks.
Users browsing this forum: Bing [Bot], Ken Lewis and 34 guests
