It is currently Tue Sep 16, 2025 11:25 am
PostPosted: Sun Jan 07, 2018 10:35 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I need a touch up gun. Ideas?
PostPosted: Sun Jan 07, 2018 11:43 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Double post...
- Beth Brower
PostPosted: Sun Jan 07, 2018 11:45 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
Our Iwatas - including our older RG-6 - behave well with nitrocellulose. The current Kustom ($200-$550), High Performance Plus (~$200) and Hi-Line (~$250) series (we have a High Line HP-CS that I really like using for touch-up work on repairs) have PTFE/Teflon needle packings specifically for solvent-based material. The Harder Steenbeck Infinity line also is equipped with solvent-resistant PFTE seals. A safe bet is to look for specific mention of solvent compatibility before buying, and if not mentioned, verify PTFE seals and packing, versus rubber, which can degrade in strong solvents like lacquer thinner. Coast Airbrush is a decent source of information and carries a wide variety of airbrushes.
- Beth Brower
PostPosted: Mon Jan 08, 2018 7:32 am
Fuji 9622 Touch-Up Spray Gun may be worth a look if you already have a Fuji system - I have one myself.
PostPosted: Mon Jan 08, 2018 11:39 am
Harbor Freight had (has?) a little gravity feed touch up gun that worked O.K. for nitro. They had a 3 or 4 oz. metal cup They were about $15. I bought a couple for spraying bursts.
PostPosted: Mon Jan 08, 2018 3:01 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
Mr. O'Melia:
Were you inquiring about a touch up gun (i.e., a smaller spray gun usually used for either small projects or touch-ups on larger jobs) or an airbrush? If looking for something to shoot bursts or other fine work, the T-75G can be tweaked to handle the work (dial back fan width, get the right air cap set, and control air and material). For touching up color work (dings/holidays) or for very small areas, an airbrush will work well. Bridging the gap between spray gun and airbrush are pistol grip airbrushes with larger capacity cups.
The jamb gun mentioned earlier in the thread is a nice little touch-up gun and inexpensive. The jamb gun and a decent pancake compressor with hose set should run not much more than the Fuji turbine detail gun.
- Beth Brower
PostPosted: Mon Jan 08, 2018 4:55 pm
The HF spray gun I was refering to was what they call a "mini detail spray gun". www.harborfreight.com/adjustable-detail ... 92126.html
It is smaller than the typical jamb gun and more like a badger 400. It will spray heavier materials than an air brush. It's good enough to do touch ups and bursts but you wouldn't want to have to do heavy top coats with it.
PostPosted: Mon Jan 08, 2018 6:03 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
That is interesting. Used it?
PostPosted: Mon Jan 08, 2018 6:29 pm
Not yet actually. I bought it to use for a matt finish neck if I was using a gloss on the body with the main gun, which I've not done yet.
PostPosted: Mon Jan 08, 2018 7:03 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Could u take a picture in ur hand? I’m trying to get an idea of scale. I’ve got some nitro touch up work to do on a solid body.
PostPosted: Tue Jan 09, 2018 4:28 am
Can do later - just woke up. Coffee......!
PostPosted: Tue Jan 09, 2018 5:30 am
Here you go, next to an XPC gravity gun.
These users thanked the author Colin North for the post: Ken Grunst (Sun Dec 23, 2018 7:34 pm)
PostPosted: Tue Jan 09, 2018 9:09 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Thank you! Bigger than I had envisioned. But from what I’ve read it has a small pattern.
Users browsing this forum: Don Williams, Kbore, meddlingfool and 15 guests
