It is currently Sun Mar 02, 2025 4:11 am
Post new topic Reply to topic  [ 105 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Thu Jan 04, 2018 1:04 pm
Mike OMelia wrote:
CP, any chance you can tell me thickness of FB at end? At highest point of crown.
Will have a look when I get back home Mike
Sent from my D6603 using Tapatalk
PostPosted: Thu Jan 04, 2018 2:53 pm
First name: peter
Last Name: havriluk
City: granby
State: ct
Zip/Postal Code: 06035
This problem may benefit from a multi-part incremental solution. How about straightening the neck, level all the frets and over-level the frets south of #14? Then try to play it. If that solution works, then the advice from folks about thinning the fingerboard south of #14 will work just fine, and OP will have determined, at little cost in either time and no cost in cash, what direction the next step needs to take. And it's not invasive or damaging to the guitar. Perhaps the now-much-lower frets down low won't matter much and the problem can be filed away as 'solved'.
I agree with Truckjohn's advice to terminate analysis and try a fix without analyzing the problem ad infinitum. An hour's effort will provide solid empirical information.
Peter Havriluk
These users thanked the author phavriluk for the post: cablepuller1 (Thu Jan 04, 2018 2:55 pm)
PostPosted: Thu Jan 04, 2018 4:05 pm
It's 6mm 0.235
PostPosted: Thu Jan 04, 2018 6:58 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Ok. Thickness sounds good. Bridge is a little short. No big deal I think. Someone above made a great suggestion. Take it to a pro setup person. Get an opinion.
I’ve been thinking. With the strings on, the relief set, what string height to u have at 12th fret? Did u mention this? What is your clearance at fret 1? High and low e
These users thanked the author Mike OMelia for the post: cablepuller1 (Fri Jan 05, 2018 1:30 am)
PostPosted: Tue Feb 13, 2018 9:29 am
Last Name: Lee
Country: Wales U.K.
Not too far from you. http://www.alanmillerguitars.co.uk/testimonials.html
I met him at Yandles show last year and he was very friendly and eager to talk about his guitars even though I told him I would not be buying. Worth a try.
Users browsing this forum: Colin North and 33 guests
