It is currently Tue Jul 22, 2025 1:40 am
Post new topic Reply to topic  [ 38 posts ]  Go to page Previous  1, 2
PostPosted: Tue Dec 19, 2017 8:31 am
First name: Brad
Last Name: Combs
That's a great jig, Jeff!
PostPosted: Tue Dec 19, 2017 10:07 am
Cool idea Jeff!
PostPosted: Tue Dec 19, 2017 11:29 am
jeffhigh wrote:
I use a 12" disc sander too.
It's a long lower and upper board, drilled at 1" centres for a pivot
I just fix the block on with a screw since I always use a cross grain veneer to the inner face.
once I have worked out the best radius by trial (working from numerially large down) I write the number on the mould for that guitar
Used to use a similar set-up for my 6" belt sander, but find it quicker now to block plane and then touch up with abrasive in my molds which are full height+ at the top and tail.
PostPosted: Tue Dec 19, 2017 2:24 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
Santa Cruz Guitar Co. called me one day and asked me to come over and look at the fixture they had made almost identical to yours Brad. They were having a slight problem with it which they showed me when I arrived. After placing the blank in the fixture and informing me to stand back J.K. ran the part through the router table. The bit ripped the part out of the fixture and sent it into the wall across the room some 30' away faster than I could follow it with my eyes. Scary? Just a bit. I would make sure that every bit I put in the router spun perfectly true, at the very least and be sure to stand out of the line of fire. Me, I'll stick with the sander. Not worth damaging any body parts to save a minute or 2.
These users thanked the author Tim L for the post: bcombs510 (Tue Dec 19, 2017 3:12 pm)
PostPosted: Tue Dec 19, 2017 2:42 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Tim L wrote:
The bit ripped the part out of the fixture and sent it into the wall across the room some 30' away faster than I could follow it with my eyes..
This is exactly what I would be worried about and whatever was in the line of fire.
These users thanked the author J De Rocher for the post: bcombs510 (Tue Dec 19, 2017 3:12 pm)
PostPosted: Sat Dec 23, 2017 3:53 pm
First name: Brad
Last Name: Combs
I updated the jig to V2 taking into account much of the feedback from here. The new jig is a bit beefier, made of MDF. The front plate of the backstop can spin to allow the block to stay registered for the second pass. I did pick up a 12” disc sander to experiment with as well. The way the jig is designed I can use either the router, the sander, or a combination. I’m thinking that for tighter radius, where more material has to come off, start on the sander and finish up with the router. I’ll experiment a bit with both to see how it goes.
Another improvement is I put the neck and tail block radius on the same sled, just to cut down on materials. The backstop can come off and flip around to use either edge depending on the radius needed.
If this goes well I’ll make a second for Tenor Uke.
Some pics:
Brad
PostPosted: Sat Dec 23, 2017 4:56 pm
First name: Brad
Last Name: Combs
First test block off of the sander. That was no drama at all. You folks may have me convinced. ;)
PostPosted: Sat Dec 23, 2017 6:08 pm
Last Name: Farmer
City: Durango
State: CO
bliss bliss
I guess you'll have to get your Adrenalin fix some other way now.
Useful for making bone chikari posts too. (and other random round things with strange tapers and diameters).
These users thanked the author david farmer for the post: bcombs510 (Sat Dec 23, 2017 6:11 pm)
PostPosted: Sat Dec 23, 2017 8:00 pm
Now yer cookin' Brad and you'll go through life with all ten.
These users thanked the author Terence Kennedy for the post: bcombs510 (Sat Dec 23, 2017 10:20 pm)
PostPosted: Sat Dec 23, 2017 8:53 pm
I must say I'm relieved to see you go the sander route.
These users thanked the author meddlingfool for the post: bcombs510 (Sat Dec 23, 2017 10:20 pm)
PostPosted: Sat Dec 23, 2017 10:25 pm
First name: Brad
Last Name: Combs
The main thing for me was repeatability of a quality result. I wasn’t getting that doing them by hand. The sander is very fast. I don’t see a reason for the router method at this time. I do appreciate all the advice and feedback!
Brad
PostPosted: Sun Dec 24, 2017 12:27 am
If you add side pieces to the jig that would support the work piece on both sides as well as clamping the top it might be less likely to fly across the room. Taking too big a bite or approaching the work in the wrong fashion can lead to disaster no matter what method you choose.
You should always use a tool and technique you are comfortable with - just not too comfortable.
These users thanked the author Clay S. for the post: bcombs510 (Sun Dec 24, 2017 7:11 am)
PostPosted: Sun Dec 24, 2017 1:59 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I may do something more elegant in the future, but for now this works.
Good judgement comes from experience. Experience comes from poor judgement.
These users thanked the author Casey Cochran for the post: bcombs510 (Sun Dec 24, 2017 3:16 pm)
Users browsing this forum: TimAllen and 18 guests
