It is currently Wed Sep 17, 2025 1:54 pm
PostPosted: Mon Dec 04, 2017 11:38 am
Here is the latest Luthier Tips du Jour video - In this video I offer a viewer a tip about how not to break bits when doing inlay work. This video as well as all my other videos are available via my website, http://www.obrienguitars.com/videos , LMI's website or on youtube.
PostPosted: Mon Dec 04, 2017 12:41 pm
Last Name: Beaver
City: Lake Forest
I think I need one of those! I see them on the Internet from $30 to several hundred dollars. Can you point me in the the right direction as to one that would be a good choice? Any thoughts you might have on it would be greatly appreciated.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Dec 04, 2017 1:35 pm
There are several types available. The more money you spend the better the quality and the higher the RPM's.
PostPosted: Mon Dec 04, 2017 5:31 pm
Last Name: Sollod
John Hall @ Blues Creek Guitars sells them...
http://www.bluescreekguitars.com/shop/i ... cts_id=294
www.swiftcreekguitars.com
PostPosted: Mon Dec 04, 2017 5:32 pm
Last Name: Sollod
... or this one...
http://www.bluescreekguitars.com/shop/i ... ucts_id=18
PostPosted: Mon Dec 04, 2017 8:28 pm
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
I have one from John Hall. Loud as hell- use hearing protection. Works great though.
PostPosted: Mon Dec 04, 2017 10:34 pm
Last Name: Kincheloe
Yep, I'll stick with my 12,000RPM just for the reasonable volume. I do use multiple passes sometimes. Usually I can feel if the bit doesn't want to cut, and back off before breaking it. But eventually all 1/32" and smaller bits do break. This guy sells them cheap, though https://www.ebay.com/usr/jtg1969
PostPosted: Tue Dec 05, 2017 3:26 am
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
+1 for John Hall at Blues Creek. Great tool and great support.
PostPosted: Tue Dec 05, 2017 9:22 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
Got mine from John, great tool . I had a machinest find the center location of the stew mac circle cutter and use this in conjunction with the die grinder for cutting rosettes on ukes. To just use as an inlay cutter I take out 2 screws , I/ve used the inlay cutters off e vil bay and yes the 1/32in bit does not last long esp with the high rpm die grinder your mileage may vary.
PostPosted: Tue Dec 05, 2017 9:30 am
First name: Fred
Last Name: Tellier
City: Windsor
Zip/Postal Code: N8T2C6
I had a lower RPM cheaper grinder, got an opportunity to get a Sioux brand professional style with much higher RPM and the improvement in cutting ability is awesome. Not any louder than using a dremel though when the compressor motor starts running every few minutes the noise is much worse.
Fred
Fred Tellier
PostPosted: Tue Dec 05, 2017 10:53 pm
Last Name: Livermore
State: Minnesota
I got a fistfull of bits from my dentst. For free.
Seriously.
Never broken one and some are much smaller and able to do amazing detailed routing for inlay.
They are chucked right into a dremel.
These users thanked the author Dave Livermore for the post: mountain whimsy (Wed Dec 06, 2017 1:48 pm)
Users browsing this forum: Ken Lewis, Michaeldc and 28 guests
