It is currently Fri Sep 19, 2025 12:43 am
 Post subject: Vertical logo
PostPosted: Sat Nov 18, 2017 11:43 am
Hmmm
What are your thoughts on a vertical logo? I’m not use to seeing it, but Tak does it don’t they? I guess it’s way too long of a name to do another way..
This is just stuck on right now to see if I like it
 Post subject: Re: Vertical logo
PostPosted: Sat Nov 18, 2017 11:54 am
Last Name: Beaver
City: Lake Forest
It is different but, the more I look at, the better I like it. Not necessarily better than horizontal but I think it will look fine.
By the way, that is a pretty nice job cutting out some difficult pearl.
Joe Beaver
Maker of Sawdust
PostPosted: Sat Nov 18, 2017 11:58 am
First name: Brad
Last Name: Combs
Looks good. If it bothers you, you could always stack it the other way like the old Martin logo.
PostPosted: Sat Nov 18, 2017 11:59 am
I appreciate the compliment but I had 6 of these logos cut out by someone w a Cnc for me:)
They did a great job.
PostPosted: Sat Nov 18, 2017 12:46 pm
I did it for years on certain mandolins.
Looks like with that large S, you are getting pretty close to the tuner shaft the other way. You might try it off center the other way too, maybe with the S centered.
PostPosted: Sat Nov 18, 2017 1:37 pm
First name: George
City: Seattle
I don't dislike the vertical alignment but it does make the S look a bit outsized to me. Too late with this neck, but experimenting with alternative headstock shapes may reveal more layout options.
George :-)
PostPosted: Sat Nov 18, 2017 2:29 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
I like the logo itself overall, but I'm not enthusiastic about how it looks in the vertical orientation. With this headstock shape it seems like you pretty much have to go with that, though. For me, with the guitar positioned vertically (like in a guitar stand), it's not immediately clear that the logo is a word because of the script font and the huge difference in size between the "S" and the "now" letters. It kind of looks like a vertical squiggle centered above a hook shape.
There actually are quite a few guitar brands that have vertically oriented headstock logos, particularly on electric guitars with a Fender type headstock, but typically the scripts/fonts that they use are immediately recognizable in any orientation as text. That's also why Haans' logo on his mandolin works so well in the vertical orientation.
I think the Snow logo could work better vertically with some minor modifications to make it more easily recognizable at first glance as being a word. One might be to reduce the difference in size between the "S" and the "now" (make the "now" letters larger/taller?) and another might be to shift the "now" letters down away from being centered on the "S" so that the word looks more like a capital letter followed by three lower case letters that form a word. Also, the "S" and the "now" are distinctly different font styles which also makes it less recognizable overall as a word.
On the other hand, you may want the logo to have a bit of an abstract quality to it as a part of the design.
Haans - That is one of the coolest non-traditional mandolin designs I've seen. I love it.
PostPosted: Sat Nov 18, 2017 4:05 pm
Thanks for the input guys:)
PostPosted: Sat Nov 18, 2017 4:09 pm
Why not, there's quite a few out there.
Nice logo BTW.
PostPosted: Sat Nov 18, 2017 6:15 pm
Snowmanguy, I've been thinking off and on about your situation all day. As Jay says, there is too much difference in the font sizes, but knowing you have 6 of them and it probably set you back a little, take your time to be creative and also realize this is one of your first mistakes along the path of learning about this stuff.
Unfortunately, The S looks a bit like Bruce Sexauer's logo, BUT a centered S with the "now part" way up at the top of the logo line and running out to the right might do for a while. It flows with the top of the peg head and would be parallel. Wish I could draw on this typewriter with a TV screen, but oh, well...just a thought. Play around with all of what you have there.
You have plenty of time to finalize the inlay. It also gives you plenty of time (6 guitars) to think things over, maybe come up with something else. This is one of the things that you will and should take plenty of time to think about, like box shapes and P/H. I used to hang cutouts of box shapes on the wall and just look at them for a few months. Might do you good to stare at fonts too...
Took me years, and depending on who did the inlay cutting (mine were all cut by hand), sometimes I wasn't too satisfied. Take a look at the two in my photos. The top inlay is quite a bit more delicately cut.
So take your time, even years to think over the very important things if you are going to pursue this...
Jay, thank you! The top one was a 3rd or 4th iteration of the instrument. The lower was the last of a different instrument.
PostPosted: Sat Nov 18, 2017 6:24 pm
Last Name: Curtis
City: Mangrove Mountain
State: N.S.W
Zip/Postal Code: 2250
Looks great. Personally i would bring it back to centre it more on the headstock. IMHO it would look better balanced to the eye by placing the 'S' of the logo somewhere between the 1st and 2nd (or 5th and 6th) space of the machine heads.
PostPosted: Sat Nov 18, 2017 7:06 pm
It may be just the camera angle, but the peghead looks shorter than it did in the 4 1/2 build thread. I agree with Steve that centering the logo might balance things better, but beauty is in the eye of the beholder.
PostPosted: Sat Nov 18, 2017 11:03 pm
Btw the “s” is actually upside down. The real font has the big loop at the top, but I just didn’t like it like that
PostPosted: Sat Nov 18, 2017 11:04 pm
Thanks for the input. Plenty of time “I hope” to think about stuff like this.
PostPosted: Sun Nov 19, 2017 10:04 am
First name: D
Last Name: S
I like it.
It's readable to an audience when in playing position.
wah
Wah-wah-wah-wah
Wah
These users thanked the author dzsmith for the post (total 2): Braedyn (Sat Nov 25, 2017 9:56 pm) • Pmaj7 (Mon Nov 20, 2017 4:42 pm)
PostPosted: Sun Nov 19, 2017 10:22 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Most people don't read logos like all of us do. I might back up and look at it from a distance where you can't read it and see what the effect is. I think it looks good the way you have it, both vertically and horizontally.
Ed
PostPosted: Sun Nov 19, 2017 3:21 pm
First name: Cal
Last Name: Maier
City: Crossfield
State: AB
Just my opinion, but, why not just use the "S" and drop the now. The S looks good just on its own, but it seems the font part of the rest of your name "now", doesn't quite look right to my eye. Just my .02.
Cal
PostPosted: Mon Nov 20, 2017 9:45 am
Another option I’ve toyed around with is using an “s” like this one... on what I call a fretboard tongue. In other words a small section past the last fret that extends just into the soundhole area a little.
Like I did on this build —-
(Which looks better in the pic than it does in real life haha)
PostPosted: Mon Nov 20, 2017 9:48 am
Cal
By “front part” you mean where it should come out of the “S”?
PostPosted: Mon Nov 20, 2017 1:37 pm
First name: Jay
City: Bothell
State: Washington
I think he was referring to the font used for the "now" part of the logo.
That's a great looking guitar. I like the S on the rounded end of the fretboard. That's a nice touch. What kind of wood did you use for the neck? It looks like it has a prominent grain to it.
PostPosted: Mon Nov 20, 2017 1:58 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
Here's one I did a while back.
These users thanked the author Rodger Knox for the post: SnowManSnow (Mon Nov 20, 2017 2:23 pm)
PostPosted: Mon Nov 20, 2017 2:24 pm
Just a good ol’ hog neck. It has a Royal Lac finish which, I feel” really adds nice depth
PostPosted: Mon Nov 20, 2017 4:34 pm
Last Name: Beaver
City: Lake Forest
When I look at the logo I kind of think of a tree. You always have the option of enhancing that theme. with something like this.
Just an idle thought.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Nov 20, 2017 6:05 pm
You could also put it up on the 12th fret area and put some floral on the P/H.
PostPosted: Mon Nov 20, 2017 6:32 pm
Glad you guys are so creative ! I’m .... not so much yet ha.
