It is currently Tue Jul 15, 2025 9:20 pm
PostPosted: Fri Nov 03, 2017 2:48 pm
Year ago I got a back saw from LMII that would not cut straight down. I guess the teeth are not offset the same on each side. They exchanged it, but the replacement was also a little off. I have suffered with it, but now I want to get a better one. I am afraid to order one without some recommendations from users. Any recommendations?
PostPosted: Fri Nov 03, 2017 7:59 pm
http://www.badaxetoolworks.com/luthier.php
These users thanked the author Colin North for the post: wbergman (Sat Nov 04, 2017 5:37 am)
PostPosted: Fri Nov 03, 2017 8:23 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
This months FW has a review of 7 dovetail saws.
While the kerf may be a few thou. heavy on some, a few minutes with a stone would tune the kerf thickness.
The review gave best bang for the buck to the Veritas saw, with the kerf being .027.
For the cost of some of the saws, you could purchase a used table saw and a new fretting blade.
B
These users thanked the author Bri for the post: wbergman (Sat Nov 04, 2017 5:38 am)
PostPosted: Sat Nov 04, 2017 7:26 am
I use a Makita 50 tooth plain steel (not carbide) 3 3/8 inch circular saw blade mounted in a crude home made tablesaw. They are fairly cheap (about $10) and much faster than the average back saw.
These users thanked the author Clay S. for the post: wbergman (Sat Nov 04, 2017 8:57 am)
PostPosted: Sat Nov 04, 2017 8:44 am
First name: robin
Last Name: courtenay
City: andover
State: hants
Country: uk
I use the lmi manual slotting system which works great apart from the saw so i got the stewmac japanese fret saw and i found this to be a vast improvement,no binding cuts like butter highly reccomended.
These users thanked the author roby for the post (total 3): Pmaj7 (Sat Nov 04, 2017 1:32 pm) • dzsmith (Sat Nov 04, 2017 9:47 am) • wbergman (Sat Nov 04, 2017 8:57 am)
PostPosted: Sat Nov 04, 2017 12:14 pm
I've been using a Lee Valley Veritas saw (I forget which one) and used a diamond plate to take a little off the sides until I got a slot size I like. But, if I had the room, I would make an outfit like Clay S., 'cause that would make life a lot easier.
Brent
These users thanked the author bftobin for the post: wbergman (Sat Nov 04, 2017 3:24 pm)
PostPosted: Sat Nov 04, 2017 2:35 pm
First name: Theo
Last Name: Delaca
City: Fbks
State: Ak
Zip/Postal Code: 99712
I've got the manual LMII setup, I can't say that I like it all that much and will upgrade when I can...I had probably done two dozen fretboards and the saw didn't cut well, meanwhile I came across a video on YouTube on how to sharpen saws, well after about 10-15min with a saw file, the LMII saw cut like butter and way better than it ever had, even new.
These users thanked the author Theo for the post: wbergman (Sat Nov 04, 2017 3:24 pm)
PostPosted: Sat Nov 04, 2017 3:25 pm
Any advice on how to reset the teeth so it cuts straight down?
PostPosted: Sat Nov 04, 2017 5:59 pm
Got a link?
These users thanked the author Pmaj7 for the post: wbergman (Sat Nov 04, 2017 7:33 pm)
PostPosted: Sat Nov 04, 2017 7:29 pm
You could try stoning the offending side :
https://www.popularwoodworking.com/wood ... -saw-blade
These users thanked the author Clay S. for the post: wbergman (Sat Nov 04, 2017 7:35 pm)
PostPosted: Sat Nov 04, 2017 10:14 pm
First name: Mark
City: Concord
Very cool Clay! I have an old small benchtop tablesaw which this could work with a 1/2" to 15mm bushing. Which Makita blade are you using and how wide is the kerf?
These users thanked the author Mark Fogleman for the post: wbergman (Sun Nov 05, 2017 4:24 am)
PostPosted: Sat Nov 04, 2017 10:30 pm
Last Name: Sollod
+1 stewmac japanese fret saw
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: wbergman (Sun Nov 05, 2017 4:23 am)
PostPosted: Sun Nov 05, 2017 2:38 am
First name: Theo
Last Name: Delaca
City: Fbks
State: Ak
https://m.youtube.com/watch?v=_fNosQU1Ujg , I think this was the one.
This was my intro to sharpening saws, it happened that I had a little saw sharpening file floating around my shop and it worked great, but I'm not knowledgeable enough to offer any real advice. It is something I hope to learn, when my tool budget allows, a saw set and some more files are somewhere mid-list
Edit :lol: maybe not my total intro to sharpening, while a bit different I forgot about the hundreds, maybe thousands of times I've sharpened chainsaw chains, and I've done it all kinds of ways. The big ticket is that the teeth are the same on both sides. I'm sure it all translates
These users thanked the author Theo for the post: wbergman (Sun Nov 05, 2017 4:23 am)
PostPosted: Sun Nov 05, 2017 3:21 am
First name: nigel
Last Name: forster
City: Newcastle upon tyne
Zip/Postal Code: ne12at
Country: england
Gary Carter makes a great little saw that uses hacksaw blades. So the blades can be replaced. He does several saws each with a different depth of cut. Great design, I have a pair of them. I use them to check the slot depth but you could use them for fretting. He has some good tools on his site.
https://www.guitarbuilding.solutions/pr ... ar-fretsaw
I find some of his stuff is well made but sometimes overcomplicated, mind, his string spacing guide is great too:
https://www.guitarbuilding.solutions/pr ... cing-guide
nigel
http://www.theluthierblog.com
These users thanked the author nkforster for the post: wbergman (Sun Nov 05, 2017 4:23 am)
PostPosted: Sun Nov 05, 2017 8:15 am
//www.ebay.com/itm/Makita-3-3-8-Plywood-Saw-Blade-For-Cordless-Saws-792299-8/292309672794?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20160908110712%26meid%3Dfcf41b7545b34235802af640bfc1feb1%26pid%3D100677%26rk%3D2%26rkt%3D21%26sd%3D291862271905&_trksid=p2385738.c100677.m4598
I haven't measured the kerf, but Stew Mac wire works O.K. with it.
These users thanked the author Clay S. for the post: Mark Fogleman (Sun Nov 05, 2017 9:00 am)
PostPosted: Sun Nov 05, 2017 12:18 pm
Am I correct that the teeth are further out on the side that the blade/slot drifts towards? So if my first attempt at correct this is to stone a little off, then I stone the side to which the blade drifts?
PostPosted: Sun Nov 05, 2017 3:41 pm
Stoning will reduce the aggressiveness on the cut so - yes- stone the side it is drifting too. But don't get carried away with it. As with people , if it's too stoned it won't work too well. :lol:
These users thanked the author Clay S. for the post: wbergman (Sun Nov 05, 2017 5:31 pm)
Users browsing this forum: Bing [Bot] and 19 guests
