It is currently Mon Jul 21, 2025 6:21 am
Post new topic Reply to topic  [ 78 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Sep 28, 2017 10:52 am
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
If the nut fits snug in the slot, is any glue necessary?
B
PostPosted: Thu Sep 28, 2017 11:36 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I only glue the ones I give to clients. Mainly to keep them from falling out when they change strings. It seems to me there is a lot of force keeping them in when the guitar is strung up.
These users thanked the author johnparchem for the post: Bri (Thu Sep 28, 2017 8:23 pm)
PostPosted: Thu Sep 28, 2017 12:46 pm
B
My nuts always fitted snuggly in the slot but I used a drop of glue anyway for insurance. I also agree with john that customers don't like having their nuts fall off...... To the uninitiated one would tend to want to go to the ER....
These users thanked the author Hesh for the post: Bri (Thu Sep 28, 2017 8:24 pm)
PostPosted: Thu Sep 28, 2017 12:48 pm
david farmer wrote:
You'd think every once in a while you'd get a little cocaine or a message for help getting out of a sweatshop or something. But every time I crack one of these fortune cookies off a neck...........nothing. idunno
That's hysterical!!!!
I found a fungus coated green toe nail under a saddle once..... Yum, yum.....;)
PostPosted: Thu Sep 28, 2017 12:49 pm
B
In my case, there is no slot. Nut just butts up against FB and sits on top of unlacquered bit of headstock.
Recent trade secrets video I saw Dan used a little shellac.
PostPosted: Thu Sep 28, 2017 8:57 pm
Last Name: McDonald
So, basically, if you wish to avoid awkward servicing,glue your nut to the shaft?
These users thanked the author Bri for the post: Michaeldc (Sat Sep 30, 2017 12:35 pm)
PostPosted: Thu Sep 28, 2017 9:43 pm
Last Name: Farmer
City: Durango
State: CO
Alex Kleon wrote:
Have to wonder why they don't use a couple of finish nails to hold them in place while the epoxy sets.
Alex
Alex, they may have run out of nails because they used them all up on their Reso.
Hesh, here are some more under saddle "tone-nails" and a biscuit to go with them. ;)
In a high vibration application like this, of course, ring-shanks would be prudent. [:Y:]
These users thanked the author david farmer for the post: Hesh (Fri Sep 29, 2017 4:24 am)
PostPosted: Fri Sep 29, 2017 4:30 am
I deal with clients frequently who are beside themselves because their nuts fell off. It's upsetting and since they don't know what to expect and didn't expect to have their nuts fall off they can feel a real sense of panic.
Seagull guitars which are great values and really nice guitars for the money IME are well known for losing their nuts since there is no back stop or head plate for the nut installation/retention.
Even if your nuts friction fit well wood moves, shrinks, expands, etc. and stuff changes over time making that single drop of glue on the end of the fret board a pretty good idea.
So just like when Sean Connery asked for just "one single ping" in Hunt for Red October just one single drop of CA on the end of the fret board is a pretty good idea. Just one drop, no more, no less. ;)
I avoid accelerator if it's a bone nut in so much as it can discolor the slots for a few days before it goes away. No one likes to have blueish, discolored nuts.
These users thanked the author Hesh for the post: Bri (Fri Sep 29, 2017 9:36 am)
PostPosted: Fri Sep 29, 2017 12:20 pm
If there is a slot, make it tapered so it is slightly smaller on the floor side. Taper the nut, too. Then it stays in place, unless someone changes strings with the guitar upside down. My Kohno is built this way, and it is not uncommon among high end classical builders.
These users thanked the author wbergman for the post (total 2): SteveCourtright (Fri Sep 29, 2017 1:31 pm) • Hesh (Fri Sep 29, 2017 12:23 pm)
PostPosted: Fri Sep 29, 2017 1:22 pm
Last Name: McDonald
Well that got me thinking..... why not taper it so it needs to slide in from the side, dovetail like?
Probably a bit of unecessary overkill, I need to quit overthinking.
These users thanked the author Bri for the post: Hesh (Sat Sep 30, 2017 7:48 pm)
PostPosted: Sat Sep 30, 2017 10:30 am
I'm surprised that the people who feel that the neck contributes a lot to the sound of the guitar haven't recommended a well glued in nut.
I do a couple of drops of superglue, so a light rap with a mallet will break it loose.
"Well that got me thinking..... why not taper it so it needs to slide in from the side, dovetail like?"
That might spell disaster for the inattentive repairman! oops_sign
These users thanked the author Clay S. for the post: Hesh (Sat Sep 30, 2017 7:48 pm)
PostPosted: Sat Sep 30, 2017 11:02 am
I do feel that the neck contributes a lot to the sound of the guitar and a well fitted nut is an essential part of that.
Having said that, most of the nut's contribution seems to come from the base of the nut having good contact with the nut shelf, i.e. flat base on a flat nut shelf, similar to a saddle.
A spot of glue. TB, hide, CA, whatever against the FB end does not interfere in this.
Gluing it to the shelf will not contribute much if anything, and in my case it seems the nut was possibly held off the nut shelf by the glue "pad" with the ends hanging in the air a bit.
And yes to your comment about inattention on the part of the hypothetical but very busy repairman.
These users thanked the author Colin North for the post: Hesh (Sat Sep 30, 2017 7:48 pm)
PostPosted: Sat Sep 30, 2017 6:50 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
I guess the obvious no-no is telling your wife that you just bought (insert your choice of: wood, tools, machinery, etc) when she has been bugging you to do the (insert your choice of: bathroom, kitchen, family room reno, painting, flooring, etc).
I'm shopping for a drum sander, but our powder room renovation will be done first, and my wife is grinding me way harder than any of my customers do!
Alex
These users thanked the author Alex Kleon for the post (total 2): whiskywill (Fri Oct 06, 2017 6:50 am) • Hesh (Sat Sep 30, 2017 7:47 pm)
PostPosted: Sat Sep 30, 2017 7:06 pm
Last Name: Farmer
City: Durango
State: CO
Alex
I think your lookig for "the great big honey-do thread" Alex.
Sent from my SM-J727V using Tapatalk
These users thanked the author david farmer for the post: Hesh (Sat Sep 30, 2017 7:47 pm)
PostPosted: Sat Sep 30, 2017 7:56 pm
I've worked on dovetailed in nuts before and they can be removed but there is far more risk of finish damage since they have to be driven out the side and some manufacturers finish the nuts in place. Martin does this and some others too.
I'm not going to get into subjective tonal matters for the obvious reason but a drop of CA on the end of the fret board holding a bone nut firmly in contact with the bottom of the nut channel is not going to be something that anyone who is not insane can discern any tonal differences. The nut bottom is flattened on a surface plate (standard fare) and the nut channel was flattened with a flat file. The nut is being pressed downward into the channel by string pressure. Pretty good contact if you ask me.
I don't think that even with a very minimal amount of glue in there and blind listening tests anyone would ever be able to say who's glued and who's not.
The primary reason for avoiding any glueless implementation of a nut installation is serviceability AND ease of use for the clients. Nuts need to be removed (until the rest of the Lutherie world gets tooled up for composite dental fillings...) and players have heart attacks when their nuts fall off in a dark room and Killer the Yorkie grabs the sucker and runs out of the room..... There was an episode of the Sopranos where Tony dreamed, oh never mind this is a G rated forum..... But you just can't have nuts falling out....
PostPosted: Sun Oct 01, 2017 6:42 pm
"I'm shopping for a drum sander, but our powder room renovation will be done first, and my wife is grinding me way harder than any of my customers do!"
Alex, you're looking at the situation as a problem, and not as an opportunity. You just need to find a reason you need a drum sander to renovate the powder room. pizza
These users thanked the author Clay S. for the post (total 2): Alex Kleon (Mon Oct 02, 2017 6:03 am) • Bryan Bear (Sun Oct 01, 2017 8:29 pm)
PostPosted: Mon Oct 02, 2017 11:04 am
And that, my friends, is the way it's done.
PostPosted: Mon Oct 02, 2017 11:07 am
First name: Brad
Last Name: Combs
Haha... I'm pretty sure you have to scuff sand drywall sheets to give them some tooth so the mud will stick. Who wants to sand all that by hand?
PostPosted: Mon Oct 02, 2017 11:15 am
Last Name: Farmer
City: Durango
State: CO
Drywall for a powder room?
No way!
Italian Spruce wainscoting. is what she needs.
These users thanked the author david farmer for the post (total 2): Bryan Bear (Mon Oct 02, 2017 2:06 pm) • bcombs510 (Mon Oct 02, 2017 11:17 am)
PostPosted: Mon Oct 02, 2017 1:41 pm
First name: Alex
Last Name: Kleon
City: Whitby
No way!
Book matched! [:Y:]
Alex
These users thanked the author Alex Kleon for the post: david farmer (Mon Oct 02, 2017 9:38 pm)
PostPosted: Mon Oct 02, 2017 9:33 pm
Last Name: Farmer
City: Durango
State: CO
OK, if this is going to be the "great big" don't do thread, we have to get back on track.
I'll try to offer matching funds from my photo stash as incentive for others.
There must be more out there. Just weed em' out for too much sensitive information.
In celebration of the current bridge caul thread, I offer this sequence for gluing a bridge on a $300 Guitalele. Straight from the factory:
1. apply glue.
2. drive the screws through the bridge into the bridge plate.
3. put a clamp on the center brace and crank the holy living cr@p out of it! until you feel the pad bottom out, firmly, on the underside of the bridge.
oops_sign
These users thanked the author david farmer for the post: Hesh (Mon Oct 02, 2017 11:17 pm)
PostPosted: Tue Oct 03, 2017 6:27 am
Here's something that we see pretty commonly, damage from a saddle that is either too tall, doesn't fit well and wants to tip forward, and/or too much rotation on the bridge with string tension. This one was all of the above.
This guitar belongs to a Priest and is used for worship services. It had mediums on it and the distance from the strings to the top was over 5/8th". The saddle, bone was a loose fit and someone had stuck some EIRW veneer in the front of the saddle slot to take up some of the extra slop.
In addition the bridge pins, you know those cheap, genuine imitation pl*stic, slotted, mass produced pins had already damaged the bridge plate and the string balls were pulling up through the top.
The fix for us was to install a maple bridge plate cap on the existing maple bridge plate and route and true up the saddle slot with our Collin's Saddle mill so that a proper saddle with consistent dimensions AND now with individual string compensation would fit well with no tipping.
In the words of the great Mick Jagger, so I did...... ;)
Anyway the moron of the story is tall saddles lead to repair bills and having to put up with people like me to get your ax fixed...;)
These users thanked the author Hesh for the post: david farmer (Tue Oct 03, 2017 7:10 pm)
PostPosted: Tue Oct 03, 2017 6:29 am
Oh yeah, see the pins pulling upward especially the low e? That's a tell tale of bridge plate damage from cheap, genuine imitation pl*stic, mass produced slotted pins. The string balls begin to migrate into the top and sometimes.... beyond and we can see this as the pins no longer seat.
PostPosted: Tue Oct 03, 2017 7:23 pm
Last Name: Farmer
City: Durango
State: CO
It can be hard to convince hard core brand believers that the fluted pins put in by their beloved company are a bad Idea. idunno
When your sliding a spatula under the fingerboard extension during a neck re-set, and you encounter resistance, maybe check inside and see if you're up against the transverse brace! oops_sign
Some may disagree, but I feel a glue that releases with heat here is good thing.
These users thanked the author david farmer for the post: Hesh (Tue Oct 03, 2017 10:17 pm)
PostPosted: Thu Oct 05, 2017 5:03 pm
If rigid sides and a stiff neck are good for tone why not take it all the way. Oh yeah, beef up the upper bout, no resets here.
These users thanked the author Terence Kennedy for the post: Hesh (Fri Oct 06, 2017 6:35 am)
