It is currently Thu Sep 18, 2025 12:11 pm
 Post subject: z poxy + blak color
PostPosted: Sun Aug 20, 2017 11:22 am
Last Name: McNerney
City: Ottawa
State: On
Country: Ca
Can I mix some black powdered tint with z poxy finishing resin?
Mike McNerney
 Post subject: Re: z poxy + blak color
PostPosted: Sun Aug 20, 2017 12:16 pm
First name: Danny
Last Name: Vincent
Yes. You might want to just tint the first one or two coats. Depending on how many coats you do.
PostPosted: Sun Aug 20, 2017 5:45 pm
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I do not have the answer to mixing black with zpoxy, I suspect it would not be a problem. I would like to ask why? I use zpoxy a lot but it is a real pain to use as pore filler. I put up with the pain for zpoxy's very transparent but amber cast it gives to the wood. If I was not looking a transparent fill I would switch to an easy to apply and clean filler like pore-o-pac or other easy to apply fillers.
PostPosted: Thu Aug 24, 2017 7:10 am
First name: Glenn
Last Name: LaSalle
City: Saint Petersburg
I am working on a non-guitar project, a live edge coffee table, and finishing it just as I do my guitars. I used Zpoxy to fill the cracks and voids, since I had it unhand. I read not to add black dye to epoxy, as it will tend to have a bluish tint. I added Medium brown dye, and like the way it came out - plenty dark enough, blackish..
Glenn
PostPosted: Thu Aug 24, 2017 9:27 am
Last Name: shelton
City: Alsea
State: Oregon
Zip/Postal Code: 97324
Permanent India ink (not water based) works great with regular epoxy although I haven't tried it with Zpoxy. We use it in 5 minute epoxy to fill the tiny gaps under the fret ends.
