It is currently Tue Sep 16, 2025 9:24 am
 Post subject: Grain Filling Ziricote
PostPosted: Thu Aug 03, 2017 3:42 am
First name: Gary
Last Name: Leddington
Hi Folks
My current build is a Ziricote Dread and i'm wondering if anyone has any tips for grain filling? I hear that normally Ziricote doesn't need much filling but this set has some pores that def. need some work.
Normally i would just do the whole thing in a black(ish) waterbased but the problem is that this set has sapwood sections as well as the usual dark brown and i think black over the sapwood would look odd.
I thought about zpoxy or so but really dont want to deal with the sanding involved.
I also thought about aqua coat... but have heard some bad things???
Any tips would be great.
Thanks!
FTL
www.leddingtonguitars.com
PostPosted: Thu Aug 03, 2017 5:09 am
ZExpoy - put on properly and there's minimal sanding.
https://www.youtube.com/watch?v=YYHxMg7n9cI
PostPosted: Thu Aug 03, 2017 6:54 am
One of my last was Ziricote and it was filled with Zpoxy. I used the foam brush and hairdryer approach that someone suggested on the forum and found the sanding was much more manageable than with the squeegee pproach.
PostPosted: Thu Aug 03, 2017 9:10 am
First name: Gary
Great...
Thanks for the tips....
I found some z-poxy finishing resin in a local store will give it a whirl.
FTL
PostPosted: Thu Aug 03, 2017 11:32 am
First name: Brad
Last Name: Combs
Three tips I can give for z-poxy....
1) Get the etore squeegee that Todd talks about in the video. They sell it at Lowe's in the broom and mop section. Get the wide one and cut the sleeve and wiper in half. Now you have two. Get some extra wipers if you want.
2) If the neck is not already attached, come up with some kind of holder for the body. In the video, Todd has a nice stick. I just used a dowel with threaded rod epoxied into it. It's important that you have a way to apply pressure with the squeegee without having to hold the body at the same time.
3) Follow this process (the youtube video) to the letter and you'll have success.
Good luck!
Brad
PostPosted: Thu Aug 03, 2017 3:20 pm
Last Name: Beaver
City: Lake Forest
My first choice would be epoxy. It pops the grain the most of any filler I've seen.
A very close second is CA. It pops the grain almost as well and if put on properly doesn't take much sanding. It also has the advantage of minimizing cracking down the road when you use thin CA to start the fill.
But, you need to consider what you are planning for a top coat, to be sure there are no compatibility issues.
Joe Beaver
Maker of Sawdust
PostPosted: Fri Aug 04, 2017 12:40 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
I have become a fan of West Epoxy systems. Much fussier than Z Poxy when mixing. But it adds no color. And I like that. I'll be using it on Zircote myself. Z Poxy is a better option if you are inexperienced with epoxy since mixing is not an issue, and cost is low. I'd also recommend using a sealer before applying.
West System: 105/207
Sealer: Prestec 58x1 (2 part) (http://www.simteccoatings.com)
Do not spray sealer if you do not have proper venting. Wipe on is just as good. It can be used on top as well to prevent grain rise under waterborn finish. This sealer will prevent epoxy from lifting color and spreading it around.
PostPosted: Fri Aug 04, 2017 1:37 pm
I like ArtResin because it's water clear and 1:1 mix but have only used it with Enduro Var.
PostPosted: Fri Aug 04, 2017 6:15 pm
Last Name: Beaver
City: Lake Forest
Regarding Epoxy, I have become a fan of System Three Clear Coat. It is good stuff. It does cure a little slower than some but they do have an accelerator which I have not yet used.
West System is good also, and zpoxy works well when you are looking for a more amber look. I have even dyed finishing resin a time or two with alcohol based colors when needed
Joe Beaver
Maker of Sawdust
PostPosted: Fri Aug 04, 2017 9:11 pm
City: Tyler
Another +++ on the systems three. Incredible stuff.
PostPosted: Sat Aug 05, 2017 9:01 am
What if any finishes would be incompatible with epoxy?
PostPosted: Sat Aug 05, 2017 9:27 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
SYSTEM 3 SILVERTIP ?? OR system 3 with silica I use the medium grade for longer setup time
PostPosted: Sat Aug 05, 2017 3:08 pm
Last Name: Beaver
City: Lake Forest
Regarding finishing resin compatibility, I've only used Ktm water based products and nitro (Cardinal) and they work fine. I've been told Royal Lac does not
A friend of mine used zpoxy with 2 part polyurethane. 2-3 months in now and it is doing fine
Joe Beaver
Maker of Sawdust
PostPosted: Sat Aug 05, 2017 4:00 pm
First name: Stephen
Last Name: Foss
State: Colorado
Royal lac should not be used in direct contact with epoxy, but several layers of regular shellac between the two solves this issue. Thats been my experience anyway.
PostPosted: Sat Aug 05, 2017 10:57 pm
City: Escondido
Zip/Postal Code: 92029
I've not had any issues between Royal Lac and epoxy. I vaguely remember one person posting that the finish crazed over epoxy, but I also recall people complaining about crazing who were spraying. I don't know if the problem was the epoxy or the way it was being sprayed.
Regardless, I'm sure a seal coat of shellac is reasonable and economical insurance.
PostPosted: Sun Aug 06, 2017 5:32 am
First name: Gary
Thanks again fellas.
I've used zpoxy finishing resin and it worked out great...
I'm in Europe so no Royal Lac or Cardinal for me... I am using Dartfords nitro... After sanding down the zpoxy I shot a couple of few sealer coats. I will begin lacquering over the coming days.
FTL
These users thanked the author Fasterthanlight for the post: Colin North (Mon Aug 07, 2017 2:57 am)
PostPosted: Sun Aug 06, 2017 7:54 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
You would almost have to go out if your way to screw up with Z Poxy. Very forgiving. I wish there was a clear version.
Users browsing this forum: Gasawdust and 24 guests
cron
