It is currently Mon Sep 15, 2025 10:33 am
PostPosted: Mon Jul 03, 2017 1:39 pm
Didn't fine much in the Uke section of this site so thought I'd ask here. What kind of interesting setups do you use to glue up a Uke bridge? I don't have a clamp that will fit in the tiny sound hole of this little fella and I've got all kinds of clamps. I thought about bolting it through some pearl dots or something but I can't imagine how I would ever get the bolts aligned before the glue dries, if ever!
PostPosted: Mon Jul 03, 2017 2:14 pm
Last Name: Reed
City: Stowmarket
State: Suffolk
Zip/Postal Code: IP14 2EX
Country: UK
You can make a simple clamp from bits of wood and a couple of bolts with wing nuts.
Or, as I increasingly do, use hot hide glue and a rubbed joint.
These users thanked the author profchris for the post: Lonnie J Barber (Tue Jul 04, 2017 3:11 pm)
PostPosted: Mon Jul 03, 2017 2:44 pm
I was wondering about that as well, so you just simply used a rubbed joint on a uke?
PostPosted: Mon Jul 03, 2017 3:08 pm
Last Name: Farmer
City: Durango
State: CO
These poney deep reach clamps are available at a lot of hardware stores. On some, I've cut material off the back with a hacksaw so they would have more room in the sound hole.
These users thanked the author david farmer for the post: Pmaj7 (Mon Aug 08, 2022 11:12 am)
PostPosted: Mon Jul 03, 2017 3:53 pm
That's how we do it too David. Hope you are doing great too!
These users thanked the author Hesh for the post: david farmer (Mon Jul 03, 2017 7:30 pm)
PostPosted: Mon Jul 03, 2017 4:53 pm
First name: Aaron
Vacuum. Got pony clamps too, and used to use them.
PostPosted: Mon Jul 03, 2017 5:00 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
Sadly, the Pony clamps(Jorgensen) are no longer made.
There may be old stock still on shelves, but if you see any and need them, grab em.
They made a great product at a reasonable price.'
PostPosted: Mon Jul 03, 2017 5:45 pm
First name: Brad
Last Name: Combs
Like Aaron, I made a small vacuum attachment and used the membrane and attachment hardware from LMI. Of course if you don't have vacuum already it's a hefty investment.
PostPosted: Mon Jul 03, 2017 7:21 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
I use vln clamps from the 80/s made by condit mfg. I/ve also gotten clamps for baritone ukes at HF, they are hvy and cheap. You can also make your own using wooden threaded dowels and a 1/2in or 5/8 th inch tap and die for making threaded wooden dowels woodcraft or e bay.
PostPosted: Mon Jul 03, 2017 7:30 pm
Last Name: Farmer
City: Durango
State: CO
https://www.amazon.com/Wilton-42520-Deep-Reach-C-Clamp-Maximum/dp/B005CZC37G/ref=pd_sim_469_5?_encoding=UTF8&pd_rd_i=B005CZC37G&pd_rd_r=1867RHVWSNDAXRX9P2PE&pd_rd_w=lPHVK&pd_rd_wg=1p3aA&psc=1&refRID=1867RHVWSNDAXRX9P2PE
Identical casting as the Pony's, but these come with an, "oscillating head"? hmmm........... beehive
These users thanked the author david farmer for the post: ernie (Mon Jul 03, 2017 8:53 pm)
PostPosted: Mon Jul 03, 2017 9:11 pm
First name: Aaron
If you build a venturi based, its not that bad. But you're right- the parts add up quickly. Still designing my vacuum bed for tops and backs. Its going to be SO COOL!
Whenever it gets done. . . Its still in my head.
These users thanked the author Aaron O for the post: bcombs510 (Mon Jul 03, 2017 9:19 pm)
PostPosted: Tue Jul 04, 2017 6:10 am
A rubbed joint with hot hide glue will work fine. For something as small as a soprano uke another way to do it is to fit a temporary block between the top and back under the bridge(like a violin sound post) and use a large clamp (and cauls) to clamp the whole body. Only moderate pressure is needed for gluing the bridge on the low tension strings of a soprano tuned to standard pitch (21 lbs. total).
PostPosted: Tue Jul 04, 2017 7:52 am
Thanks for all the info... Those Pony or Pony clone clamps look like what I'm after.
PostPosted: Tue Jul 04, 2017 10:12 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I had the clamp in the forefront, and I bought the clamp that is installed already at Harbor Freight:
https://www.flickr.com/photos/ruby1638/27289929665/in/album-72157662606115293/
Ed
PostPosted: Tue Jul 04, 2017 11:54 am
The HF one works and is cheap but heavy. The pony is much nicer!
Sent from my SM-G930T using Tapatalk
PostPosted: Tue Jul 04, 2017 2:35 pm
Last Name: Farmer
City: Durango
State: CO
Just a heads up. I have one of those china versions (upper left) and the casting is fully hard. Cutting or drilling it is untenable with conventional bits.
The Wilton/pony castings cut/drill like butter. Much more practical for my purposes. The lower one is a Pony modified to work in most soprano ukes.
I bet we can get two pages of discussion on a single size C clamp if we try. :)
PostPosted: Wed Jul 05, 2017 11:49 am
First name: Wayne
Last Name: Brown
City: Huntersville
Zip/Postal Code: 28078
I use violin clamps that came from International Violin. They come in different throat lengths.
David Farmer's first pic looks like one of the violin clamps.
PostPosted: Mon Jul 31, 2017 6:33 pm
I ended up getting these C-Clamps from Stewmab and they barely made the fit, but good enough. It was impossible to get a clamping caul under there so I just squeezed the bracing a bit.
Users browsing this forum: No registered users and 75 guests
