It is currently Fri Aug 22, 2025 2:49 am
PostPosted: Tue Mar 21, 2017 10:06 am
First name: Daniel
Last Name: Petrzelka
State: Washington
I'm catching up posting documentation of one of two 00's I've been working on. Both are built on Ken's KMG 00 12 fret template in the mega-mold. This combo has worked great for me.
Sitka top
Red spruce bracing
Ziricote Back and sides
Ebony binding - likely with b/w/b purfling and Blue Pau bling.
Rosette - 3 ring, with Blue Pau
Slot head
Waverly brass 3 on a plate with ebony tuner
Pyramid bridge
1 3/4 nut
First, make sure the humidity is right on
PostPosted: Tue Mar 21, 2017 10:08 am
First name: Daniel
State: Washington
PostPosted: Tue Mar 21, 2017 10:11 am
First name: Daniel
State: Washington
Homemade bending jig, with controller taken from a glass kiln I built years earlier.
PostPosted: Tue Mar 21, 2017 10:14 am
First name: Daniel
State: Washington
Resawing brace stock - .25" throughout. This saw was rescued from a friend - the tension block had broken, and it needed a new home. It's about time I invest in a new blade though.
PostPosted: Tue Mar 21, 2017 10:15 am
First name: Daniel
State: Washington
More to come - just need to get photos uploaded.
PostPosted: Tue Mar 21, 2017 10:27 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I am not sure wood and plane porn are allowed on this site. I may have to report it. Looks like it will be a great looking guitar.
These users thanked the author johnparchem for the post: dpetrzelka (Tue Mar 21, 2017 10:55 am)
PostPosted: Tue Mar 21, 2017 11:03 am
First name: Daniel
State: Washington
Thanks John - If I'm going to break the rules, I might as well keep going.
PostPosted: Tue Mar 21, 2017 11:07 am
First name: Daniel
State: Washington
I prefer to hand plane the radius in my top and back braces. Moving forward I'm going to build a simple jig to make this step just a little quicker and more precise.
And gluing up the x-brace. Coming from the KMG process, I still use card stock radius cauls. They work really well, and I make up extras or different radii whenever needed.
For go-bars I'm using simple oak strips, with lightly rounded edges.
PostPosted: Tue Mar 21, 2017 11:11 am
First name: Daniel
State: Washington
A 16" fretboard radius block works great for putting a gentle radius on my back strips. I run masking tape down both outside edges of the block, protecting the back from the abrasive. When the edges of the block touch the back I'm done.
I knew I held on to all of these old baseball cards for a reason - protecting the back reinforcing strip while shaping the back braces.
PostPosted: Tue Mar 21, 2017 11:13 am
First name: Daniel
State: Washington
Blue Pau inlay for the rosette, purfling, headstock and the fretboard.
PostPosted: Tue Mar 21, 2017 11:15 am
First name: Daniel
State: Washington
How do you build a guitar?
Simple. Just remove everything that isn't essential.
Lots of wood removed from the top bracing during the voicing process.
These users thanked the author dpetrzelka for the post: Pmaj7 (Tue Nov 13, 2018 3:53 pm)
PostPosted: Tue Mar 21, 2017 11:17 am
First name: Daniel
State: Washington
The rim is ready.
The top goes on first so I can still make final voicing adjustments before closing the box.
Getting close on the bracing, just needs the final cleanup and sanding.
PostPosted: Tue Mar 21, 2017 11:20 am
First name: Daniel
State: Washington
Pressing frets before gluing the board on the neck. This makes fret installation really easy, but I'm rethinking this approach as I study more. (Hesh, take it easy, I'll come around)
PostPosted: Tue Mar 21, 2017 11:21 am
First name: Daniel
State: Washington
Label applied and back cleaned up prior to closing the box.
PostPosted: Wed Mar 22, 2017 7:00 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Very nice work. Great wood selection, and pretty rosette.
Ed
These users thanked the author Ruby50 for the post: dpetrzelka (Wed Mar 22, 2017 7:03 pm)
PostPosted: Wed Mar 22, 2017 8:11 pm
Last Name: Parchem
City: Seattle
State: Wa
Very nice, phenomenal pictures as well.
These users thanked the author johnparchem for the post: dpetrzelka (Wed Mar 22, 2017 9:50 pm)
PostPosted: Wed Mar 14, 2018 10:44 pm
First name: Daniel
State: Washington
PostPosted: Wed Mar 14, 2018 10:45 pm
First name: Daniel
State: Washington
I learned a few things from Robbie O'Brien's French Polishing videos...
First name: Daniel
State: Washington
Out in the wild...
PostPosted: Wed Mar 14, 2018 10:48 pm
First name: Daniel
State: Washington
And here is an image from the evening I finally presented, literally, the finished Ziricote 00-12 to its final owner.
This was at a design retreat we do annually. I spent some time speaking about and demonstrating tap tones of tonewoods, their characteristics and how they can be combined for different tonal effect before suggesting that its easier to understand in a completed instrument. I then presented the finished guitar and invited a number of friends from the audience to demo it for the group.
PostPosted: Thu Mar 15, 2018 6:58 pm
Nice guitar! I like doc-u-builds. Wish more people did them. I find it most valuable when folks share their techniques for various processes, I've learned a lot that way.
These users thanked the author SteveSmith for the post: dpetrzelka (Thu Mar 15, 2018 7:25 pm)
PostPosted: Tue Nov 13, 2018 1:17 pm
First name: Daniel
State: Washington
Fixed all of the broken image links - thanks all for the heads up. Things should look good again.
PostPosted: Tue Nov 13, 2018 3:56 pm
I like it, just get a chunk of wood and remove all the non guitar part!
Great build log and pics too, looks like a beauty!
New username, same ole Pat Macaluso!
These users thanked the author Pmaj7 for the post: dpetrzelka (Tue Nov 13, 2018 4:03 pm)
