It is currently Wed Aug 13, 2025 5:04 pm
 Post subject: pore fill?
PostPosted: Sat Mar 04, 2017 10:26 am
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
Zip/Postal Code: 57106
I just finished my 3rd coat of epoxy and it is all level but still can see the grain a little bit. It almost seems like the 3rd coat never helped. It looks the same as the second coat did. They are almost there i think. I feel like when I start spraying sealer they will fill in. Am I right or do they need to be completely level now
These users thanked the author dertien616 for the post: Tim McKnight (Wed Mar 08, 2017 9:45 pm)
 Post subject: Re: pore fill?
PostPosted: Sat Mar 04, 2017 11:15 am
City: Tyler
Apply some naphtha on the surface and leave it wet. Look at it at an angle in the light and see if you see the pores. With three coats of epoxy, you should see none, unless your technique for applying the epoxy needs some work. Sealer may fill some in but is more work than epoxy. You'll have to really build and level a lot.
PostPosted: Sat Mar 04, 2017 11:20 am
First name: Brad
Last Name: Combs
Also, make sure to work the epoxy in a couple directions, not just side to side or top to bottom.
PostPosted: Sat Mar 04, 2017 11:46 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
If you are sanding back to wood (not a bad technique) you can open new pores. I leave a thin layer of epoxy on the wood.
PostPosted: Sat Mar 04, 2017 12:16 pm
Last Name: Beaver
City: Lake Forest
You didn't mention if you have level sanded the epoxy yet? Or maybe sanding back to bare wood?
Joe Beaver
Maker of Sawdust
PostPosted: Sat Mar 04, 2017 12:55 pm
My preference is to leave a thin layer of epoxy -- sanding back to bare wood for me is a bit of a hassle plus as mentioned, there is a tendency to pull out the filler as well as the reveal of more/new pores during the sanding process.
Ken Cierp
PostPosted: Sat Mar 04, 2017 1:49 pm
First name: Thomey
Last Name: Dertien
City: Sioux Falls
State: SD
I am leaving a thin layer. I actually just sanded some more and it seams like they are going away. Doesn't seem right
PostPosted: Sat Mar 04, 2017 2:05 pm
Last Name: Beaver
City: Lake Forest
I've noticed that also with epoxy. (if, 'it seams like they are going away', means the pores are disappearing) What looks like pores can disappear with a good level sanding.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Mar 07, 2017 10:08 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Those who "leave a thin layer" - how do you know when you have that?
Ed
PostPosted: Tue Mar 07, 2017 10:23 pm
Sand throughs jump right out and are easy to see.
Ken Cierp
PostPosted: Tue Mar 07, 2017 11:23 pm
Online
It may be that you need to thin the epoxy a bit with denatured alcohol. I was having some trouble filling my latest guitar, and thinning the epoxy was the solution. I probably thinned it 30%, but just eyeball and feel it out.
PostPosted: Wed Mar 08, 2017 8:11 am
City: Tyler
Ed
I just sand the ridges left from the razor blade applicator and lightly sand the rest once it is level.
PostPosted: Wed Mar 08, 2017 10:35 am
Last Name: Parchem
City: Seattle
State: Wa
One more thought. Zpoxy is thick and it is really easy to bridge pores instead of filling them. Those pores can show up as the thin cap sags. Also they will open during level sanding. The zpoxy needs to be forcibly pushed or smushed into the pores. WHile I am working in zpoxy in an area I first want to see small bubbles coming up, showing my technique is forcing the zpoxy in the pores, then I want to see the bubbles stop, the pores are filled. James Orr suggestion of diluting would make it easier to fill the pores also some warm up zpoxy to make it flow better.
Instead of sanding down to a thin layer, I sand until level, often to wood in places. I then use a cotton rag to wipe on a diluted last coat of epoxy covering any exposed wood.
These users thanked the author johnparchem for the post: Alex Kleon (Wed Mar 08, 2017 10:20 pm)
PostPosted: Wed Mar 08, 2017 3:32 pm
Ditto
Ken Cierp
Users browsing this forum: DennisK, James Orr and 44 guests
