It is currently Wed Aug 13, 2025 9:32 pm
 Post subject: CA and Mahogany
PostPosted: Mon Feb 20, 2017 2:20 pm
Online
First name: Brad
Last Name: Combs
Will CA discolor Mahogany like it does spruce? A quick search didn't bring a result.
Brad
 Post subject: Re: CA and Mahogany
PostPosted: Mon Feb 20, 2017 2:32 pm
Last Name: Cox
CA generally darkens wood about like water does. Epoxy seems to be a lot less obvious...
There's an easy enough way to find out ;). If you are like the rest of us - there's no shortage of little scrap bits laying around.
These users thanked the author truckjohn for the post: bcombs510 (Mon Feb 20, 2017 3:07 pm)
PostPosted: Mon Feb 20, 2017 3:09 pm
Online
First name: Brad
Last Name: Combs
I used shellac on the rosette channel just because of the volume of CA I use and just to be safe. This is for the binding channel though. I'm thinking I might spray it anyway with shellac to help with keeping the tape from pulling up the fibers.
PostPosted: Mon Feb 20, 2017 5:04 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
If there is a gap and you are filling it with dust and CA it will darken. If it is a very thin line (as in a cracked/split in a top/back/side) it will be nearly invisible.
"I've been had again"
Tim Benware
Creedmoor, NC
These users thanked the author Ben-Had for the post (total 2): Lonnie J Barber (Tue Feb 21, 2017 1:04 pm) • bcombs510 (Mon Feb 20, 2017 6:04 pm)
PostPosted: Mon Feb 20, 2017 5:09 pm
First name: George
City: Seattle
Yes, CA has the potential of darkening mahogany. Sealing with shellac can help prevent this from happening. I always shellac the top in areas where tape may be applied when affixing any binding/purfling.
George :-)
These users thanked the author George L for the post: bcombs510 (Mon Feb 20, 2017 6:04 pm)
PostPosted: Mon Feb 20, 2017 6:04 pm
Online
First name: Brad
Last Name: Combs
Thanks!
PostPosted: Mon Feb 20, 2017 8:51 pm
Darken, but you can't see the yellow. I think with finish it disappears.
These users thanked the author Pmaj7 for the post: bcombs510 (Mon Feb 20, 2017 8:53 pm)
PostPosted: Sat Feb 25, 2017 11:31 pm
First name: Chuck
Last Name: Hutchison
City: Houston
It does indeed.
These users thanked the author ChuckH for the post: bcombs510 (Sun Feb 26, 2017 7:37 am)
Users browsing this forum: DennisK, doncaparker and 24 guests
