It is currently Wed Aug 13, 2025 3:51 am
 Post subject: Neck Blank Size & Cut
PostPosted: Thu Feb 02, 2017 4:26 pm
Last Name: Simmons
State: Ohio
So, I'm starting my first acoustic build after completing two electrics.
I've got a 19mm thick, rift sawn mahogany board that I'd like to use for a few acoustic necks.
Is that too thin to use? I also know that quarter sawn is ideal so I was wonder if using the rift sawn board is also a no-no.
Thanks!
PostPosted: Thu Feb 02, 2017 4:40 pm
Last Name: Kincheloe
If it's smooth and flat, that should be ok. I taper to 3/4" at the 12th fret and 5/8" at the nut before gluing the scarf joint and heel block, but then carve a little thinner in the end.
I don't think there's anything wrong with using riftsawn neck wood. Especially Honduran mahogany, which has little difference between the radial and tangential expansion rates. Straightness of grain is what matters.
