It is currently Sat Jun 28, 2025 5:47 pm
 Post subject: Uke repair
PostPosted: Wed Feb 01, 2017 8:24 pm
First name: Brad
Last Name: Combs
Hello,
I have a friends Uke that needs a repair, it looks like the neck bolt insert has come loose. I need to inspect more closely after taking the neck off. If the insert is loose and won't tighten for some reason, could I just epoxy it in place? My thought is the string forces are so much lower that it would work? If so, just remove the insert, cleanup the hole a bit, and epoxy into place?
Appreciate any help.
Brad
 Post subject: Re: Uke repair
PostPosted: Wed Feb 01, 2017 8:39 pm
Last Name: Farmer
City: Durango
State: CO
As long as it's high quality epoxy. Not 50/50 fast setting stuff. West or system three.
Long setting times and low viscosity let it penetrate the surrounding wood. Should be bomber.
I would make sure the bolt wasn't bottoming in the hole and jacking out the insert.
Just my 2 cents.
These users thanked the author david farmer for the post: bcombs510 (Wed Feb 01, 2017 10:04 pm)
PostPosted: Wed Feb 01, 2017 9:48 pm
First name: Kevin
Last Name: Mason
City: Wheeling
State: IL
Zip/Postal Code: 60090
If I understand the kind of insert you have, I would remove the insert, drill out the hole larger than the original, glue in a piece of dowel made of hardwood, redrill the hole for the insert, and then epoxy the insert.
Kevin Mason
Mason Guitars and Ukuleles on Facebook
http://masonguitars.net
These users thanked the author Kevin Mason for the post: bcombs510 (Wed Feb 01, 2017 10:04 pm)
PostPosted: Wed Feb 01, 2017 10:10 pm
First name: Brad
Last Name: Combs
Just my 2 cents.
Something like this I assume?
https://www.woodcraft.com/products/syst ... 1-1-2-pint
I'll check the bolt as well, good point.
PostPosted: Wed Feb 01, 2017 11:26 pm
Last Name: Farmer
City: Durango
State: CO
Yep, that's the stuff.
These users thanked the author david farmer for the post: bcombs510 (Thu Feb 02, 2017 5:18 am)
PostPosted: Thu Feb 02, 2017 12:18 pm
First name: Kevin
Last Name: Quine
City: Hudson
State: MA
Country: Usa
Should hold with epoxy. I hope you can get the neck bolt out with the insert spinning
These users thanked the author Quine for the post: bcombs510 (Thu Feb 02, 2017 7:32 pm)
PostPosted: Tue Feb 07, 2017 10:20 am
First name: Brad
Last Name: Combs
To close the loop.
I was able to get the bolt out. I cleaned out the hole a bit and epoxied that sucker into place. One tricky thing was some epoxy squeezed up into the end of the insert and I had the clean it out by screwing the bolt in, removing, clearing the threads and repeat until it wasn't picking up any more epoxy. Probably a slick way to avoid that but I wasn't aware of it. :)
Thanks for the help!
Brad
