It is currently Wed Aug 13, 2025 12:52 pm
PostPosted: Wed Feb 01, 2017 8:44 am
I've got my method that I have been using for 25 years now but it's one of those things that has always had room for improvement. Sometimes it's perfect other times not so much, so that's the problem, consistency. I finally made my self a binding machine, something very similar to the Canadian Luthier Supply binding jig, so cutting the rabbets are not really the problem anymore.
The problem I struggle with every time is getting the binding lengths right. I use a scarf joint at the heal block and a butt joint at the neck. I do a dry run and tape up the binding real tight all the way round and mark off the end. Then I slip a hardwood veneer, usually a side cut off or something like that, under the binding while it's still in place and cut the joint with a razor saw and trim it with a chisel.
But too many time's when I start to rope up the binding and get to the end it's either too long or too short. I always make the rabbets a bit deeper then necessary to accommodate the glue swelling and so I'm wondering if when tightening the ropes up that has something to do with it. If you make them deeper too, how much deeper?
As I am about to bind my 53rd guitar I thought I would seek out a method that might be better. Maybe that's just the way you do it but I aint' doin' it good...
PostPosted: Wed Feb 01, 2017 10:18 am
Last Name: Imbler
State: KS
Zip/Postal Code: 67204
I use the CA method, so when your bindings are taped up and pared for the butt joint at the neck, they don't move, they just get glued,
PostPosted: Wed Feb 01, 2017 10:43 am
I don't cut the neck end until I am at the mid point of the upper bout. So that might neutralize some of the swelling, but I can't imagine it's more than a couple thou anyways. It's always awkward and a little nerve racking cutting that binding. Of course I always do the top one first and quickly to see how cool I am before I do the money cut!
PostPosted: Wed Feb 01, 2017 10:46 am
Last Name: McGlynn
City: Scotts Valley
Zip/Postal Code: 95066
What is the "CA Method"? Sounds like the bindings are positioned dry and then CA glue is wicked onto the joint?
Wouldn't that tend to clue the tape/rope/whatever is holding the binding to the guitar too?
I have a second guitar that I need to bind, with wood this time instead of plastic. The first one was a sticky mess getting the adhesive in place (I was doing purflings at the same time), but it cleaned up OK. I'd like to feel like I had a little better control of the process.
Blog on Making Stuff: http://www.McGlynnOnMaking.com
PostPosted: Wed Feb 01, 2017 11:11 am
First name: Brad
Last Name: Combs
JoeM wrote:
+1
I'd like to hear more from folks who use CA here too. I think CA would especially help with miters where the alignment is critical and stressful as I'll get out. Taping everything down and dabbing some CA sounds like a good idea. I'm guessing you tape it all up leaving small gaps between the tape, tack it in the gaps, then remove the tape and apply a full run of CA?
PostPosted: Wed Feb 01, 2017 11:23 am
bcombs510 wrote:
JoeM wrote:
... I'm guessing you tape it all up leaving small gaps between the tape, tack it in the gaps, then remove the tape and apply a full run of CA?
That is pretty much how I do it.
These users thanked the author SteveSmith for the post: bcombs510 (Wed Feb 01, 2017 11:24 am)
PostPosted: Wed Feb 01, 2017 11:27 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I have found that CA on miters when using light binding leaves a dark glue line. Has anyone addressed this issue. I have had no problem with the rest of the binding using CA. To avoid a mess, the tape is spaced and I put the CA in between the tape. I still manage to glue some of the tape down, but it is not a big deal.
PostPosted: Wed Feb 01, 2017 12:32 pm
I have done the CA method once in the past. I actually did it on a guitar that I built almost entirely using CA as an experiment. It worked brilliantly really. In fact it really was the easiest binding I have ever done. But I worry about as John mentioned, darkening lines, and also the thin stuff dripping all over the inside of the guitar. Also the wood bindings have to be a super perfect fit and this guitar has a real tight waist and no matter how hard I tried I just cannot get it to fit without the extra clamping strength of rope. I suppose I could revisit it. But if you have exposed holes between kerfed linings for example then thin CA could be a disaster on the inside of the guitar. And I do know you are supposed to shellac the channel.
I also have an idea in my head that the binding, especially for this guitar with wide binding and wide purfling, that the binding is a sort of structural joint for the top. The CA method to me appears to just be a 'hold it in place' type job instead of structural. I might be off on this thinking but none the less. I would definitely use CA again if I had no holes in the linings and it was a simple binding scheme. I may also be convinced that CA is perfectly fine in any scheme ;)
PostPosted: Wed Feb 01, 2017 1:36 pm
Last Name: Imbler
State: KS
John, I use the clear reinforced packing tape which doesn't get glued down even if glue runs under it. I've only used EIR bindings, so I can't address the dark glue line other than to ask if you are shellacing the end grain of the miters?
PostPosted: Wed Feb 01, 2017 1:42 pm
Last Name: Imbler
State: KS
I actually seal up the kerfing with fish glue to prevent any errant ca from running down the inside of the guitar, but I'm guessing that wouldn't appeal to a lot of builders! I don't mind the look (just looks like it is shellaced, but doesn't look like bare wood.
As for the super fit, I tape in place, but press in and down with a caul at the place where I am tacking with CA. That gets things tighter than roping could,
As Alan Carruth says: "When there are many methods to accomplish a task, either they all work or none of them do!" :)
PostPosted: Wed Feb 01, 2017 1:58 pm
Last Name: Beaver
City: Lake Forest
Yes, it does. I use CA also, pretty much as others discribed, a dab between the tape then fully after the tape is off, but I always use a dab of Elmer's white glue on the ends of the binding and graft where it butts up to the binding. Use to use LMI White but then they changed it. I haven't try their new stuff.
Joe Beaver
Maker of Sawdust
PostPosted: Wed Feb 01, 2017 2:40 pm
I'm giving the LMI Yellow stuff a go for the first time on this guitar. It's kind of different then TB but seems to work well enough.
These users thanked the author jfmckenna for the post: Joe Beaver (Wed Feb 01, 2017 11:11 pm)
PostPosted: Wed Feb 01, 2017 3:31 pm
Last Name: McGlynn
City: Scotts Valley
The next guitar I build I'm going to try solid / laminated linings, so dripping into the inside shouldn't be an issue. And if I shellac the binding channel and top edge of the soundboard that should keep the CA from wicking into the top and interfering with any dye finish I want to try.
PostPosted: Thu Feb 02, 2017 12:19 pm
I might have a problem with this practice. Fish glue, while fairly safe in a joint, where it's protected from moisture, is reasonably safe as a glue, but applied as a sealer on the surface of linings, inside a guitar, that properly cared for, will have a humidifier hanging inside during the winter months, seems to give me pause. The fish glue is going to soak up a great deal of that moisture and become gummy over a period of time, due to it's hygroscopic(?) tendencies. Maybe I'm all wet, though! idunno
PostPosted: Thu Feb 02, 2017 1:58 pm
Last Name: Imbler
State: KS
Hasn't been a problem for me over the last 7 years of building guitars. It is all I use other than ca for bindings so that is why I used it to seal the bindings. And it gets pretty humid in KS in the summer, but there are more humid areas of course. Any high viscosity glue would work, of course like the pva white glues,
PostPosted: Thu Feb 02, 2017 3:20 pm
I use thin CA, I don't seal kerfed linings and I haven't had any issues with glue running down the inside. I'm guessing but I suppose the amount of CA I put on is probably held in the joint by surface tension
PostPosted: Thu Feb 02, 2017 4:23 pm
Last Name: Waszazak
City: Vancouver
State: Wasington
Zip/Postal Code: 98665
Joe Beaver wrote:
..but I always use a dab of Elmer's white glue on the ends of the binding and graft where it butts up to the binding.
I find this works very well. The water based glue swells the end grain. Besides helping with CA discoloring, it also helps minimize micro gaps. I first dab a little white glue, then a little CA to secure it in place.
PostPosted: Thu Feb 02, 2017 7:14 pm
As far as getting the length right at the neck joint you can glue up to within a few inches of the joint and use this technique. It has made things easier for me.
http://kennedyguitars.com/binding-cutting-aid.html
I have never used ca except to tack down miters and love it for that.
These users thanked the author Terence Kennedy for the post (total 2): DannyV (Fri Feb 03, 2017 9:14 am) • Alex Kleon (Thu Feb 02, 2017 7:21 pm)
PostPosted: Thu Feb 02, 2017 7:47 pm
An interesting point on bindings and gluing the joint. In Bogdanovich's DVD, he says not to glue the joint line, as it makes a dark line. So he just glues the binding in the channel, and does not glue the actual joint. Same with mitered purfling joints where side purfs intersect with the tail piece, etc. He just buts them up, glued in place everywhere except the actual joint itself.
These users thanked the author WaddyThomson for the post (total 2): bcombs510 (Thu Feb 02, 2017 11:16 pm) • Imbler (Thu Feb 02, 2017 8:41 pm)
PostPosted: Fri Feb 03, 2017 6:58 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Like Mr. Macaluso, we cut the neck end of the back binding during the glue-up, unless we are using CA (which is usually reserved for either very complex schemes with a bunch of miters or for plastic). For fish or hide glue-ups, we use strapping tape to hold things together until the binding is on, then the long Stewart MacDonald rubber bands and a plywood base with deck screw anchor points every inch to apply constant pressure in and down on binding and purflings while the glue dries. The rubber bands do an amazing job on pulling in the upper bout back bindings, as well as Florentine back binding in the cutaway.
For CA work, we seal all hardwood with a coat of 1 lb cut spray shellac, and two coats on spruce, redwood, and cedar...this avoids the problem of the end grain in miters darkening on maple or ash binding. We usually apply a misted coat on the entire binding strip and channel, let fully dry, then tack in with thin CA in fine tip disposable 1.5ml disposable transfer pipettes. GluBoost accelerator does a wonderful job here, and once the trick is learned on how to get a very light mist from the can, not too expensive. On plastic bindings, we always butter any miter or butt joint with a dollop of dissolved binding and wait at least a day before final scrape and sand to allow the paste to fully set up... joints in cellulose nitrate disappear with this treatment.
- Beth Brower
PostPosted: Fri Feb 03, 2017 8:48 am
Brilliant! Thank you. I will definitely be making one of those simple jigs.
But suffice to say I've already done this one. I used the CA method though I routed for a glue method. So with no expansion of the wood I now have some scraping to do. The ends didn't come out to bad but some how I made an idiot mistake and along a 3in section the binding purfling line has a gap from the bottom of the binding to the sides. Darn it. If this guitar was not for me I'd rout it off and do it again, I still might but for now I'll just fill it.
I hate making rookie mistakes. I swear binding is jut one of those things I'll never really get right.
PostPosted: Fri Feb 03, 2017 8:55 am
There was some interest in what my binding machine jig looks like so I'll post a pic here. It's a very simle set up that works better then anything I have tried so far and it has a very small foot print. As mentioned I stole, er um borrowed, the idea from the Canadian Luthier Supply jig.
PostPosted: Fri Feb 03, 2017 11:03 am
First name: Brad
Last Name: Combs
The pics are not loading for me?
These users thanked the author bcombs510 for the post: Bryan Bear (Fri Feb 03, 2017 11:19 am)
PostPosted: Fri Feb 03, 2017 11:19 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I can't see them either.
Bryan Bear PMoMC
PostPosted: Fri Feb 03, 2017 11:49 am
Sorry, perhaps now?
Users browsing this forum: Bing [Bot], dofthesea, doncaparker, meddlingfool, Woodie G and 27 guests
cron
