It is currently Wed Aug 13, 2025 11:47 pm
PostPosted: Fri Jan 13, 2017 4:12 pm
First name: EddieLee
Last Name: Brown
I have some nice Birch lumber. Do you think Birch will be a good material to make solid linings. What other materials do you like and why?
_____________
EddieLee
PostPosted: Fri Jan 13, 2017 4:27 pm
I use poplar but only because I have some nice quartered 1x stock left over from some construction work.
PostPosted: Fri Jan 13, 2017 4:40 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Basswood. Smells nice when you cut it!
Alex
PostPosted: Fri Jan 13, 2017 5:01 pm
I've used beech for solid linings (3 strips of 2mm thick), birch should be fine.
These users thanked the author Colin North for the post: EddieLee (Sat Jan 14, 2017 6:14 pm)
PostPosted: Fri Jan 13, 2017 5:26 pm
Last Name: Cox
About anything easy to bend works well. Birch, bass, aspen, poplar, ash, oak, maple, willow, etc.
These users thanked the author truckjohn for the post: EddieLee (Sat Jan 14, 2017 6:14 pm)
PostPosted: Fri Jan 13, 2017 7:11 pm
I just just did one using Cherry, I can think of no reason why birch wouldn't work.
PostPosted: Fri Jan 13, 2017 10:15 pm
Last Name: Beaver
City: Lake Forest
I like to try and approximate the shrinkage numbers of the lining with the side wood. Probably overkill but to me it makes sense.
Example:
If am doing an East Indian Rosewood guitar and I have basswood, stika spruce and mahogany linings available I would use the mahogany.
............Radial .......... Tangent
EIR ........... 2.7 ............ 5.9
Basswood ........... 6.6 ............ 9.3
Mahogany ...........2.9 ........... 4.3
Sitka Sp. ........... 4.3 .............. 7.5
Joe Beaver
Maker of Sawdust
PostPosted: Fri Jan 13, 2017 10:39 pm
First name: Brad
Last Name: Combs
Does the wood need to be quartered?
PostPosted: Fri Jan 13, 2017 11:10 pm
Last Name: Beaver
City: Lake Forest
I don't believe quartered linings would add anything to the strength of the body.
Most B&S are not carefully quarter sawn these days, like they were years ago. (that's why many sides display attractive figure as opposed to the quarter sawn of a few years ago (fairly mundane). Just look at BRW.
And, if a side is carefully quartered it will expand along the radial. If the lining grain is oriented to match, it will be flat sawn and expansion will also move along the radial, so I don't worry so much about grain.
Joe Beaver
Maker of Sawdust
Users browsing this forum: No registered users and 39 guests
