It is currently Wed Aug 13, 2025 4:21 am
 Post subject: D-18 Questions...
PostPosted: Wed Jan 04, 2017 6:31 pm
We're d-18's scalloped or straight braced?
Is the layout anything much different than found on the stewmac 'Herringbone' plans?
Thanks...
 Post subject: Re: D-18 Questions...
PostPosted: Wed Jan 04, 2017 6:54 pm
State: Tennessee
Depends on the year, but if Martin was scalloping D-28's, D-18 were pretty much the same
PostPosted: Wed Jan 04, 2017 6:56 pm
The primary difference being mahogany vs rosewood?
PostPosted: Wed Jan 04, 2017 7:03 pm
State: Tennessee
For the back and sides, tops were about the same possibly lower grade for the D-18
If you want a really accurate print of a forward shifted, scalloped braced Martin, John Arnold has an excellent tracing of his 1937 Herringbone D-28. Its also an outstanding guide for a killer D-18.
PostPosted: Wed Jan 04, 2017 7:18 pm
D-18:
B&S mahogany
Fretboard and bridge E Indian RW, Brazilian on earlier models
Binding Black ABS or tortoise celluloid on earlier models
D-28:
B&S E Indian RW, Brazilian on earlier models
FB & bridge ebony
Binding white ABS or Ivoroid on earlier models
Bracing was pretty much the same between the 18 and 28.
PostPosted: Wed Jan 04, 2017 8:19 pm
Thanks!
PostPosted: Wed Jan 04, 2017 8:46 pm
Last Name: Miller
City: Wood Dale
State: Illinois
So how does one get a hold of the John Arnold tracing?? I understand that John is an expert concerning " red spruce " and he's considered one of the best guitar makers on a par with Wayne Henderson.
Ed
PostPosted: Wed Jan 04, 2017 9:04 pm
State: Tennessee
Ed
Johns a forum member send him a PM
PostPosted: Wed Jan 04, 2017 9:46 pm
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
I have been helping with spec corrections on our 'prewar' model dreadnought - there are a lot of subtle differences between years of production. I would suggest getting a good tracing from Mr. John Arnold, which will accurately represent a specific 1930's instrument, while the Stewart MacDonald plans are a loose interpretation closer in specs to a 1985 HD-28 than a vintage D-28 (the D-18 differs in materials and trim...mahogany back and sides, red spruce top through about 1946, and sitka thereafter). Other changes include:
- Bracing was scalloped thru the late 1930's, then scalloped and rearward shifted though the mid-1940's, then tapered for a time, prior to going to straight bracing by the early 1950's.
- Nut width (1-3/4" thru late 1930's then 1-11/16")
- Bridge pin spacing (2-5/16" narrowing to 2-1/8 when nut was narrowed)
- Fretboard and bridge were originally ebony, then Brazilian, then East Indian.
- Bridge changes included contours, moving pins rearward
- Rosette changes, tuner changes, etc.
If replicating an instrument, pick a year and do some research.
- Beth Brower
PostPosted: Wed Jan 04, 2017 10:07 pm
thanks!
PostPosted: Fri Jan 06, 2017 12:38 pm
First name: Freeman
Last Name: Keller
Ed, I have one of the '70's D-18's from the "over built" era that has had the large rosewood bridgeplate replaced with a smaller maple one and some "after market" scalloping was done thru the sound hole. We did not remove the popsicle brace as is sometimes done.
While I do not have before and after sound clips the subjective feeling is that the guitar did change - my wife's comment was "you are playing louder". At a local bluegrass jam it was played along side a D18GE and a 1937 D-18 (yeah, a real one) and the feeling was that it held its own.
PostPosted: Fri Jan 06, 2017 1:09 pm
I think the popsicle braces should stay there...
PostPosted: Fri Jan 06, 2017 4:52 pm
First name: Freeman
Last Name: Keller
Some early D-18's didn't have them......
PostPosted: Sun Jan 08, 2017 12:14 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
True, but remember they had a larger neck block.
"I've been had again"
Tim Benware
Creedmoor, NC
cron
