It is currently Wed Aug 13, 2025 5:47 pm
 Post subject: Notching the x
PostPosted: Mon Dec 12, 2016 3:40 pm
Hi
Anybody got any neat tricks for making a great joint where the x brace crosses over.
Mark mine with pencil then carefully cut the notch .Mine are ok but could be better.
There must be a better way
 Post subject: Re: Notching the x
PostPosted: Mon Dec 12, 2016 3:48 pm
I cut them slightly undersized with the table saw then clean up with a XActo blade and chisel for a tight fit. Takes longer to talk about then it does to do it.
These users thanked the author SteveSmith for the post: cablepuller1 (Tue Dec 13, 2016 1:34 am)
PostPosted: Mon Dec 12, 2016 3:49 pm
State: Tennessee
Tablesaw, set your angle, sneak up on your cut perfect every time.
These users thanked the author Clinchriver for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Mon Dec 12, 2016 5:00 pm
Last Name: Beaver
City: Lake Forest
I Mark with a pencil, cut slightly undersized with a razor saw. Then I final fit with a file for width and a chisel for depth.
Joe Beaver
Maker of Sawdust
These users thanked the author Joe Beaver for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Mon Dec 12, 2016 5:19 pm
I made a little miter box for a razor saw. I mark the depth of cut and then chisel out the notch at the bottom and it is a press fit.
These users thanked the author Mike Franks for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Mon Dec 12, 2016 5:31 pm
Yeah I like to get that joint nice and tight -- I use a razor saw and this tool:
http://www.kennethmichaelguitars.com/Xb ... guide.html
Ken Cierp
These users thanked the author kencierp for the post (total 2): J De Rocher (Tue Dec 13, 2016 1:12 am) • bcombs510 (Mon Dec 12, 2016 7:22 pm)
PostPosted: Mon Dec 12, 2016 5:51 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
linen patch .... white glue .... multitude of sins ....
These users thanked the author murrmac for the post (total 2): Pmaj7 (Wed Dec 14, 2016 12:23 am) • cablepuller1 (Tue Dec 13, 2016 1:36 am)
PostPosted: Mon Dec 12, 2016 6:35 pm
I have a router jig that allows me to rout the notches at the angle I want. For 1/4" braces I would use a 1/4" bit and thickness the braces to a couple of thousands over. I then sand the notch area with a wood block until I get a squeak fit.
Got the jig idea from Charlie Hoffman.
These users thanked the author Terence Kennedy for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Mon Dec 12, 2016 7:06 pm
Last Name: Farmer
City: Durango
State: CO
You could do what most manufacturers do. Don't worry about it and cover up the mess with some cloth and glue. laughing6-hehe
Sorry, not helpful.
One trick:
what ever you use to cut the notch, it's easier to take thin plane shavings off the side of the brace than adjust the notch size. Yes I know some will protest it could throw your chladni patterns way out of wack. Just don't tell them you do it that way.
Oops, Mr. Kennedy already mentioned it.
Spell check suggests chlamydia is what I'm looking for when I write Chladni. Fun with algorithms!
These users thanked the author david farmer for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Mon Dec 12, 2016 9:46 pm
Chlamydia is actually mentioned in the now out of print book- Safe Sex With Your Guitar
PostPosted: Mon Dec 12, 2016 10:01 pm
Same here, but I don't even use a jig. This is how I've been doing it since Guitar #1. I got the idea from Lance.
These users thanked the author James Orr for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Mon Dec 12, 2016 10:07 pm
First name: William
Last Name: Snyder
City: Brooklyn
Similar to others. I cut just inside line with hand saw then refine with a chisel and file. Usually takes just a few minutes.
If I were building a bunch and/or had an extra laminate trimmer that didn't stay set up for other things I'd probably do it like James and Terence.
As is, it would take me longer to pull a router from a jig and set it up than doing it by hand.
These users thanked the author WilliamS for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Tue Dec 13, 2016 8:24 am
First name: Miguel
Last Name: Bernardo
Country: portugal
Sorry, nothing us for to add here. I'd just like to quote this.
These users thanked the author mqbernardo for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Tue Dec 13, 2016 10:30 am
First name: George
City: Seattle
I struggled with this at first as well. The solution I came up with was to use my table saw with a dado set to cut the notches and then to use my thickness sander to gradually reduce the width of the braces until the notches fit together perfectly.
George :-)
These users thanked the author George L for the post (total 2): bcombs510 (Tue Dec 13, 2016 3:29 pm) • cablepuller1 (Tue Dec 13, 2016 11:38 am)
PostPosted: Tue Dec 13, 2016 8:12 pm
Same as George, but the braces are batch sanded to .254, then dadoed at just over .250, braces are very tight.
These users thanked the author meddlingfool for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Tue Dec 13, 2016 10:12 pm
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I just follow the marking and cutting procedure outlined in the Cumpiano book. Works great every time. I have moved beyond that book in many ways, but I still like the sequence the book outlines for bracing.
These users thanked the author doncaparker for the post: cablepuller1 (Wed Dec 14, 2016 1:23 am)
PostPosted: Wed Dec 14, 2016 4:53 am
First name: Edzard
Last Name: Kolks
City: Eindhoven
Country: The Netherlands
I use this one.
These users thanked the author Edzard for the post: cablepuller1 (Wed Dec 14, 2016 12:34 pm)
PostPosted: Wed Dec 14, 2016 8:50 am
First name: Trevor
Last Name: Gore
City: Sydney
One is seldom a problem. With a few, things can get interesting...
Done with a table router fixture to get the angle and an indexing pin to get the spacing, all 12 sticks together. The bit is sized to the brace width. Rout to a hair over half way depth. Turn half the sticks over and slot them into the other half of the sticks.
Can be done on a table saw using a very similar fixture, but getting the right kerf width for your selected brace width is more problematical (and typically more expensive). X-bracing can be done exactly the same way. Just stop after one cut, as per Terence above.
http://www.goreguitars.com.au
These users thanked the author Trevor Gore for the post: cablepuller1 (Wed Dec 14, 2016 12:34 pm)
PostPosted: Wed Dec 14, 2016 9:51 am
Last Name: Sollod
Trevor, I know you are very knowledgeable, but I don't get this bracing scheme... seems like the top wouldn't be able to move at all... ...nice jointing BTW.
www.swiftcreekguitars.com
PostPosted: Wed Dec 14, 2016 6:16 pm
First name: Trevor
Last Name: Gore
City: Sydney
It's similar to the system used on Smallman type classical guitars - a very thin top with a light-weight lattice to support it. I used that system in this instance because the owner wanted a loud koa guitar and the only way to get near was to make a top with the same mass and stiffness as a spruce top. Because koa is quite a lot denser than spruce the only way to get the mass down is to go thin, then the bracing follows to get the strength and stiffness back whilst keeping the overall mass low. It worked very well. More info in this OLF thread here.
PostPosted: Fri Dec 16, 2016 3:40 pm
yep ... two Freud diablos, plus a Forrest blade stiffener and then Lee Valley dado shims (the really tough but thin plastic ones, in 5 thou increments) to get the sizing right (my X braces are all .280 or so) - test on scrap .. set your mitre gauge to the desired angle and blade height to a touch over half way ... cut away ... once you know the correct dado spacers needed, cutting the notch takes about 2 minutes including setup/blade change ....
These users thanked the author TonyKarol for the post (total 2): cablepuller1 (Sat Dec 17, 2016 3:41 am) • Pmaj7 (Fri Dec 16, 2016 4:32 pm)
PostPosted: Fri Dec 16, 2016 7:21 pm
Single edge razor blade squeezed into the brace to cut the sides of the notch, the a narrow chisel to cut the bottom of the notch.
These users thanked the author Pat Foster for the post: cablepuller1 (Sat Dec 17, 2016 3:41 am)
PostPosted: Sat Dec 17, 2016 2:13 am
First name: Tim
Last Name: Allen
City: San Francisco
I tried a couple of ways; for me the table saw method works best. There's a nice video tutorial here, thanks to Chris Paulick:
viewtopic.php?f=10117&t=23633
As Chris mentions in the comments below the video, you can nibble with a saw blade rather than use a dado set, and that's what I do. Doesn't take long, though you have to smooth the bottom of the slots a little bit.
Tim Allen
"Never hurry, never rest."
These users thanked the author TimAllen for the post: cablepuller1 (Sat Dec 17, 2016 3:41 am)
PostPosted: Sat Dec 17, 2016 3:02 pm
Pre-dado system. Dado better.
viewtopic.php?f=10101&t=45045&p=595810&hilit=Stick+with+lump#p595810
These users thanked the author meddlingfool for the post: TimAllen (Tue Dec 20, 2016 1:47 am)
Users browsing this forum: No registered users and 39 guests
