It is currently Wed Aug 13, 2025 6:56 pm
 Post subject: Powered Dish Sander
PostPosted: Tue Dec 06, 2016 7:48 pm
I just finished my powered dish sander and am happy to not have to "drive the bus" with manual steering! I used a 1/4 HP gear motor with 72 RPM output, flexible coupling and flange bearing which drives a sprocket that I modified as a drive plate with 3/4" spindle and a 1/4" drive pin. The radius dishes have a corresponding 3/4" center hole and 1/4" drive pin hole and the whole mess rides on 8 ball bearing casters. I added a foot switch for start/stop.
I couldn't be more pleased with the smooth, quiet operation of the machine and the 278 inch/pound torque rating of the gearmotor is very powerful and does not slow down with even the hardest of sanding. I have sanded ukuleles and jumbo size guitar frames and it sure beats manual sanding.
I purchased all of the mechanical components on good old eBay and was happy with the quality of everything that I received.
Mike Franks
mjfranksguitars.com
http://www.facebook.com/mjfranksguitars
These users thanked the author Mike Franks for the post (total 3): Pmaj7 (Fri Jan 20, 2017 1:49 am) • jeff crisp (Fri Dec 09, 2016 5:31 pm) • DannyV (Wed Dec 07, 2016 11:22 am)
 Post subject: Re: Powered Dish Sander
PostPosted: Tue Dec 06, 2016 8:00 pm
Online
Very nice! We've been thinking of building one, but vertical to save space...
PostPosted: Tue Dec 06, 2016 8:34 pm
Last Name: Beaver
City: Lake Forest
That is a great machine
Good job
Joe Beaver
Maker of Sawdust
PostPosted: Tue Dec 06, 2016 8:40 pm
City: winnipeg
State: manitoba
Country: canada
I like your caster support system, simple but practical.
Bob :ugeek:
PostPosted: Tue Dec 06, 2016 8:41 pm
Like it. Creative!
PostPosted: Tue Dec 06, 2016 8:50 pm
Last Name: Beaver
City: Lake Forest
Good job
Joe Beaver
Maker of Sawdust
PostPosted: Wed Dec 07, 2016 1:04 am
First name: Joey
Last Name: Holliday
City: Palmetto
Zip/Postal Code: 34221
Nice work. Do you have a list of the parts on EBay? I want to build one of these.
PostPosted: Wed Dec 07, 2016 6:54 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I have a slightly different design, and mine works well, but you have given me some upgrade ideas. Thanks!
PostPosted: Wed Dec 07, 2016 7:57 am
Dust control?
Ken Cierp
PostPosted: Wed Dec 07, 2016 9:16 am
Online
First name: Brad
Last Name: Combs
This has given me an idea. My wife has an industrial pottery wheel that has been gathering dust for long enough!
Thanks!
PostPosted: Wed Dec 07, 2016 9:54 am
Wish I had the space, even for a vertical.
:mrgreen:
PostPosted: Wed Dec 07, 2016 10:47 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
I never would have thought of using casters!
Bryan Bear PMoMC
PostPosted: Wed Dec 07, 2016 10:50 am
Yeah... the casters are a nice idea... at first I had to laugh over the simple practicality of it. They will align nicely as the wheel is turning. Pretty darn clever!
PostPosted: Wed Dec 07, 2016 12:39 pm
City: Escondido
Zip/Postal Code: 92029
I like it, but I don't understand the gear mechanism. Can you show a picture of the underside of the dish?
PostPosted: Wed Dec 07, 2016 1:15 pm
First name: Tim
Last Name: Lynch
City: Santa Cruz
Zip/Postal Code: 95060
Think its being driven by the offset pin.
Nice simple design. Wish I had he room for something like that
These users thanked the author Tim L for the post: Pmaj7 (Fri Jan 20, 2017 1:53 am)
PostPosted: Wed Dec 07, 2016 1:28 pm
Last Name: Parker
City: Charleston
Mike could explain in detail, since he built it, but it looks like the choice of the sprocket on top is just a matter of convenience, because it is round and flat and it fits securely on the end of a drive shaft. The teeth on the sprocket don't do anything. There is an offset pin on the outer edge of the face of the sprocket, and that pin inserted into an offset hole in the bottom of the dish provides rotational movement. Is that right, Mike? Like Tim said, that's a simple and effective design. I do something similar with a pulley instead of a sprocket, but I like the sprocket idea better. I also like the idea of having the drive shaft fit up into a centered hole in the dish; it helps keep the movement of the dish strictly rotational. I have been using two equidistant offset pins in my pulley, and it can shimmy around a little too much. Mike's way is better.
PostPosted: Wed Dec 07, 2016 2:56 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
Who else wants to see an action video?
These users thanked the author J De Rocher for the post (total 5): Durero (Fri Dec 09, 2016 11:20 pm) • ernie (Thu Dec 08, 2016 7:10 pm) • Bryan Bear (Wed Dec 07, 2016 5:16 pm) • Pmaj7 (Wed Dec 07, 2016 5:13 pm) • James Orr (Wed Dec 07, 2016 4:08 pm)
PostPosted: Wed Dec 07, 2016 3:49 pm
Last Name: Parker
City: Charleston
I think seeing such a video without the dish on top would explain how it works better than having the dish in place. We'll see the sprocket rotating, and the offset pin spinning in a circle. But it would also be cool to hear how the casters sound with the dish in place. I bet they are pretty quiet, compared to the noisy Lazy Susan I currently use.
These users thanked the author doncaparker for the post: Gary Norman (Tue Dec 13, 2016 9:46 pm)
PostPosted: Wed Dec 07, 2016 6:32 pm
Thanks to all who have commented on my dish sander. I will try to address some of your questions. After contemplating the design for some time, I purchased all of the components on eBay, at one sitting. The mechanical components are as follows:
Marathon/Bison Gearmotor, parallel 3/4" output shaft with keyway. 1/4 HP, 110/220vac, 27.82:1 ratio with 62 RPM output at 238 inch/pounds torque
Lovejoy Flexible Coupling, 3/4" X 3/4" keyed
3/4" I.D. Flange Bearing
3/4" X 12" Keyed shaft
7" X 1/4" flanged sprocket
(8) Ball Bearing Casters
Foot Switch
I was fortunate to find the gearmotor new in the box for about $250. The 62 RPM speed is perfect and allows good control of the workpiece. I was uncertain of the ideal rotational speed but considered that manual sanding at 1 rev per second was that speed that I worked at. Don is correct in that I chose a sprocket because that is what was handy for the drive plate. The steel is soft enough (apart from the teeth) to drill and tap for the 1/4" drive pin which I made from a cut off bolt. The table top is 3/4" plywood and I made it large enough to catch the sanding dust. I thought about dust collection but the dust when sanding is not airborne and is easy to vacuum off of the top of the machine after sanding, much like I did when manually sanding.
I screwed a 3/4" thick plywood backing plate to each of my radius dishes and drilled the center hole at 3/4" with the 1/4" drive pin hole. I used the actual drive plate as a drill guide after locating the center of the disc.
The casters are self-aligning, very quiet and work very well. The soft rubber tires are kind to the disc.
I pre-cut all of the wood frame pieces and used carriage bolts to assemble. I probably over-built the frame but it is solid as a rock.
I took a quick look on eBay and there is a good selection of 1/4 HP gearmotors to choose from. Many of them are rated for 90 VDC but I see a few that are similar to mine.
I'm not quite sure of how to upload a video but will give it a try if it would be of help to anyone considering building a dish sander.
Best,
Mike Franks
www.mjfranksguitars.com
These users thanked the author Mike Franks for the post: Durero (Sat Dec 10, 2016 12:08 am)
PostPosted: Fri Dec 09, 2016 10:19 am
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
I get tired of "driving the bus" too. I'm thinking about how I could modify a used washing machine.
PostPosted: Fri Dec 09, 2016 11:22 am
You must have bigger washing machines in the States, no way could I get even a parlour into mine laughing6-hehe
PostPosted: Fri Dec 09, 2016 11:58 am
I am unable to find the link, but the simplest power rim contour sander set up I ever saw, used a 1/2" variable speed drill with a small sanding drum (2"?) in the chuck. The drum rubbed against the turn table (two layers of MDF) with a center bearing. Instead of casters, the thrust bearings were pieces of Teflon fastened to the base. All kind of like the old phonograph record turn table worked.
Ken Cierp
PostPosted: Fri Dec 09, 2016 12:55 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
laughing6-hehe Happy hour must start early on Fridays, Colin! laughing6-hehe
Alex
PostPosted: Fri Dec 09, 2016 4:04 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Alex
No kidding! Obviously you have to put it in there without the neck attached. duh
I use the wringer to thickness my plates too. I just run billets through until they are smashed down thin enough but sometimes my arm gets tired (especially if I start with 4/4 stock).
Bryan Bear PMoMC
These users thanked the author Bryan Bear for the post: Michaeldc (Fri Dec 09, 2016 4:11 pm)
PostPosted: Fri Dec 09, 2016 4:24 pm
Alex
Cheers! Eat Drink
Users browsing this forum: meddlingfool and 15 guests
