It is currently Wed Aug 13, 2025 5:48 pm
PostPosted: Wed Nov 30, 2016 4:44 pm
City: London
State: ON
Zip/Postal Code: N6C5Y2
Can you guys recommend a system that would be a step up from rattle cans?
I'm just a hobbyist who works only with my own guitars so something reasonably priced and manageable.
I've painted a few guitars with cans but would like to get better, more consistent results.
Or maybe I should stick with painting with cans but just find a professional for the clear coats?
I'm thinking of a few projects down the road and maybe more so I'm at a crossroads.
Thanks for your opinions.
PostPosted: Wed Nov 30, 2016 6:56 pm
I had a friend who did auto body repairs paint one for me. If you have such a friend, ask.
PostPosted: Wed Nov 30, 2016 7:40 pm
City: London
State: ON
I don't have a friend like that but I will have a number of guitars to do.
PostPosted: Wed Nov 30, 2016 7:48 pm
First name: Freeman
Last Name: Keller
Paul, do you want do "paint" as in solid colors? If so I can't help much - that is the realm of auto paint. I have a very good friend who paints custom motorcyles - somebody like that could coach you.
If you want do do "finishes" as in clear or tinted or even sunbursts, then I can share my learning experiences. My first couple of guitars were done with rattle cans of lacquer - I thought quite acceptable but like you I wanted to move to the next level. I am still learning and experimenting, but here is what I've done so far.
I found a small home air compressor at a yard sale ($50), I think it is 2hp and 8 gal tank. I added a water filter and pressure regulator. I started with a siphon "jamb" gun (about 4 oz) but have moved to a gravity feed LPHV (low pressure high volume) gun that I bought at an auto parts store. I added a pressure gauge at the gun.
This has allowed me to experiment with both nitrocellulose and so called "water born" lacquers - frankly both have advantages and disadvantages.
Nitro is easy to shoot and get good results, but it is hazardous, explosive, and a bit of a hassle to clean up. I don't have a spray booth (actually I could go to my motorcycle painter friend) but I shoot outside on warm days with moderate humidity. I wear a full respirator. Clean up involves taking the gun apart and cleaning everything in lacquer thinner. I can add dye to lacquer and do tinted, shaded or sunbursts. These are finished in nitro
Water born lacquer (I've used both StewMac's and KTM-9) is not toxic or explosive, cleans up with warm water and seems to give a very nice finish. I have tried tinting and shading it with good results. These were finished in KTM-9
A potential problem with the water born finish is that each coat does not melt into the previous one like nitro and you can get "witness lines" when you sand.
My point is that once you have committed to an air compressor and small gun you can try many different finishes (including automotive, I just can't tell you what). Some sort of spray booth is advisable, particularly if you want to finish in doors. Dan Erlewine's book on guitar finishing (StewMac) is highly recommended, and as always, practice on scrap.
These users thanked the author Freeman for the post (total 2): TimAllen (Thu Dec 01, 2016 2:39 am) • FL6 (Wed Nov 30, 2016 9:18 pm)
PostPosted: Wed Nov 30, 2016 9:10 pm
Is French polish any good for solid bodies?
PostPosted: Wed Nov 30, 2016 9:20 pm
City: London
State: ON
Thanks Freeman. I'll study your post and setup, kinda looks like what I'm after.
PostPosted: Thu Dec 01, 2016 8:15 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Most pros at instrument finishing will not want to clear over rattle can paint, I sure won't. Because I cannot guarantee what will happen when my product hits yours......
Before I start recommending equipment do you have compressed air already?
Brian
PostPosted: Thu Dec 01, 2016 9:08 am
City: London
State: ON
I have a small 2 gallon air compressor.
PostPosted: Fri Dec 02, 2016 8:09 am
Last Name: Howard
City: Magnolia
State: Delaware
That's likely good enough to do one guitar at a time without killing it. So what you need is a filter/sperator to remove oil and water from your compressed air , a regulator, hose and a gun. You can get all these items at Harbor Freight for $100 or less....but quality will be what it is. You will be able to get satisfactory results but will need to work a bit harder to get them then if you purchased some better equipment. The regulators and filters at HF are fine so buy them there....but maybe spend a bit more on a better gun like a Devilbiss (there "Starting Line" guns are quite good for the price).
Brian
Users browsing this forum: No registered users and 40 guests
