It is currently Wed Aug 13, 2025 10:21 pm
 Post subject: Hand sawing to plates
PostPosted: Sat Nov 12, 2016 5:55 pm
First name: george
Last Name: s
Hi All.
I have a 1" x 10" Western Hemlock board that I am thinking about making into some top plates. As a hobbyist I like to try new things (hemlock) so I thought I'd try hand cutting the plates (vs. Band or Table saw).
Any suggestions for making a jig to do this with a hand saw?
I saw a picture of the Lyon Healy / Regal plant from the turn of the 20th Century, and it looked like they had a slotted box in which they stood the plate material , and a two man hand saw. Keeping it with the theme of "olde tymey" I want to use my grandfather's WWI era hand saw, which I recently sharpened. This could be fun, or a crime against nature, TBD.
Regards, GS
PostPosted: Sat Nov 12, 2016 7:06 pm
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
Zip/Postal Code: 64081
FWIW . I resawed vln plates in maple wood using a large beam saw, basically a 1.5in wide blade 5 ft long with 2 straight handles. I got the blade from suffolk machinery.Tensioning is via a long wing nut it/s a t shape with 2 handles .I/ve also done it with a 28in 5 pt ripsaw or euro bowsaw that has a 1in blade traditional woodworker or highland hardware sells these euro saws. A large japanese ryoba ripsaw works well in softwoods , japan woodworker , woodcraft, etc. The problem with usa rip saws for ripping plates is they don/t track well because of the whippy blade . Hope this helps . THey do work for ripping e.g. taking a 2in slice off a 5in board
These users thanked the author ernie for the post: gxs (Sun Nov 13, 2016 1:56 am)
PostPosted: Sat Nov 12, 2016 8:07 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Here's a page out of Ruobo. A friend made one - ended up being a pretty heavy thing to keep it from moving around as you saw.
Ed
PS - your grandfather's saw better be filed for rip
These users thanked the author Ruby50 for the post: gxs (Sun Nov 13, 2016 1:58 am)
PostPosted: Sun Nov 13, 2016 8:14 am
To saw plates with a hand saw I would first cut the board to the maximum width needed for the instrument. I would then kerf both edges with the table saw blade raised as high as possible. The kerfs would act as a guide for the hand saw. This would allow you to use your grand dad's hand saw with out turning the endeavor into a "manhood" thing
These users thanked the author Clay S. for the post: gxs (Sun Nov 13, 2016 12:02 pm)
PostPosted: Sun Nov 13, 2016 8:24 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
As said, the saw better be filed for rip cuts but also very sharp and filed evenly so it tracks well. You don't say much about the saw, are the gullets deep enough for such a wide rip cut. There will be a lot of dwarf to remove from a 10" wide rip cut. . .
I'' not saying don't do this, but you'all be manliest than I am when you are done
Bryan Bear PMoMC
PostPosted: Sun Nov 13, 2016 9:01 am
First name: ernest
Last Name: kleinman
City: lee's summit
State: mo
george I got the plans for making the beam saw from a book in the local library.They are fairly easy to make and you can use leftover wood scraps an bits of hardware. The blade stock can be purchased from suffolk machinery .The beam saw works quite quickly. But your wood should be mounted in a secure vice with at least 6 ft of empty space around you. Start with a cut at a 45 deg angle with the wood held upright, and mark your wood all around so you don/t veer off your cut line . Practice on scrap first !! Roy Underhill bliss blissl might also have a plan for one . He is a hand tool woodworker who does a lot of PBS videos . Good luck.
PostPosted: Sun Nov 13, 2016 12:44 pm
First name: Gregor
Last Name: Crothers
Here is Tom, he is awesome!
https://m.youtube.com/watch?v=OtmswWZ4Lvo
Wake up and smell the rosewood!
PostPosted: Wed Nov 16, 2016 12:23 am
First name: george
Last Name: s
It is a rip saw. Six teeth per inch, and just sharpened, to your point though the gullets are not that deep, so it could take a while.
GS
PostPosted: Wed Nov 16, 2016 12:26 am
First name: george
Last Name: s
gregorio wrote:
Ah, ya see what happens, now I am totally jonesin' for one of those kerfing planes. . . and darn it there are plans for it, and I can think of a bunch of uses for it.
These users thanked the author gxs for the post: Bryan Bear (Wed Nov 16, 2016 11:48 am)
PostPosted: Wed Nov 16, 2016 11:28 am
gregorio wrote:
Ah yes! When I first saw this thread that is the video I was thinking of which I saw a while back, could not remember the guys name though.
PostPosted: Wed Nov 16, 2016 11:45 am
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
GS
Yikes! I hate reading quotes from me that demonstrate how terrible my cell phone posts are. . . really, how terrible my proofreading is :)
That was swarf not dwarf, I'm not I", you'll be manlier than I. . .
:shock:
Bryan Bear PMoMC
PostPosted: Thu Nov 17, 2016 5:57 am
Last Name: Minch
City: Chestertown
Six teeth per inch will be fun. 4-1/2 would be my guess for that much wood.
Ed
PostPosted: Mon Nov 21, 2016 5:44 pm
City: winnipeg
State: manitoba
Country: canada
I once considered using a reciprocating saw (sawzal) with bearings as guides mounted horizontally.
Just a thought.
Bob :ugeek:
PostPosted: Mon Nov 21, 2016 5:51 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
GS
:shock:
Thanks for the clarification, I was gonna inquire about your dwarf problem :-)
Unless, of course, dwarves are the new goats.
These users thanked the author JSDenvir for the post: Bryan Bear (Mon Nov 21, 2016 5:53 pm)
PostPosted: Sun Nov 27, 2016 1:21 pm
I've done it... pretty much as Clay S. described above. As I moved down the cut I put shims into the slot and moved the clamps to above the saw.
Users browsing this forum: DennisK, meddlingfool and 26 guests
cron
