It is currently Wed Aug 13, 2025 9:47 pm
 Post subject: Refreshing sanding belts
PostPosted: Fri Nov 04, 2016 8:58 pm
Last Name: Denvir
City: Baltimore
State: ON
Zip/Postal Code: K0K 1C0
Here's an idea I haven't heard before. I was taking an online course, and they were talking about cleaning shellac on glassware for French polishing. They used TSP, tri-sodium phosphate (?), which can be found in any hardware or paint store. It's used for cleaning walls prior to painting.
It worked incredibly well for cleaning up old shellac residue, and I thought, hmm, resin? Maybe it'll work for burnt-on oils/resins from cocobolo and the like.
I got a small Home Depot pail, half filled it with water, and added about 4 tablespoons of tsp. Added a couple of buggered up sanding belts and left it for about a week.
Took a wire brush to them this morning, and while not good as new, they're in much better shape than they were. Not sure what kind of shape the grit is in, but the burnt on residue is mostly gone.
These users thanked the author JSDenvir for the post (total 2): GRS (Mon Nov 21, 2016 3:10 pm) • Alex Kleon (Fri Nov 04, 2016 11:10 pm)
PostPosted: Fri Nov 04, 2016 11:52 pm
I think oven cleaner does the same. The problem is that the sand/crystals/grit on the belt are already broken. Your belt might be clean, but it's still dull.
PostPosted: Sat Nov 05, 2016 12:41 pm
Last Name: Beaver
City: Lake Forest
Thanks Steve, I think it's worth trying
Joe Beaver
Maker of Sawdust
PostPosted: Sat Nov 05, 2016 2:21 pm
I recall that Don Williams also had a thread about cleaning belts a few years ago.
PostPosted: Sun Nov 06, 2016 6:53 am
"The problem is that the sand/crystals/grit on the belt are already broken. Your belt might be clean, but it's still dull."
Ed, some of us gum up the belts with the woods we sand before they are worn out. It's hard to resist taking that bigger bite that ultimately costs us time (and belts) rather than saving it.
PostPosted: Sun Nov 06, 2016 10:59 am
First name: D
Last Name: S
I stripped the shellac off an Oak floor built in the 1930's.
Mixed it in a bucket and moppd it right off.
I was shocked it workd so well.
wah
Wah-wah-wah-wah
Wah
PostPosted: Sun Nov 06, 2016 11:01 am
We use the blue Zirconia abrasive (well worth the extra $) To clean "De-Glue-Goo" works really good especially where there is the burnt glue trail on the drum. Brush on the chemical (heavy) wrap with Saran plastic leave over night. Clean off with a brass wire brush and some water.
Ken Cierp
These users thanked the author kencierp for the post (total 2): Colin North (Mon Nov 21, 2016 9:29 am) • Pmaj7 (Mon Nov 07, 2016 10:06 am)
PostPosted: Mon Nov 07, 2016 10:07 am
PostPosted: Sun Nov 13, 2016 1:34 am
First name: Mark
City: Concord
I soak my glommed up drum sander belts overnight in a strong solution of Simple Green and water. Anything remaining on them comes off with a brass bristle brush.
PostPosted: Sun Nov 20, 2016 9:42 pm
First name: Murray
Last Name: MacLeod
City: Edinburgh
Country: UK
No puzzlement that I can see.
tri-sodium phosphate was mixed in a bucket and applied to shellac-covered oak floor ... shellac was removed unexpectedly easily.
Unless i am missing something.
PostPosted: Mon Nov 21, 2016 7:10 am
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Maybe the sanding belts that Dan used to strip the floor went into the bucket.
We may never know! idunno
Alex
Users browsing this forum: DennisK and 21 guests
