It is currently Thu Aug 14, 2025 10:33 am
 Post subject: Rasps
PostPosted: Sun Oct 16, 2016 7:58 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Boring topping. But, I would like a recomendation on a rasp(s) useful for clearing neck joint material for fitting. I usually use a block of wood with a 10-15 deg angle, 30 grit paper. But it's too slow. Ideas?
M&T joint.
 Post subject: Re: Rasps
PostPosted: Sun Oct 16, 2016 8:14 pm
First name: Brad
Last Name: Combs
I've been using this with some success. It's easy to go too far though which I never had an issue with when using sandpaper and a block. :)
http://m.woodcraft.com/product/150566/i ... e-cut.aspx
PostPosted: Sun Oct 16, 2016 8:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Does it cut on all sides? I want one that only cuts on bottom. Don't want to mess with tenon
PostPosted: Sun Oct 16, 2016 9:03 pm
One of my favorite files is the plasticut duplex laminate file with the yellow handle. It has one "safe edge"which can also be used as a straight edge, one side that cuts quickly and one side that is fine cut. Rough enough for wood work and fine
enough to give control and a good finish. (The red handled one isn't as aggressive as I like - less suited for wood IMHO)
http://www.wurthwoodgroup.com/Duplex-La ... 79353.aspx
PostPosted: Sun Oct 16, 2016 9:15 pm
First name: Tim
Last Name: Benware
City: Creedmoor
Zip/Postal Code: 27522
http://www.stewmac.com/Luthier_Tools/Ty ... _Rasp.html - I use the large coarse and fine
http://www.stewmac.com/Luthier_Tools/Ty ... Files.html - I use the small flat and curved and large flat
"I've been had again"
Tim Benware
Creedmoor, NC
PostPosted: Mon Oct 17, 2016 12:10 am
I have two Liogier rasps which were handmade in France by Noël Liogier. Noël actually came to the forum to introduce himself and share a video of the process he uses to make them. One is a 10" #9 grain cabinet maker's rasp, and the other is a 7" #13 modeler's rasp. They're beautiful and highly effective, but I don't think they're what you want for this if I'm reading you correctly. I use a chisel to relieve the heel, leaving an 1/8th to a 1/4" of material around the edge. This makes the flossing process go much quicker. This is a pretty common technique. Robbie O'Brien demo's it around the 6:50 mark here.
PostPosted: Mon Oct 17, 2016 8:28 am
First name: Brad
Last Name: Combs
Based on the responses from others I believe I misunderstood what you wer asking for. I use that file to take small amounts off the tenon sides to fit it into the mortise. For whatever reason mine don't fit right off the jig. I'm hoping to fix that though because I ordered the neck angle jig from luthiertool. :D
PostPosted: Tue Oct 18, 2016 4:20 am
Last Name: Lee
City: Albany Creek
State: QLD
Zip/Postal Code: 4035
Ben-Had wrote:
http://www.stewmac.com/Luthier_Tools/Types_of_Tools/Files/Dragon_Hand-cut_Rasp.html - I use the large coarse and fine
I use the razor files as well
PostPosted: Tue Oct 18, 2016 9:13 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
Why not a nice sharp chisel? Once you have relieved the parts of the joint next to the tenon, there is very little work to do. I haven't done many, but I use the chisel to get close to the line, then the angled piece of wood with 80 grit to the line, then floss in place.
These users thanked the author Ruby50 for the post: Mike OMelia (Tue Oct 18, 2016 11:20 am)
PostPosted: Tue Oct 18, 2016 9:37 am
I use a 1/4/" down spiral bearing guided pattern bit, same as for trimming top or back over hand.
+1 for the Dragon file from SM -- excellent tool.
Ken Cierp
PostPosted: Tue Oct 18, 2016 11:21 am
Last Name: O'Melia
City: Huntsville
State: Alabama
OK, I used the chisel approach, plus sanding with a 10 degree block, much faster.
Thanks!
PostPosted: Tue Oct 18, 2016 12:17 pm
First name: Brad
Last Name: Combs
Now that I know what we are talking about... I chisel relief all the way up so that just a very thin edge is around the perimeter of the joint and then floss in place. What does the sanding block achieve?
PostPosted: Tue Oct 18, 2016 5:37 pm
First name: David
City: Napa
Zip/Postal Code: 94558
I'm a big fan of the razer files from Stewmac
PostPosted: Tue Oct 25, 2016 10:30 pm
Last Name: O'Melia
City: Huntsville
State: Alabama
Sanding block is fine tuning
PostPosted: Wed Oct 26, 2016 7:59 pm
First name: Jim
Last Name: Kirby
Chisel is probably the way to go, but if you are still interested in something that produces a smooth finish that may be comparably useful, look at ...
http://www.leevalley.com/US/Wood/page.a ... at=1,42524
These are designed for finishing body work on cars and such. They leave a really nice finish, and are almost always what I want to use after the basic rasp work.
Jim Kirby
kirby@udel.edu
