It is currently Wed Aug 13, 2025 11:50 pm
 Post subject: Bandsaw brainmelter...
PostPosted: Thu Oct 13, 2016 3:31 pm
Full on cognitive dissonance over here.
I need to cut some wood, and my saw is being a jerk.
Hoping someone with more general tool knowledge can set me straight.
Exhibit A-ImageBlade is square to the table on the outside.
Exhibit B-ImageBlade is not square to the inside of the table.
Exhibit C- Image Not a fine precision tool, but table appears to be flat.
How is this even physically possible?
The guides are not in the picture, but they are not touching the blade at all, so they're not the problem.
PostPosted: Thu Oct 13, 2016 3:37 pm
Oops, exhibit B resubmitted...Image
PostPosted: Thu Oct 13, 2016 3:40 pm
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Zip/Postal Code: 30705
Are you sure that your squares are square? haha
What happens when you put the larger one on the left side of the blade?
Guitar Maker and Purveyor of the World's Finest Tonewoods
http://www.aaronhixguitars.com/
http://stores.ebay.com/A-Hix-Tonewood-a ... r-Supplies
PostPosted: Thu Oct 13, 2016 4:04 pm
I am not quite catching the problem. The Straight Edge doesn't appear to be square with a blade?
PostPosted: Thu Oct 13, 2016 4:19 pm
Yes, squares are square.Image
PostPosted: Thu Oct 13, 2016 4:20 pm
Pat, the problem is that the blade is square to the table on one side, but not the other, which I simply can fathom how it's even physically possible.
PostPosted: Thu Oct 13, 2016 4:29 pm
Last Name: Kincheloe
The first two photos are the same. EDIT: Nevermind, didn't see that the other post was the right one.
I'm not seeing the problem yet either. I'll keep looking... EDIT: Ok, now I see it. The sliver of light beside the blade toward the bottom of the square on the left side. As Aaron says, switch sides and check. The smaller square looks like it might be hanging too far over the edge and tipping slightly toward the blade. Also, clear the dust away to make sure that's not tipping it at all.
PostPosted: Thu Oct 13, 2016 4:41 pm
First name: David
Last Name: Lush
City: Louisville
State: Kentucky
Is it possible the weight of the larger of the two squares is pushing against the smaller of the two causing the smaller not to sit flat? Would you get a better result with the table insert installed supporting the weight? Food for thought...
PostPosted: Thu Oct 13, 2016 4:47 pm
here's what I'm seeing from the pictures:
the smaller square (left side) appears to have a 1/16" gap at bottom and be touching at top
the larger square (right side) appears to be totally square with blade
the table top appears to be flat since that beam across it makes it look so
the 2 squares when on the table top appear to be touching all the way
here's what I think: the smaller square's handle is only half on the table, the other half is in the throat...the mass of the blade plus half a handle is tipping it over and making it appear out of square...try putting the larger square of the left side and see what happens
PostPosted: Thu Oct 13, 2016 4:50 pm
Last Name: Spector
City: ORANGE
Zip/Postal Code: 77632
Is one of your squares resting on the weld for the band?
PostPosted: Thu Oct 13, 2016 5:05 pm
I wouldn't be surprised if one of the squares is not square on the outer edge.
PostPosted: Thu Oct 13, 2016 5:39 pm
Squares are square.Image
Small square outside this time, square with blade...Image
Large square inside, not square with bladeImage. Not even close.
PostPosted: Thu Oct 13, 2016 5:48 pm
Also, I have four RK blades, and they all do it, the same amount.
These users thanked the author meddlingfool for the post: jayluthier (Thu Oct 13, 2016 6:02 pm)
PostPosted: Thu Oct 13, 2016 5:59 pm
Last Name: Beaver
City: Lake Forest
The logical conclusion is the table is not perfect.
If you chose to accept this mission then you must remove the blade, scrape the table with a razor blade, then lay a straight edge right where the squares sat, and use a light to check it.
Joe Beaver
Maker of Sawdust
PostPosted: Thu Oct 13, 2016 6:05 pm
Flat table, check.Image
PostPosted: Thu Oct 13, 2016 6:18 pm
Ruling out red shift, I'm miffed! Ok.....how about the two squares in that spot with no blade? Or just perhaps just in from/behind blade?
PostPosted: Thu Oct 13, 2016 6:35 pm
In front...Image
On blade, outside of blade square, inside, not...Image
The befuddlement is complete.
PostPosted: Thu Oct 13, 2016 6:36 pm
First name: D
Last Name: S
Try rotating the blade and recheck.
Check for crud on the wheels.
wah
Wah-wah-wah-wah
Wah
PostPosted: Thu Oct 13, 2016 7:00 pm
Wheels clean, gap persists through full blade revolution...
PostPosted: Thu Oct 13, 2016 7:20 pm
First name: George
City: Seattle
Hmm ... maybe one of the wheels is out of round and somehow putting torque on the blade that is causing it to twist or bow slightly? idunno
George :-)
PostPosted: Thu Oct 13, 2016 7:29 pm
Maybe I missed something, but have you tried cutting a piece of scrap ?
Brent
PostPosted: Thu Oct 13, 2016 7:48 pm
First name: Kevin
Last Name: Looker
City: Worthington
State: OH
Zip/Postal Code: 43085
You are assuming the blade is straight but I don't see a straight edge against the blade, aligned with the blade, not the table.
The blade could have compound curvature in it - twist and bow.
I'm not a luthier.
PostPosted: Thu Oct 13, 2016 7:54 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Get one of these, Ed. Put it on the right side of the table and zero it out, then put it on the blade to get the angle relative to the table, and then measure the angle on left side of the blade. Repeat the whole operation on the left side of the table, as well. Only zero out once per entire operation. It should tell you if the table is the problem.
Alex
PostPosted: Thu Oct 13, 2016 9:07 pm
First name: Aaron
Last Name: Hix
City: Chatsworth
State: Georgia
Ed, your wheels are slightly out of line causing your blade to have a very small amount of twist. No big deal.
PostPosted: Thu Oct 13, 2016 10:32 pm
Aaron, that's good to know. I set the table for square against the fence, and had a much better time of resawing than previous experiences. I think I may have fallen prey to the infamous 'dull out of the box' Resaw King blade last time, this seemed to cut with little force required.
The last time I totalled the table insert, the sides billet bounced up and down like a jackhammer and bent it like potato chip.
But today, I got ten ovangkol and three walnut back sets without the blade seeming to dull at all. Much more along the lines of what I expected out of a skookum resaw set up...
cron
