It is currently Fri Aug 15, 2025 7:36 am
 Post subject: Bending irons
PostPosted: Thu Sep 22, 2016 7:56 am
First name: Richard
Last Name: Bello
City: Weymouth
State: Ma
Zip/Postal Code: 02189
Country: Usa
Anyone willing to share their experience with commercially available bending irons (too busy to DIY)? I know LMI and SM but perhaps there are other options I am not aware of. Also, is the small end of the oval profile OK for mandolin/fiddle bends or would that require another iron? The SM version has an option for an attachment but I've heard some say that it doesn't really work that well. Thanks!!
 Post subject: Re: Bending irons
PostPosted: Thu Sep 22, 2016 10:24 am
Last Name: Parchem
City: Seattle
State: Wa
Zip/Postal Code: 98177
I have the stewmac version with the extension. I can not compare as it is the only one I have used. I like the shape of the iron a lot. I have bent very tight curves using the various radiuses the iron presents. The extension is not very wide I use it for purflings like herringbone; the right angle where the extension intersects with the main iron helps me keep the purfling square.
The iron gets very hot. I bend on max with very little water. I honed my skill bending ebony bindings for a tight venetian cutaway. I went through a whole stack before I got the feeling of when the wood is plastic.
PostPosted: Thu Sep 22, 2016 12:11 pm
I use the Ibex iron which is like the StewMac version except the end is not tapped (easy to do if I ever want to). Mine did not get as hot as I wanted so I souped it up by putting in a higher wattage heating element - that thread is here:http://www.luthiersforum.com/forum/viewtopic.php?f=10101&t=37310
PostPosted: Fri Sep 23, 2016 6:39 am
Last Name: Parker
City: Charleston
State: West Virginia
Zip/Postal Code: 25314
I use a bending machine for sides, but I use an iron like Steve's without the smaller extension for purfling, touch up bends, stuff like that. I don't suffer from not having the extension. The egg profile of the pipe gets me all the radii I need. I guess if I were making really tight bends I would feel the need for the extension, but that's not my situation.
Mine gets plenty hot, by the way.
PostPosted: Fri Sep 23, 2016 9:14 am
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I lucked into a barely used second hand SM iron with the extension. I have done a uke on it without the extension. I find I use it at almost max temp.
Ed
PostPosted: Fri Sep 23, 2016 9:45 am
I've seen a lot of them on ebay, I think from the orient, at lower cost, but I have no idea of the quality.
PostPosted: Mon Sep 26, 2016 6:16 am
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
I had a Ibex one which worked OK for about 4 guitars and then broke. I then got one of those cheap "oriental" ones off E-Bay and it has outlasted the Ibex, and works fine.
PostPosted: Mon Sep 26, 2016 10:16 am
First name: Brad
Last Name: Hall
City: Windsor
State: Ca.
Zip/Postal Code: 95492
I started out with a piece of black pipe with a galvanized cap on one end and a reducer on the other. Hated it. I bought the LMI aluminum bending pipe , and use with a propane torch and love it. I don't have a way of controlling or even checking the temperature. I put a blue shop towel on the tube and spritz with water. It works very well. If I could afford a heating blanket and controller I would get them.
I'm a very low tech shop with many home made tools. Can't miss what I've never had, but do get tool envy from reading this site.
Brad Hall
Mystic Dawg Guitars
Users browsing this forum: bobgramann, Robbie_McD and 15 guests
